Philips 55POS9002/12 can't reach UMS
Re: Philips 55POS9002/12 can't reach UMS
Samples are the way to go, but the hunt for samples can be quite a task. A good place to start is here: https://samples.mplayerhq.hu/
@galmok You will also need your log informations given into by line
That you will later use into that line:
And the informations provided by the "Sink:" lines.
After that, you should be ready to go
I will suggest you to use something like that:
USER-AGENT: Linux...Code: Select all
UserAgentSearch = After that, you should be ready to go
UpnpDetailsSearch = Philips TV DMR.*2k15Re: Philips 55POS9002/12 can't reach UMS
Thanks for the hints so far.
I am trying to work out how the media formats are matched.
In "DefaultRenderer.conf", it says:
1) A file is requested to play. UMS checks the file with Mediainfo.
2) Mediainfo is compared with any "Supported = " lines in the config.
3) If matched, file is streamed directly to renderer.
4) If no Supported lines match, mediainfo is compared with the capabilities of the renderer (TV).
5) If matched, file is streamed to renderer.
6) If not matched, file is transcoded and then streamed to renderer.
Is this generally speaking correct?
This almost looks like no configuration is necessary. Yet, a little further down, this is what I read:If a file is supported and its mediainfo indicates that it falls within the
capabilities of this renderer, UMS will stream the file to the renderer. All
other files will be transcoded to the format specified in "TranscodeVideo"
or "TranscodeAudio" before being sent to the renderer.
Here is how I guess it works:Each format that the renderer supports should result in a "Supported" line
that defines the capabilities of the renderer. When MediaInfo = true, media
files are parsed and their properties are matched against all "Supported"
lines.
UMS/PMS has a long history, so there's a lot of cooks involved. I can't speak to why the desciption is like it is, but how it works is like this:
There's two different parsing implementations, the "old" and the "new". UMS still default to the "old" way, even though it's pretty bad (inaccurate). If "MediaInfo = true", MediaInfo (the "new" parser) will be used for that renderer, if it's false or missing the "old" parser will be used.
The "old" parser doesn't look at the "supported" lines at all. It simply decides what to do based on file extension, so you have settings for deciding if specific extensions should be "streamed" or transcoded. In UMS/PMSish, "streamed" means "not transcoded". It's actually wrong and confusing, because the media is streamed either way. Still, that's the term used everywhere.
The "new" parser aka MediaInfo use the "supported" lines to decide what the renderer can handle and not.
So, this is kind of how it works:
- A folder is browsed with a renderer. All the files in that folder is parsed or the parsed information is retrieved from the cache/database/media library, using either the "old" or the "new" parser (which is a bug in itself as the parser depends on the renderer but the results are stored in the database and might be used by a renderer with a different parser configured). UMS decides if the file should be transcoded or not, and to what format based on the configured setting if transcoding. This has to be determined at the time of browsing because UPnP/DLNA requires UMS to supply quite a lot of information about the file in the browse response.
- A file is requested to play. UMS use the decision from the previous step to determine how to deliver the file, and either sends the file directly or starts one of the transcoding engines.
So, if I were to configure to use MediaInfo = true, I would have to generate as many Supported lines that the renderer reports to support (or as many as I can be bothered to enter)?
The TV reports to understand 115 mime types (mixture of audio, video, image, text, and application (subtitles)):
It appears to quite capable. I feel it would be easier to write a list of formats not supported. :-/# <FLAGS> replaces DLNA.ORG_FLAGS=8d700000000000000000000000000000
# audio/mpeg:DLNA.ORG_PN=MP3;<FLAGS>
# audio/x-ms-wma:DLNA.ORG_PN=WMABASE;<FLAGS>
# audio/x-ms-wma:DLNA.ORG_PN=WMAFULL;<FLAGS>
# audio/x-ms-wma:DLNA.ORG_PN=WMAPRO;<FLAGS>
# audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS;<FLAGS>
# audio/mp4:DLNA.ORG_PN=AAC_ISO;<FLAGS>
# audio/mp4:DLNA.ORG_PN=AAC_ISO_320;<FLAGS>
# audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320;<FLAGS>
# audio/mp4:DLNA.ORG_PN=AAC_MULT5_ISO;<FLAGS>
# audio/mp4:DLNA.ORG_PN=HEAACv2_L2;<FLAGS>
# audio/mp4:DLNA.ORG_PN=HEAACv2_L2_320;<FLAGS>
# audio/mp4:DLNA.ORG_PN=HEAACv2_L3;<FLAGS>
# audio/mp4:DLNA.ORG_PN=HEAACv2_MULT5;<FLAGS>
# audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM;<FLAGS>
# audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM;<FLAGS>
# audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM;<FLAGS>
# audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM;<FLAGS>
# image/jpeg:DLNA.ORG_PN=JPEG_SM
# image/jpeg:DLNA.ORG_PN=JPEG_MED
# image/jpeg:DLNA.ORG_PN=JPEG_LRG
# image/jpeg:DLNA.ORG_PN=JPEG_SM_ICO
# image/jpeg:DLNA.ORG_PN=JPEG_LRG_ICO
# video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC;<FLAGS>
# video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL;<FLAGS>
# video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU;<FLAGS>
# video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T;<FLAGS>
# video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;<FLAGS>
# video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_60_L2_T;<FLAGS>
# video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_60_AC3_T;<FLAGS>
# video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_50_L2_T;<FLAGS>
# video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_50_AC3_T;<FLAGS>
# video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC;<FLAGS>
# video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_520;<FLAGS>
# video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L2_CIF30_AAC;<FLAGS>
# video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L3_SD_AAC;<FLAGS>
# video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L3L_SD_AAC;<FLAGS>
# video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_MPEG1_L3;<FLAGS>
# video/mp4:DLNA.ORG_PN=AVC_MP4_HP_SD_HEAACv2_L4;<FLAGS>
# video/mp4:DLNA.ORG_PN=AVC_MP4_HP_HD_HEAACv2_L4;<FLAGS>
# video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_L2_AAC;<FLAGS>
# video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_AAC;<FLAGS>
# video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_VGA_AAC;<FLAGS>
# video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_AAC;<FLAGS>
# video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_L5_SO_AAC;<FLAGS>
# video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_L4_SO_AAC;<FLAGS>
# video/x-ms-wmv:DLNA.ORG_PN=WMVSPLL_BASE;<FLAGS>
# video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_BASE;<FLAGS>
# video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE;<FLAGS>
# video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL;<FLAGS>
# video/x-ms-wmv:DLNA.ORG_PN=WMVHM_BASE;<FLAGS>
# video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL;<FLAGS>
# video/x-matroska:DLNA.ORG_PN=AVC_MKV_MP_HD_AAC_MULT5;<FLAGS>
# video/x-matroska:DLNA.ORG_PN=AVC_MKV_MP_HD_HEAAC_L4;<FLAGS>
# video/x-matroska:DLNA.ORG_PN=AVC_MKV_MP_HD_AC3;<FLAGS>
# video/x-matroska:DLNA.ORG_PN=AVC_MKV_MP_HD_MPEG1_L3;<FLAGS>
# video/x-matroska:DLNA.ORG_PN=AVC_MKV_HP_HD_AAC_MULT5;<FLAGS>
# video/x-matroska:DLNA.ORG_PN=AVC_MKV_HP_HD_HEAAC_L4;<FLAGS>
# video/x-matroska:DLNA.ORG_PN=AVC_MKV_HP_HD_AC3;<FLAGS>
# video/x-matroska:DLNA.ORG_PN=AVC_MKV_HP_HD_MPEG1_L3;<FLAGS>
# video/x-ms-asf:*
# video/x-ms-asf-plugin:*
# video/avi:*
# video/x-ms-avi:*
# video/msvideo:*
# video/x-msvideo:*
# video/h264:*
# video/x-xvid:*
# video/quicktime:*
# video/webm:*
# audio/amr:*
# video/mpeg4:*
# video/x-matroska:*
# video/mpeg:*
# video/MP2T:*
# video/vnd.dlna.mpeg-tts:*
# video/mp4v-es:*
# video/mp4:*
# video/x-ms-wmv:*
# video/x-m4v:*
# video/x-m4a:*
# video/x-mkv:*
# video/x-matroska-3d:*
# video/3gpp:*
# audio/mpeg:*
# audio/x-ms-wma:*
# audio/x-ms-asf:*
# audio/L16:*
# audio/lpcm:*
# audio/wav:*
# audio/x-wav:*
# audio/x-aiff:*
# audio/mp4:*
# audio/x-aac:*
# audio/aac:*
# audio/x-mpegurl:*
# audio/amr:*
# audio/3gpp:*
# audio/3gpp2:*
# audio/vnd.dolby.dd-raw:*
# audio/vnd-dts:*
# audio/x-m4a:*
# audio/x-flac:*
# audio/flac:*
# audio/ogg:*
# audio/vorbis:*
# audio/vorbis-config:*
# image/png:DLNA.ORG_PN=PNG_LRG
# image/png:DLNA.ORG_PN=PNG_TN
# image/png:DLNA.ORG_PN=PNG_SM_ICO
# image/png:DLNA.ORG_PN=PNG_LRG_ICO
# image/bmp:*
# text/plain:*
# text/x-microdvd:*
# application/x-subrip:*
# application/x-sami:*
No, many of those lines are almost the same and only requires one "supported" line. DLNA profiles aren't specified, only the format and codec combinations. Matroska for example would be one line with something like:
The exact codecs would have to be adjusted to your renderer, this is just an example from the Kodi configuration file.
Supported = f:mkv v:cvid|divx|h263|h264|h265|mjpeg|mp4|mpeg1|mpeg2|vc1|wmv a:aac-lc|he-aac|ac3|dts|dtshd|lpcm|mp2|mp3|mpa|truehd|wma m:video/x-matroska
