ums 2.6.5 - 3.0a3 just randomly freezes -OSX 10.9 Mavericks
- Optimus_prime
Re: ums 2.6.5 - 3.0a3 just randomly freezes -OSX 10.9 Maveri
I can't see anything so far, i'm currently setting up a Mavricks box so i can test to see what the issues may be
Just letting you know that I updated to UMS 3.1.0 in hopes that it would resolve the freezing issues, but it's still there.
Same issue after upgrading to 3.1.2.1
- Optimus_prime
I can't seem to pinpoint where it's going wrong in the old log, Could you upload a trace log for the latest version. Thanks again
Hi there,
I was having the same problems as you describe with running the latest UMS build on Mavericks.
Was that is , because yesterday night I discovered the latest Java 7 build from UMS that Optimus Prime provides us with.
This version runs very smoothly with no freezing at all and the subtitles are also working perfect.
Maybe you can try downloading Java 7 so you can use this version as well.
To Optimus_Prime I would like to say : A BIG THUMBS UP AND KEEP ON THE GREAT WORK.
Greetsssssssssssss , Snakebyte
- Optimus_prime
Thanks Snakebyte, I'll be continuing the Java 7 builds for UMS on OS-X into the future. More the better!!!
Whilst i don't actually use OS-X (I only have it to build OS-X versions of UMS), I know the community needs them so we have more people using this product, Cheer's to all
Get Java 7 Builds For OS-X Here
Make sure you remember to either install the Java 7 JRE or JDK
I installed 3.2.0 Java 7 build and everything seems be working flawlessly so far. I'll keep you posted if anything changes. Thanks for all the help!snakebyte wrote:I was having the same problems as you describe with running the latest UMS build on Mavericks.
--Brian
