During Playback, sometimes progress slider doesn't work
Re: During Playback, sometimes progress slider doesn't work
I removed the n: s: and b: sections from the .conf file as you suggested, but no difference.
Attached you'll find the log files.
What I did: I launched UMS in logging mode and played a FLAC file ("11. Touching Truth.flac"). The FLAC file played fine, but without the progress slider.
In the UMS config on the General Settings tab, at "Enabled renderers" only the Sangean WFT-3 is selected. Setting "Default renderer" is set to "Sangean WFT-3" and I checked the checkbox "Forced default renderer".
The Sangean media player has ip 192.168.1.75.
Hope you can shine some light on this.
