Help with Linux Mint
cooltwou
Re: Help with Linux Mint
Post by cooltwou »
it shows the folder under this /opt/ums but it doesn't allow you to put a folder in there zipped or unzipped and sudo-V says this:
Sudo version 1.9.15p5
Sudoers policy plugin version 1.9.15p5
Sudoers file grammar version 50
Sudoers I/O plugin version 1.9.15p5
Sudoers audit plugin version 1.9.15p5
boss
Post by boss »
If I am understanding correctly,
The command from the opt folder: "sudo mkdir ums" worked.
But
The command to copy the install file "UMS-Linux-15.6.0-x86_64.tgz" by using sudo is not working.
How are you trying to copy "UMS-Linux-15.6.0-x86_64.tgz" to the /opt/ums folder?
Or is it
You can copy the "UMS-Linux-15.6.0-x86_64.tgz" file to /opt/ums and the unpacking using the command: "sudo tar -xvzf UMS-Linux-15.6.0-x86_64.tgz"
does not work.
cooltwou
Post by cooltwou »
the problem here is you can ses the folder but you can't copy anything in the folder it just keeps saying permission denied You can copy the "UMS-Linux-15.6.0-x86_64.tgz" file to /opt/ums and the unpacking using the command: "sudo tar -xvzf UMS-Linux-15.6.0-x86_64.tgz"
does not work. and it lets you unzip but you can't put anything in that folder
when you enter sudo tar -xvzf UMS-Linux-15.6.0-x86_64.tgz you get this:
[sudo] password for cooltwou:
tar (child): UMS-Linux-15.6.0-x86_64.tgz: Cannot open: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
cooltwou@Cooley-Home-Network:~$ sudo tar -xvzf UMS-Linux-15.6.0-x86_64.tgz
boss
Post by boss »
Perhaps the folder needs creating first.
Do you have a folder: /opt/ums/ums-15.6.0/ ?
If not try creating the folder first.
From /opt/ums/
sudo mkdir ums-15.6.0
Then try: "sudo tar -xvzf UMS-Linux-15.6.0-x86_64.tgz" again.
cooltwou
Post by cooltwou »
i have a folder called opt and it has a ums folder in it I attached a picture that shows I have the folder made on my laptop
boss
Post by boss »
What is inside the ums folder ?
And ... Are doing this from your laptop in gui or are you using the command line interface on your Linux computer?
cooltwou
Post by cooltwou »
I was trying to transfer from downloads folder to the UMS folder and in the opt ums folder nothing is in it and the picture shows what is in the other ums folder
boss
Post by boss »
We are not going to get very far if you don't answer my questions.
Is english not your language? Are you using a translator to read and answer my questions?
You have done an install to the downloads folder.
Do this:
cd /opt/ums/
ls -l
Post the output
cooltwou
Post by cooltwou »
English is the only I speak language & the OPT/UMS has nothing in it & it doesn't let you transfer anything to it either & ls -l /opt/ums says total zero and I have folder up 15.6.0 & it just keeps saying this Error moving file /home/cooltwou/Downloads/ums-15.6.0/jre17: Permission denied even you try to transfer the whole folder or you folder & try to transfer individual folders into the OPT/UMS folder you still get the same error message
boss
Post by boss »
This is using the terminal when this problem happens. NOT using the GUI?
and
Where is the file "UMS-Linux-15.6.0-x86_64.tgz" located now.
