[Solved] No subtitle on samsung TV F series
Re: No subtitle on samsung TV F series
I suspect this is all the same bug so hopefully your testing will help a lot of people :) Please try this one, the official 4.0.0: http://sourceforge.net/projects/unimedi ... e/download
MAdS
Post by MAdS »
Just tried official 4.0.0 and subtitles are, indeed, OK.
Thanks, I hope it's fixed in this version:
http://www.spirton.com/uploads/UMS/UMS-cc9f131.exe
If it is then we'll release 4.0.3 ASAP
MAdS
Post by MAdS »
We have a winner. Great job! Thank you very much!! :D :D :D :D :D
Awesome! That fix was more of a workaround so I hope this one works too since it will be more reliable for multiple subtitle choices, please let me know:
http://www.spirton.com/uploads/UMS/UMS-MAdS.exe
MAdS
Post by MAdS »
Working fine too.
Saw titles changed from {External Subtitles} to {Sub: SubRIP}.
pipin
Post by pipin »
Subtitles on 32F4500 are working too.
Regards,
Jens
Thanks pipin, we are releasing the version with the fix now :)
