Version 4.1.3 is released
ArnBok
Re: Version 4.1.3 is released
Post by ArnBok »
Hi
I got problem with my Sony home thetatre system (BDV-E370) and have to back version 4.1.1. Then it work again!
t.u.g.
Post by t.u.g. »
Hi Guys,
is it possible to create a renderer for Technisat S1+? Its a HDTV-Tuner with UPnP-Support.
I tried out many other media server software on my ubuntu server 13.10 like plex or ps3 media server, but that wasn't the right thing. One time are the media folders empty, other time the transcoding will not start the movie (i walked thru the transcoding folder and start the movie but the movie won't play.) No i will give UMS a chance.
Sorry for my bad english.
Thanks.
smirk
Post by smirk »
Thanks for another awesome release!
I just clean-installed it and noticed something minor. In the Navigation/Share Settings tab, "Enable the cache" is enabled by default, but its tooltip says that the default is disabled.
Other than that, everything's working perfectly. :-)
fjrial
Post by fjrial »
sma76928 wrote:Hi:
is there any update about LG webos TV? this version stills not working with this TVs
best regads
I am using version 4.0.0 with LG webos TV with only a minor problem about subtitles support.
Profile using LG LA6200.. but my tv is LG 42 LB650v
Edited the mentioned profile and added this line
SupportedSubtitlesFormats = SUBRIP,ASS
This allow the SRT subtitles to be shown on the tv
Other minor problems:
-problems resuming videos: if I resume a video, the video does not reach to the end.. finish on some point randomly previous to the end..
-after playing more than 200 videos, some of them, a few dont play.. doesn´t check/review the video/codec etc..
ArnBok wrote:Hi
What's the problem?
t.u.g. wrote:Hi Guys,
Thanks.
Sure we can support it, first I need you to upload logs using version 5.0.0-a1 so we know how to identify the device. Just run UMS, power on the Technisat S1+, make sure they connect and then use "Pack debug files" on the "Logs" tab to save the logs :)
