Version 5.0.0-b1 is released
sma76928
Re: Version 5.0.0-b1 is released
Post by sma76928 »
SharkHunter wrote:Does it work with 4.x? This is not something that has changed in 5.0 so if it works in 4 it should work.
no, as i reported on every release since 4.x UMS is not working on LG webos tv. it doesn't transcode. it get buffering and sending the movie as mpg2 and there is no audio.
best regards
Marco
Spareone
Post by Spareone »
I have noticed a few issues since updating from 4.2.x
1) The forward and reverse scan does not work on Samsung ES8000. This seems due to the time not running on the video so I cannot scan to a part of a film etc.
2) The connection seems to drop within 2 mins of the end of a title.
3) Xbox One did not detect this version.
Maybe it is a configuration issue, so any help would be appreciated. The good news is that the mkv files load and stream within 5 seconds now, where as before it took almost 2 mins to start playing a title once selected...
Kefran
Post by Kefran »
Hey guys, nice new interface.
I'm unable to get any videos to play via tsMuxR (OSX 10.9.5).
I can send logs in another post if needed.
Thanks for all your work guys!! :)
jps92
Post by jps92 »
"Nope. it just means you don't have a WEB.conf file and thus UMS will not add a WEB folder. If this wasn't intended (or if you've got some odd permissions so that the WEB.conf can't be read) you should probably reinstall/restore the WEB.conf/make sure it is readable by UMS."
I've re-installed ums (after deleted previous install) but it's the same. I've verified i can read and write in the folder with ums.conf and web.conf. Nevertheless there is "Web conf path: C:\ProgramData\UMS\WEB.conf
12-10 12:28:16 Web conf permissions: rw" in the traces log.
Rocket
Post by Rocket »
shaina wrote:xbox 360 still not working on this release ??
For me, 4.2.2 is the latest version that works with the 360.
If someone can make logs we can fix the Xbox 360 issue
shaina
Post by shaina »
Hi SubJunk
I made a trace ums_dbg.zip file to fix the xbox360 but I don't know where the attachment button is
also when you open the xbox360
the folders you see are
All Photos
By camera model
By Date
By ISO settings
Hi shaina, you can attach it in the support forum, here's a link to start a new thread in the support forum: posting.php?mode=post&f=9
shaina
Post by shaina »
HI SubJunk
I think I got it to attach debug files for fix on xbox360 .conf
it is posted in General Help And Support where you requested it and marked for you
thanks again
shaina
RMcV
5.0.0-b1 does not successfully play next video
Post by RMcV »
I installed UMS 5-a1 and the play next video in folder worked like a charm, however, when I installed 5-b1 this function fails with a popup saying "video cannot be played". The videos are the precise same files in both cases. The files are MKVs with 1080p AVC and 2 ch AC-3. The Android client is eHomeMediaCenter v2.0.23_121109. The Android device is an MK808.
I hope you can fix this so that I can install your future versions.
Thanks.
