[Solved] 24-bit FLAC files "This content cannot be played."
Re: 24-bit FLAC files "This content cannot be played."
Yes I clean install every release. When I try and play the file under the video section of the PS3 on UMS 5.0.0 I get: This content cannot be played. (800288E1)
Are you playing with the Audio section or Video section? The file plays under Audio, but 24 bit needs to be played under video to get the correct bit depth and kHz, correct? It must use Audio High Fidelity and not FFmPeg Audio.
Yeah I played it in the video section, and confirmed it was being played in 24-bit mode by toggling the info on the PS3
Hmm ok interesting. Is there some log file I can send to find out why it's failing on my end?
Yeah if you can attach logs for it using 5.0.0 I'll have a look
Here you go. One thing I did just notice is that it has [Audio High Fidelity] next to the file names twice on the PS3. Not sure if that has anything to do with the problem.
Still can't upload an attachment to the forum for some reason. Here's the link to the logs:
https://www.mediafire.com/?s33p7f9bod658d2
The logs are showing that FFmpeg can't find the file "DummyInput.jpg" which should be in "C:\Program Files (x86)\Universal Media Server\win32\", can you confirm that file isn't there?
Can confirm, that file does not exist in that dir on my computer.
When I clean install 3.3.0 there are "DummyInput.jpg" and "DummyOutput.mpeg" files in the "C:\Program Files (x86)\Universal Media Server\" directory. Those files don't exist when i clean install any version after 3.3.0.
There is a "DummyInput.ass" in that root directory with 5.0.0.
Putting those jpg and mpeg files from 3.0.0 in the root dir and restarting 5.0.0 allow 24 bit files to be played!
You're right, the file was removed accidentally while trying to fix another issue. I've re-added it now for the upcoming 5.0.1 release
Re: [Solved] 24-bit FLAC files "This content cannot be played."
Thanks so much!
