Constant 25% CPU usage even video not being played
recognosco
Re: Constant 25% CPU usage even video not being played
quick question - what version java do you have? because i uninstalled older versions of java and installed the latest version (jre1.8.0_80) and the cpu usage issues went away. or at least i haven't noticed since java update.
I have 1.8.0_40 64-bit and 32-bit. Not sure if having both of these causes the problem with 5.0.1. But I don't have any problems with 4.4.0.
having the same problem here. Always minimized UMS 5.0.1 Java 1.8.0_40-b26
never had CPU problems prior to 5.0.x
Still no more replies from devs?
I hope they don't add some cool features that I could miss if I can't upgrade to newest versions due to this bug.
I didn't get chance to test 5.1.0 version, if this problem is fixed in it because BubbleUPnP didn't want to play any files. I had two locations, one is directly from UMS, which had files in it, but they dind't play (most likely because unsupported by Chromecast) and second one is via BubbleUPnP server, which had no files at all for unknown reason.
Hi guys, I've made an issue for this on our tracker at https://github.com/UniversalMediaServer ... issues/513
I was unable to test this issue with Version 5.1.1.1-Java8 because it did not start anymore after restarting PC. I had no time to try to fix it so I downgraded to 4.4.0-Java8 which has no problems.
It seems to me as a bug in the startPoll() in the Chromecast.player. In the log Nake sent there are every 1 sec an error It could be also the Chomecast or the network problem. There is also running BubbleUPnP or TumpoCast on the same computer as UMS is running. It may also caused this problem. UMS version 4.4.0 is working OK because the Chromecast support was introduced in the 5.0 version
Bad chromecast mediastate javax.net.ssl.SSLException: Connection has been shutdown: javax.net.ssl.SSLException: java.net.SocketException: Connection resetRe: Constant 25% CPU usage even video not being played
Yes I have BubbleUPNP running. Can you even use only UMS and play all videos via Chromecast on TV?valib wrote:It seems to me as a bug in the startPoll() in the Chromecast.player. In the log Nake sent there are every 1 sec an errorIt could be also the Chomecast or the network problem. There is also running BubbleUPnP or TumpoCast on the same computer as UMS is running. It may also caused this problem. UMS version 4.4.0 is working OK because the Chromecast support was introduced in the 5.0 versionCode: Select all
Yes I recommend to stop BubbleUPNP and try to use Chromecast. The Chromecast support is included in UMS since 4.0.0 UMS version.
