Widnows 10
Re: Widnows 10
All problems is just about network ... i have not not upgraded it yet, but sound so boring! :/
Re: Widnows 10
Hi there,Trell wrote:I just turn off my firewall and it works. I guess that will have to do...
I had a bit of a similar problem where my clients/renders wouldn't find UMS.
Im using Windows Server 2012 R2 Standard with Advanced Windows Firewall, so if you are using an application based firewall you might not have some settings. As a reminder, although some of my settings are open to public networks, there is still my router firewall to public.
I was using Plex prior to UMS and I was getting so mad I went into a Port opening rampage until it was working. So some of these ports might not even be needed.
Inbound:
Aplication UMS, All Ports, Any Protocol, Any profile(Domain, Private, Public)
Aplication Javaw, All Ports, Any Protocol, Any profile(Domain, Private, Public)
UMS listening, Port 5001 TCP, Profile (Private, Domain)
UMS listening, Port 5001 UDP, Profile (Private, Domain)
DNLA discovery, Port 2869 TCP, Profile (Private, Domain)
DNLA discovery, Port 1900 UDP, Profile (Private, Domain)
Some extra Inbound rules I'm not sure if its helping or not.
My client has a fixed IP so I have rule just for that.
Client, Any Port, Scope: Local IP: 192.168.1.50(example) Any Protocol, Profile (Private, Domain)
Some ports I had open when trying to get plex to work (Kinda Overkill lol):
TCP 32469, 32400
UDP 32469, 32400, 5353, 32410, 32412, 32413, 32414
Outbound:
Aplication UMS, All Ports, Any Protocol, profile(Domain, Private)
Aplication Javaw, All Ports, Any Protocol, profile(Domain, Private)
So yeah, my UMS is working with all these ports open lol
I will try to narrow down the necessary ports still and come back to you (if I dont forget
Hope it helps.
