.WTV Support
Millerisonway
Re: .WTV Support
Maybe you can first convert wtv file to h.264 format, then play it on UMS. I use Faasoft Video Converter to convert wtv file to H.264 format. Give it a try.
Re: .WTV Support
No need to convert if FFMPEG supports it natively. The devs will find a solution.
Universal Media Server Wiki!
Re: .WTV Support
Electrifying Which TV do you use? UMS shows and transcodes .wtv files for me (Panasonic TV). Tested on video http://www.mediafire.com/download/64nz7 ... c_news.wtv
Re: .WTV Support
Maybe a simple solution might be to rename the file extension. To, say, yourfile.mp4 without actually converting it. You might want to try just one or so for testing it first.
