[Testers Required] UMS Running on Java 7
buccia
Re: [Testers Required] UMS Running on Java 7
Post by buccia »
Dear Optimus,
here is my log, I hope it helps.
Ciao Marco
5/5/13 11:47:11.479 AM [0x0-0x81081].net.pms.PMS: 11:47:11.472 [main] DEBUG o.a.c.c.ConfigurationUtils - ConfigurationUtils.locate(): base is null, name is /Users/marco/Library/Application Support/UMS/UMS.conf
5/5/13 11:47:11.479 AM [0x0-0x81081].net.pms.PMS: 11:47:11.478 [main] DEBUG o.a.c.c.DefaultFileSystem - Could not locate file /Users/marco/Library/Application Support/UMS/UMS.conf at null: no protocol: /Users/marco/Library/Application Support/UMS/UMS.conf
5/5/13 11:47:11.479 AM [0x0-0x81081].net.pms.PMS: 11:47:11.478 [main] DEBUG o.a.c.c.ConfigurationUtils - Loading configuration from the absolute path /Users/marco/Library/Application Support/UMS/UMS.conf
5/5/13 11:47:11.485 AM [0x0-0x81081].net.pms.PMS: 11:47:11.485 [main] DEBUG o.a.c.c.PropertiesConfiguration - Base path set to file:///Users/marco/Library/Application%20Support/UMS/UMS.conf
5/5/13 11:47:11.504 AM [0x0-0x81081].net.pms.PMS: 11:47:11.503 [main] DEBUG o.a.c.c.PropertiesConfiguration - FileName set to UMS.conf
5/5/13 11:47:11.505 AM [0x0-0x81081].net.pms.PMS: 11:47:11.504 [main] DEBUG o.a.c.c.PropertiesConfiguration - Base path set to /Users/marco/Library/Application Support/UMS
5/5/13 11:47:11.611 AM [0x0-0x81081].net.pms.PMS: 11:47:11,610 |-INFO in ch.qos.logback.core.joran.action.DefinePropertyAction - About to instantiate property definer of type [net.pms.logging.DebugLogPathDefiner]
5/5/13 11:47:11.613 AM [0x0-0x81081].net.pms.PMS: 11:47:11,612 |-INFO in ch.qos.logback.core.joran.action.DefinePropertyAction - Popping property definer for property named [debugLogPath] from the object stack
5/5/13 11:47:11.615 AM [0x0-0x81081].net.pms.PMS: 11:47:11,615 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [net.pms.logging.FrameAppender]
5/5/13 11:47:11.616 AM [0x0-0x81081].net.pms.PMS: 11:47:11,616 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [traces]
5/5/13 11:47:11.670 AM [0x0-0x81081].net.pms.PMS: 11:47:11,668 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.ConsoleAppender]
5/5/13 11:47:11.670 AM [0x0-0x81081].net.pms.PMS: 11:47:11,668 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [console]
5/5/13 11:47:11.677 AM [0x0-0x81081].net.pms.PMS: 11:47:11,677 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.FileAppender]
5/5/13 11:47:11.680 AM [0x0-0x81081].net.pms.PMS: 11:47:11,679 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [debug.log]
5/5/13 11:47:11.691 AM [0x0-0x81081].net.pms.PMS: 11:47:11,685 |-INFO in ch.qos.logback.core.FileAppender[debug.log] - File property is set to [/Applications/Universal Media Server 2.app/Contents/Resources/debug.log]
5/5/13 11:47:11.691 AM [0x0-0x81081].net.pms.PMS: 11:47:11,687 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.rolling.RollingFileAppender]
5/5/13 11:47:11.691 AM [0x0-0x81081].net.pms.PMS: 11:47:11,689 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [debug.log.10MB]
5/5/13 11:47:11.708 AM [0x0-0x81081].net.pms.PMS: 11:47:11,708 |-INFO in ch.qos.logback.core.rolling.FixedWindowRollingPolicy@182c0e6 - Will use zip compression
5/5/13 11:47:11.720 AM [0x0-0x81081].net.pms.PMS: 11:47:11,719 |-INFO in ch.qos.logback.core.rolling.RollingFileAppender[debug.log.10MB] - Active log file name: /Applications/Universal Media Server 2.app/Contents/Resources/debug.log
5/5/13 11:47:11.720 AM [0x0-0x81081].net.pms.PMS: 11:47:11,720 |-INFO in ch.qos.logback.core.rolling.RollingFileAppender[debug.log.10MB] - File property is set to [/Applications/Universal Media Server 2.app/Contents/Resources/debug.log]
5/5/13 11:47:11.721 AM [0x0-0x81081].net.pms.PMS: 11:47:11,720 |-INFO in ch.qos.logback.classic.joran.action.LoggerAction - Setting level of logger [org.apache] to WARN
5/5/13 11:47:11.721 AM [0x0-0x81081].net.pms.PMS: 11:47:11,720 |-INFO in ch.qos.logback.classic.joran.action.LoggerAction - Setting level of logger [httpclient.wire] to WARN
5/5/13 11:47:11.721 AM [0x0-0x81081].net.pms.PMS: 11:47:11,720 |-INFO in ch.qos.logback.classic.joran.action.RootLoggerAction - Setting level of ROOT logger to DEBUG
5/5/13 11:47:11.722 AM [0x0-0x81081].net.pms.PMS: 11:47:11,721 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [traces] to Logger[ROOT]
5/5/13 11:47:11.722 AM [0x0-0x81081].net.pms.PMS: 11:47:11,721 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [console] to Logger[ROOT]
5/5/13 11:47:11.722 AM [0x0-0x81081].net.pms.PMS: 11:47:11,721 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [debug.log] to Logger[ROOT]
5/5/13 11:47:11.722 AM [0x0-0x81081].net.pms.PMS: 11:47:11,721 |-INFO in ch.qos.logback.classic.joran.action.ConfigurationAction - End of configuration.
5/5/13 11:47:11.723 AM [0x0-0x81081].net.pms.PMS: 11:47:11,721 |-INFO in ch.qos.logback.classic.joran.JoranConfigurator@6c5a12d5 - Registering current configuration as safe fallback point
5/5/13 11:47:12.710 AM [0x0-0x81081].net.pms.PMS: ERROR 2013-05-05 11:47:12.709 [main] A serious error occurred during PMS init
5/5/13 11:47:12.710 AM [0x0-0x81081].net.pms.PMS: java.lang.StringIndexOutOfBoundsException: String index out of range: -5
5/5/13 11:47:12.710 AM [0x0-0x81081].net.pms.PMS: 	at java.lang.String.substring(String.java:1875) ~[na:1.7.0_21]
5/5/13 11:47:12.710 AM [0x0-0x81081].net.pms.PMS: 	at net.pms.util.WindowsRegistry.readRegistry(WindowsRegistry.java:34) ~[ums.jar:3.0.0]
5/5/13 11:47:12.710 AM [0x0-0x81081].net.pms.PMS: 	at net.pms.configuration.PmsConfiguration.isAutoStart(PmsConfiguration.java:1725) ~[ums.jar:3.0.0]
5/5/13 11:47:12.710 AM [0x0-0x81081].net.pms.PMS: 	at net.pms.newgui.GeneralTab.build(GeneralTab.java:106) ~[ums.jar:3.0.0]
5/5/13 11:47:12.710 AM [0x0-0x81081].net.pms.PMS: 	at net.pms.newgui.LooksFrame.buildMain(LooksFrame.java:401) ~[ums.jar:3.0.0]
5/5/13 11:47:12.710 AM [0x0-0x81081].net.pms.PMS: 	at net.pms.newgui.LooksFrame.buildContent(LooksFrame.java:373) ~[ums.jar:3.0.0]
5/5/13 11:47:12.710 AM [0x0-0x81081].net.pms.PMS: 	at net.pms.newgui.LooksFrame.<init>(LooksFrame.java:253) ~[ums.jar:3.0.0]
5/5/13 11:47:12.710 AM [0x0-0x81081].net.pms.PMS: 	at net.pms.PMS.init(PMS.java:423) [ums.jar:3.0.0]
5/5/13 11:47:12.710 AM [0x0-0x81081].net.pms.PMS: 	at net.pms.PMS.createInstance(PMS.java:968) [ums.jar:3.0.0]
5/5/13 11:47:12.710 AM [0x0-0x81081].net.pms.PMS: 	at net.pms.PMS.main(PMS.java:1060) [ums.jar:3.0.0]
EDIT: after loading the version you have created for me (thanks!), UMS does not start yet and this is the log:
5/5/13 4:12:13.810 PM [0x0-0x2d02d].net.pms.PMS: 16:12:13.794 [main] DEBUG o.a.c.c.ConfigurationUtils - ConfigurationUtils.locate(): base is null, name is /Users/marco/Library/Application Support/UMS/UMS.conf
5/5/13 4:12:13.811 PM [0x0-0x2d02d].net.pms.PMS: 16:12:13.810 [main] DEBUG o.a.c.c.DefaultFileSystem - Could not locate file /Users/marco/Library/Application Support/UMS/UMS.conf at null: no protocol: /Users/marco/Library/Application Support/UMS/UMS.conf
5/5/13 4:12:13.811 PM [0x0-0x2d02d].net.pms.PMS: 16:12:13.810 [main] DEBUG o.a.c.c.ConfigurationUtils - Loading configuration from the absolute path /Users/marco/Library/Application Support/UMS/UMS.conf
5/5/13 4:12:13.819 PM [0x0-0x2d02d].net.pms.PMS: 16:12:13.819 [main] DEBUG o.a.c.c.PropertiesConfiguration - Base path set to file:///Users/marco/Library/Application%20Support/UMS/UMS.conf
5/5/13 4:12:13.873 PM [0x0-0x2d02d].net.pms.PMS: 16:12:13.872 [main] DEBUG o.a.c.c.PropertiesConfiguration - FileName set to UMS.conf
5/5/13 4:12:13.873 PM [0x0-0x2d02d].net.pms.PMS: 16:12:13.872 [main] DEBUG o.a.c.c.PropertiesConfiguration - Base path set to /Users/marco/Library/Application Support/UMS
5/5/13 4:12:14.248 PM [0x0-0x2d02d].net.pms.PMS: 16:12:14,247 |-INFO in ch.qos.logback.core.joran.action.DefinePropertyAction - About to instantiate property definer of type [net.pms.logging.DebugLogPathDefiner]
5/5/13 4:12:14.250 PM [0x0-0x2d02d].net.pms.PMS: 16:12:14,250 |-INFO in ch.qos.logback.core.joran.action.DefinePropertyAction - Popping property definer for property named [debugLogPath] from the object stack
5/5/13 4:12:14.253 PM [0x0-0x2d02d].net.pms.PMS: 16:12:14,252 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [net.pms.logging.FrameAppender]
5/5/13 4:12:14.254 PM [0x0-0x2d02d].net.pms.PMS: 16:12:14,254 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [traces]
5/5/13 4:12:14.415 PM [0x0-0x2d02d].net.pms.PMS: 16:12:14,413 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.ConsoleAppender]
5/5/13 4:12:14.415 PM [0x0-0x2d02d].net.pms.PMS: 16:12:14,413 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [console]
5/5/13 4:12:14.422 PM [0x0-0x2d02d].net.pms.PMS: 16:12:14,422 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.FileAppender]
5/5/13 4:12:14.425 PM [0x0-0x2d02d].net.pms.PMS: 16:12:14,425 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [debug.log]
5/5/13 4:12:14.433 PM [0x0-0x2d02d].net.pms.PMS: 16:12:14,430 |-INFO in ch.qos.logback.core.FileAppender[debug.log] - File property is set to [/Applications/Universal Media Server 3.app/Contents/Resources/debug.log]
5/5/13 4:12:14.441 PM [0x0-0x2d02d].net.pms.PMS: 16:12:14,440 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.rolling.RollingFileAppender]
5/5/13 4:12:14.443 PM [0x0-0x2d02d].net.pms.PMS: 16:12:14,443 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [debug.log.10MB]
5/5/13 4:12:14.467 PM [0x0-0x2d02d].net.pms.PMS: 16:12:14,466 |-INFO in ch.qos.logback.core.rolling.FixedWindowRollingPolicy@4f22bfd6 - Will use zip compression
5/5/13 4:12:14.479 PM [0x0-0x2d02d].net.pms.PMS: 16:12:14,478 |-INFO in ch.qos.logback.core.rolling.RollingFileAppender[debug.log.10MB] - Active log file name: /Applications/Universal Media Server 3.app/Contents/Resources/debug.log
5/5/13 4:12:14.479 PM [0x0-0x2d02d].net.pms.PMS: 16:12:14,478 |-INFO in ch.qos.logback.core.rolling.RollingFileAppender[debug.log.10MB] - File property is set to [/Applications/Universal Media Server 3.app/Contents/Resources/debug.log]
5/5/13 4:12:14.479 PM [0x0-0x2d02d].net.pms.PMS: 16:12:14,479 |-INFO in ch.qos.logback.classic.joran.action.LoggerAction - Setting level of logger [org.apache] to WARN
5/5/13 4:12:14.480 PM [0x0-0x2d02d].net.pms.PMS: 16:12:14,479 |-INFO in ch.qos.logback.classic.joran.action.LoggerAction - Setting level of logger [httpclient.wire] to WARN
5/5/13 4:12:14.480 PM [0x0-0x2d02d].net.pms.PMS: 16:12:14,479 |-INFO in ch.qos.logback.classic.joran.action.RootLoggerAction - Setting level of ROOT logger to DEBUG
5/5/13 4:12:14.480 PM [0x0-0x2d02d].net.pms.PMS: 16:12:14,479 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [traces] to Logger[ROOT]
5/5/13 4:12:14.480 PM [0x0-0x2d02d].net.pms.PMS: 16:12:14,479 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [console] to Logger[ROOT]
5/5/13 4:12:14.480 PM [0x0-0x2d02d].net.pms.PMS: 16:12:14,479 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [debug.log] to Logger[ROOT]
5/5/13 4:12:14.480 PM [0x0-0x2d02d].net.pms.PMS: 16:12:14,480 |-INFO in ch.qos.logback.classic.joran.action.ConfigurationAction - End of configuration.
5/5/13 4:12:14.481 PM [0x0-0x2d02d].net.pms.PMS: 16:12:14,480 |-INFO in ch.qos.logback.classic.joran.JoranConfigurator@22fa544b - Registering current configuration as safe fallback point
5/5/13 4:12:15.000 PM kernel: (default pager): [KERNEL]: ps_select_segment - send HI_WAT_ALERT
5/5/13 4:12:15.000 PM kernel: macx_swapon SUCCESS
5/5/13 4:12:16.766 PM [0x0-0x2d02d].net.pms.PMS: ERROR 2013-05-05 16:12:16.765 [main] A serious error occurred during PMS init
5/5/13 4:12:16.766 PM [0x0-0x2d02d].net.pms.PMS: java.lang.StringIndexOutOfBoundsException: String index out of range: -5
5/5/13 4:12:16.766 PM [0x0-0x2d02d].net.pms.PMS: 	at java.lang.String.substring(String.java:1875) ~[na:1.7.0_21]
5/5/13 4:12:16.766 PM [0x0-0x2d02d].net.pms.PMS: 	at net.pms.util.WindowsRegistry.readRegistry(WindowsRegistry.java:34) ~[ums.jar:3.0.0]
5/5/13 4:12:16.766 PM [0x0-0x2d02d].net.pms.PMS: 	at net.pms.configuration.PmsConfiguration.isAutoStart(PmsConfiguration.java:1740) ~[ums.jar:3.0.0]
5/5/13 4:12:16.766 PM [0x0-0x2d02d].net.pms.PMS: 	at net.pms.newgui.GeneralTab.build(GeneralTab.java:107) ~[ums.jar:3.0.0]
5/5/13 4:12:16.766 PM [0x0-0x2d02d].net.pms.PMS: 	at net.pms.newgui.LooksFrame.buildMain(LooksFrame.java:401) ~[ums.jar:3.0.0]
5/5/13 4:12:16.766 PM [0x0-0x2d02d].net.pms.PMS: 	at net.pms.newgui.LooksFrame.buildContent(LooksFrame.java:373) ~[ums.jar:3.0.0]
5/5/13 4:12:16.766 PM [0x0-0x2d02d].net.pms.PMS: 	at net.pms.newgui.LooksFrame.<init>(LooksFrame.java:253) ~[ums.jar:3.0.0]
5/5/13 4:12:16.766 PM [0x0-0x2d02d].net.pms.PMS: 	at net.pms.PMS.init(PMS.java:423) [ums.jar:3.0.0]
5/5/13 4:12:16.766 PM [0x0-0x2d02d].net.pms.PMS: 	at net.pms.PMS.createInstance(PMS.java:968) [ums.jar:3.0.0]
5/5/13 4:12:16.766 PM [0x0-0x2d02d].net.pms.PMS: 	at net.pms.PMS.main(PMS.java:1060) [ums.jar:3.0.0
Optimus_prime
Post by Optimus_prime »
buccia,
Do me a favor and check this directory /Users/marco/Library/Application Support/UMS/ and see if this file, UMS.conf is in there. If not create this directory and place the file below in there and restart UMS. Let me know how it goes
UMS.conf
(33.52 KiB) Downloaded 1343 times
buccia
Post by buccia »
Hi Optimus,
it was the first thing I have checked, but it did not help :( !
I have saved the log but i think it is always more or less the same.
I attach also the file debug.log where it says:
Error killing old process java.io.FileNotFoundException: /Users/marco/Library/Application Support/UMS/data/pms.pid (No such file or directory)
Indeed i could not find any directory named /Users/marco/Library/Application Support/UMS/data
Ciao and thanks again
Marco
debug.log
(1.2 KiB) Downloaded 1562 times
debug.zip
(1.86 KiB) Downloaded 1433 times
suicidesamurai
Post by suicidesamurai »
I'd just like to add a comment regarding Buccia's issues. I was running OSX 10.7.5 with java versions 7u-17 and I also tried 7u-21. UMS 3.0.0 would not start at all. I was getting the same messages in the log that Buccia was getting.
I have just recently upgraded to OSX 10.8.3 and have java 7u17 installed and UMS is working fine. I don't know what fixed things but I can provide a log if need be.
Optimus_prime
This is the biggest problem i'm having, i know from other stuff on the internet (google) that java 7 app launcher has issues on Mac versions 10.7.x. i'm trying to isolate the issue and when i have a fix i will get it out. I think it has something to do with where main files are read in the directory for the java 7 launcher. Normally (10.8.x onwards unless some tells me otherwise) it will launch UMS from the .app/Contents/Java directory and read all the other files from the .app/Contents/Resource directory. But this maybe different in mac 10.7.x versions and i'm stuck for time due to work commitments. If you guys have any thoughts please share, i'm sorry for not trying to get a fix sooner but time is something i'm running out of atm (work pays the bills).
buccia
Post by buccia »
Dear Optimus if updating to 10.8 solves the issue, i have no problems to do it, let me know what you prefer i do. To run tests maybe it should be better to stick to 10.7 and solve the issue.
Ciao Marco
Optimus_prime
Marco, i think your right if you can stay at 10.7 for now and i'll try and come up with a fix in my free time tomorrow. Cheer's to all who have helped so far
Edit: Marco could you trash your /Users/<Username>/Application Support/UMS Folder for me and try and restart UMS. could you tell me the results. Sorry if you have already done this, trying to find simple fixes first
2ND Edit: It looks as though the JavaAppLauncher used in UMS (My custom built one, needed to run UMS on java 7) might, and i want to emphisize might, not have compiled to allow 10.7 compatible binaries. I will test and attempt to fix by tomorrow night my time (+10 GMT). Sorry it's taking time
3rd Edit: I've attempted to test and find the problem with not much success. Funny thing is i can replicate the issue on a 10.7 VMware image, even if UMS doesn't launch (due to a known 10.7 Java 7 VMware issue, not related to this issue) .
So until i can fix the problem or get a copy of 10.7 to run on my actual machine i might not have a fix. Any help or solutions would be great, sorry for the bad news :cry:
buccia
Post by buccia »
Dear Optimus, I have trashed the /Users/<Username>/Application Support/UMS folder but with no success. Actually that was the first thing I have tried before contacting you but to be sure i have done it once again...
Keep me posted on the developments.
Thanks a lot
Marco
Optimus_prime
Buccia, i still can't find the cause of the issue, like i said in my previous post i can replicate the issue but even if i populate the application support directory with all the correct data it still fails to work. Not sure what the issue is but what is the result of a uname -a on the terminal. could you post the result as id like to compare my VMmachine OS-X version to yours. Thanks but it may just have to be support for 10.8 for UMS 3.0 for now until i find a solution
Update: Well i've compiled a JavaAppLauncher on OS-X 10.7 thus eliminating if that was the cause. Not sure what the actual problem is now, so i'll keep working at it and hope i stumble upon the problem.
Update 2: Look's as i might have found the issue, i will attempt to fix and let you know how i go (Code issue, but specific to 10.7.X)
buccia
Post by buccia »
Hi Optimus,
this is the result of uname -a
iMac-di-Marco:~ marco$ uname -a
Darwin iMac-di-Marco.local 11.4.2 Darwin Kernel Version 11.4.2: Thu Aug 23 16:26:45 PDT 2012; root:xnu-1699.32.7~1/RELEASE_I386 i386
I hope it helps!
Ciao Marco
