[Solved] Service consuming lots of resources
Re: [Solved] Service consuming lots of resources
Thanks for letting us know. We are working on a fix now if it's that same bug. If you want to make sure it's the same bug, would you please try 10.6.0 and confirm that is the problematic version? Also logs would be good so we can see what the interaction is between your renderer and UMS
