Another Samsung thread "An error occurred"
Re: Another Samsung thread "An error occurred"
Here's a third one for fun
First try: DLNALocalizationRequired=true > symbol playable (grey) in TV-Menu > error "audio codec not supported" > playes file with no sound
Second try: DLNAOrgPN=true > symbol unplayable (pink) in TV-Menu > error "unexpected error"
third try: oncemore DLNALocalizationRequired=true > symbol unplayable (pink) in TV-Menu > error "unexpected error"
after that, i switch the two conf-files several times, but on each try "unexpected error"
i move all conf-files in an archiv-directory under \renderers, so there is only one the conf-file and .gitignore in majordirectory "renderers"
after all... i saw the the "fun-file"... > symbol unplayable (pink) in TV-Menu > error "unexpected error"
Do you need log files for each new configfile-test?
It would be great to get logs for the DLNALocalizationRequired one
so sorry, i dont have logs from the Thu Jan 20 post-trys, because it was a simple "work-dont work" test.
From now, i do every new conf-test in log-mode
Now:
- Clean new install UMS, only the "DLNALocalizationRequired" in \renderers
- switch off TV, switch off voltage, wait some minutes, switch on voltag, switch on TV
- test... but same result: symbol unplayable (pink) in TV-Menu > error "unexpected error"
thanks for your time...
Now:
anybody who has an idea to fix the problem?
