Version 4.4.0 is released
aey
Re: Version 4.4.0 is released
Post by aey »
aey wrote:Thanks for the release.
I tried the new H6400 conf file that supports the H6400 Samsung. The TV plays about 10 to 30 seconds of transcoded streaming Web source (apparently depending on resolution of the source) and stops. Local files that do not require streaming play OK.
Transcoded streams play great on older Samsung and Philips TVs. The problem exists with 4.3.1 and 5.0 as well.
Is this a problem with DLNA implementation on the TV? Has anyone experienced the same problem? Any ideas?
I solved the problem by changing ChunkedTransfer = true to ChunkedTransfer = false
Everything seems to work OK now.
