Constant 25% CPU usage even video not being played
Re: Constant 25% CPU usage even video not being played
Reason why I use BubbleUPNP is that I don't have to get up from couch to get next episode playing on TV. Can you do that with just with UMS? If you can, how?valib wrote:Yes I recommend to stop BubbleUPNP and try to use Chromecast. The Chromecast support is included in UMS since 4.0.0 UMS version.
OK please addNake wrote:Reason why I use BubbleUPNP is that I don't have to get up from couch to get next episode playing on TV. Can you do that with just with UMS? If you can, how?valib wrote:Yes I recommend to stop BubbleUPNP and try to use Chromecast. The Chromecast support is included in UMS since 4.0.0 UMS version.
chromecast_extension = falseRe: Constant 25% CPU usage even video not being played
I have problem with testing this. When I browse with BubbleUPNP app on my phone UMS folders via BubbleUPNP Server I don't see any video files. If I directly choose UMS folders I see files but none of them are able to play via Chromecast.
You can "bump" (i.e. push) any item from the web interface (available in your phone's web browser at <ums ip>:9001, e.g. 192.168.1.7:9001) to any controllable renderer, which includes chromecasts. See here.Nake wrote:Reason why I use BubbleUPNP is that I don't have to get up from couch to get next episode playing on TV. Can you do that with just with UMS? If you can, how?
