Need YAMAHA RX- A720 renderer
Re: Need YAMAHA RX- A720 renderer
1. I do clean install of UMSSami32 wrote:I guess that my weak english doesn't help as well![]()
Do you mean that when you delete the Yamaha renderer configuration file, you are able to play all your PC's music ? I still doesn't understand what you meanUnder 6.5.3, all music files work the render doesn't work
I'll look at your log for the web radio later, as i understood that it didn't work for you.
EDIT: Stop to post 2 times the same thing !
2 I copy my config and web files back to the correct directory
3 I copy the a720 config to the render folder.
What do you mean exactly by my config ? as by web file i think that your refering to web.conf file ?2 I copy my config and web files back to the correct directory
As a side note, i guess that you know that you are using an old 32-bit Java 7u75 version on your 64-bit Windows 7 OS ?
Yes I am refereeing to the UMS.config and the web.config. Those are the only files I restore back to the clean install. Yes I haven't updated java as of yet, I just keep as is for now .Does having the correct Java have anything to do with the performance of UMS?Sami32 wrote:What do you mean exactly by my config ? as by web file i think that your refering to web.conf file ?2 I copy my config and web files back to the correct directory
The default icon of this Yamaha renderer will only appear in the 6.6.0 UMS version, as it's a new one, but your renderer will work fine also without it.
No, i don't think so, i was searching the reason why your renderer icon didn't appear, and that make me look at your Java configuration.
EDIT: BTW, copy your ums.conf file in a clean UMS install is a bad idea that could give you issue.
Did you check the 7.0 logs?
Rapidly, but the 7.0.0a1 have the same base as the 6.5.3 version, not like the 6.6.0 version.
Are you saying I shouldn't copy my config files back to the C:\ProgramData\UMS after a clean install?Sami32 wrote:The default icon of this Yamaha renderer will only appear in the 6.6.0 UMS version, as it's a new one, but your renderer will work fine also without it.
I mean that you shouldn't copy your ums.conf file back to the C:\ProgramData\UMS after a clean install.
So what needs to be done if you want to keep your settings for UMS?
