Channels Plugin
Re: Channels Plugin
Hi SharkHunter, I tried to install Channels 2.22 (with the GUI) today on UMS 3.2.0, without success. I didn't get any actual channels and the plugin doesn't get listed as installed under "Installed plugins" in the GUI.
With earlier versions of UMS i've reported that UMS failed to start due to problems with PMSEncoder. Now this isn't a problem anymore, great!
What can I do to help with this installation problem?
Re: Channels Plugin
Alternatively: how can I help myself to get a clean install via the GUI?
Re: Channels Plugin
Is this plugin still under support ? Just curious wether to wait or move on. It would be great I could make it work.
- SharkHunter
- Developer
Re: Channels Plugin
Yes I still support it. But it might come as a surprise that I do have a life and work that needs attending to from time to time. What can I say I use Channels each day (more or less) so it works for me.
I'll look over it again during the weekend.
Re: Channels Plugin
Hi SharkHunter, I'm very graceful for your plugin (best in class) and do understand that you have to support us best effort!
I think there is some misstake now in the plugin data base. When trying PnP install in UMS 3.2.0 of Channels, I get the GroowShark plugin installed instead
. Unfortunately the reverse does not hold: I do not get Channels installed when asking for GroowShark
Pen
Pen
- SharkHunter
- Developer
Re: Channels Plugin
pen - have a look now. We did a change here on the website and there was a glitch in the transistion. See if it works better now...
Re: Channels Plugin
NopeSharkHunter wrote:pen - have a look now. We did a change here on the website and there was a glitch in the transistion. See if it works better now...
- SharkHunter
- Developer
Re: Channels Plugin
Weird I'll need to ask SJ to have a look
Re: Channels Plugin
ThanksSharkHunter wrote:Weird I'll need to ask SJ to have a look
- AlexanderGson
Re: Channels Plugin
Is the Visata.ch channel outdated? Neither TV3, TV6 or TV8 works for me contrary to all the other Swedish play channels which works perfectly.
When I go into the folders of them and into a letter it only shows "Add to favourite" instead of listing the shows for that letter.
And when I went to check on this site https://github.com/SharkHunter/Channel/ ... r/channels if there was an update it says the last update for viasat.ch was 9 months ago.
