Another Java Exception 2.2.0
bevster
Re: Another Java Exception 2.2.0
Post by bevster »
clean install, initially same problem, tsmuxer will not play the files at first. Once I transcode it briefly, then tsmuxer will work.
Then the usual error and it stops streaming so I switch to ffmpeg to finish the show. However, this time ffmpeg would not fast forward at all, normally it works fine. so i used mencoder to finish out the show.
Hope my logs help you with these errors.
thank you
(49.81 KiB) Downloaded 948 times
bevster
Post by bevster »
I uploaded the latest log as you requested :)
thanks and hope this helps
Thanks mate, I haven't forgotten, just juggling lots of things at the moment :) Should get to this soon
Ooo The Huntress from Arrow is my fave!
I just had a look through the logs and unfortunately I need a bit more info in them, can you please change the "Log level" to Trace before you start reproducing the bug, and use 2.6.1 please? Full instructions at viewtopic.php?f=9&t=556
bevster
Post by bevster »
ok problem reproduced with trace selected...
As a side note its weird that tsmuxer initially wont play anymore, just get a content cant be played type message on ps3, but once I transcode and then go back and try tsmuxer it will then work. strange.
thank you!
(128.38 KiB) Downloaded 1046 times
