[FIXED] Javaw.exe hangs after UMS quits
squadjot
Re: Javaw.exe hangs after UMS quits
Post by squadjot »
The problem is fixed if: i create a new user account and run UMS from that!
I remember solving other non-related problems before with this "trick" - highly recommended in desperate situations.
Anyways.. thats what i'm going for right now. YAY, back to debugging WD TV Live
Edit: I'm sure this could be fixed somehow.. atleast i know it's related to my account, but that's still a pretty broad spectrum of possibilities.. not up for it ^^
kuroukage
Post by kuroukage »
squadjot wrote:The problem is fixed if: i create a new user account and run UMS from that!
Does your original account have admin privileges?
Also, did you end up getting rid of that "casino.com" malware? Or whatever other viruses you might have had?
squadjot
Re: [SEMIFIXED] Javaw.exe hangs after UMS quits
Post by squadjot »
The original account has admin privileges yes.
The casino.com was my own fault (was messing with windows .hosts file, but had forgotten about it)
kuroukage
Post by kuroukage »
Did you try a fresh install of Windows again?
squadjot
Post by squadjot »
No, it's running as expected now under this new user.. (which has no administator rights)
But i will eventually ^^
kuroukage
Post by kuroukage »
So the was the only way to fix it? Was by creating a new user account? If so I'm guessing whatever malware you had was limited to that specific user account.
squadjot
Post by squadjot »
kuroukage wrote:So the was the only way to fix it? Was by creating a new user account? If so I'm guessing whatever malware you had was limited to that specific user account.
yea, and I'm not sure there is any malware..
Been running loads of virus/spy programs.. they found the usual cookies and stuff. + been running MSE from day one.
For now i leave it..it's running. =)
kuroukage
Post by kuroukage »
Yep, good to hear. Glad it's working well now. :)
Ah I see, glad the mystery of the casino.com malware was solved :D
It's interesting that the new account fixed it, very weird. I don't see how it can be related to UMS though since changing accounts wouldn't cause any differences in UMS.
*shrugs* glad it's fixed for you though!
kuroukage
Post by kuroukage »
Yeah, I'm also kinda confused as to why that fixed it. Unless some settings on his other account got messed up perhaps (by the malware).
