Channels Plugin
Re: Channels Plugin
Hi folks. First post, love the program. Decided to download the Channels Plugin and have some questions I haven't found the answers to elsewhere on here. I've also checked over at the PS3MediaServer forums and can't find anything really specific to my questions, so apologies in advance if this has been addressed.
I'm using OSX and the newest build of UMS as of 7/24/2012. I downloaded the Channels Plugin and tried to view some content. I was able to view some of the TruTV clips, but have had little luck elsewhere. I've scanned through the UMB.conf file and noticed this:
I am unsure if I know enough about the underpinnings of the software, but .exe files assume I'm running some sort of Windows based system. While those files do indeed exist on my system when I show the package contents, I fear they're not actually running based on the errors I am seeing in the traces.
That's just a small snippet of it.
So, I ask, what can I do here? I absolutely love this software. It's turned my PS3 into the heartbeat of my home entertainment system and I've been after this holy grail of self propagating streams I can turn to (in addition to some live feeds, but I won't be greedy right now).
Thanks for all your hard work on this.
-Dobbs
perl.path = extras\\perl\\bin\\perl.exe
python.path = extras\\Python27\\python.exe
rtmpdump.path = extras\\bin\\rtmpdump.exe
youtube-dl.path = extras\\bin\\youtube-dl.exe
ERROR 2012-07-24 19:16:17.231 [New I/O server worker #1-3] There is no inputstream to return for ESPN
INFO 2012-07-24 19:16:40.608 [New I/O server worker #1-1] Starting transcode/remux of PPV Ticket #1
ERROR 2012-07-24 19:16:41.057 [C:\rtmpdump.exe] Fatal error in process starting:
java.io.IOException: Cannot run program "C:\rtmpdump.exe": error=2, No such file or directory
at java.lang.ProcessBuilder.start(ProcessBuilder.java:460) ~[na:1.6.0_33]
at com.chocolatey.pmsencoder.PMSEncoderProcessWrapper.run(PMSEncoderProcessWrapper.java:89) ~[na:na]
Caused by: java.io.IOException: error=2, No such file or directory
at java.lang.UNIXProcess.forkAndExec(Native Method) ~[na:1.6.0_33]
at java.lang.UNIXProcess.<init>(UNIXProcess.java:53) ~[na:1.6.0_33]
at java.lang.ProcessImpl.start(ProcessImpl.java:91) ~[na:1.6.0_33]
at java.lang.ProcessBuilder.start(ProcessBuilder.java:453) ~[na:1.6.0_33]
... 1 common frames omitted
ERROR 2012-07-24 19:16:52.250 [New I/O server worker #1-1] There is no inputstream to return for PPV Ticket #1
INFO 2012-07-24 19:17:00.478 [New I/O server worker #1-3] Starting transcode/remux of Pentagon Channel
ERROR 2012-07-24 19:17:00.930 [C:\rtmpdump.exe] Fatal error in process starting:
-Dobbs
- SharkHunter
- Developer
Re: Channels Plugin
Dobbson - you're right the Channels installer is windows only (I'm working on linux right now). So It shouldn't work. That said your problem can be easy fixed.
Download a OSX rtmpdump (found here http://trick77.com/downloads/) put the binary in extras\bin and change to .
Probably curl should be installed as well (http://curl.haxx.se/download.html)
add
Perl and python are only used for some special channels so ignore them for now.
That should be it. If this works I can make an OSX version of the installer...
rtmpdump.path = extras\\bin\\rtmpdump.exeCode: Select all
rtmpdump.path = extras\\bin\\rtmpdumpProbably curl should be installed as well (http://curl.haxx.se/download.html)
add
curl.path=...That should be it. If this works I can make an OSX version of the installer...
Re: Channels Plugin
Sweet! Thanks. I'll give this a go tomorrow and report back.
Cheers.
-Dobbs
Cheers.
-Dobbs
Re: Channels Plugin
Hi!
I got a quick question about channel SVT. Is it broken or am I doing something wrong? The only think I find under the "letters" in the "Add to favourites"-task. No shows at all... I really like think plug in so do you thibbk it will be OK soon? Or can I do something?
I tried for example Tv3 and that works (by the way)
- SharkHunter
- Developer
Re: Channels Plugin
Which version of SVTPlay do you have? (it can be found in the traces tab). It should be 0.40 since SVT did a change a while ago. With it it works for me.schenne wrote:Hi!
Re: Channels Plugin
OK, I have curl installed and have put the rtmpdump in the appropriate directory and updated the config file. That much seems to be fine. However, any channel I try and play returns this error code:
Then, at one point, the server quit working altogether. Wouldn't show me any channels or my locally stored media files.
This content cannot be played.
(800288E1)
[size=85]ERROR 2012-07-25 18:26:05.596 [New I/O server worker #1-3] PMSEncoder: match error
org.codehaus.groovy.runtime.InvokerInvocationException: java.io.IOException: Cannot run program "TaskKill": error=2, No such file or directory
at org.codehaus.groovy.reflection.CachedMethod.invoke(CachedMethod.java:97) ~[na:na]
at groovy.lang.MetaMethod.doMethodInvoke(MetaMethod.java:233) ~[na:na]
at org.codehaus.groovy.runtime.metaclass.ClosureMetaClass.invokeMethod(ClosureMetaClass.java:273) ~[na:na]
at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:886) ~[na:na]
at groovy.lang.Closure.call(Closure.java:282) ~[na:na]
at groovy.lang.Closure.call(Closure.java:277) ~[na:na]
at com.chocolatey.pmsencoder.Profile.runActionBlock(Profile.groovy:70) ~[na:na]
at com.chocolatey.pmsencoder.Profile.match(Profile.groovy:114) ~[na:na]
at com.chocolatey.pmsencoder.Matcher$match$3$1.doCall(Matcher.groovy:47) ~[na:na]
at com.chocolatey.pmsencoder.Matcher$match$3$1.call(Matcher.groovy) ~[na:na]
at groovypp.util.Iterations.each(Iterations.groovy:98) ~[na:na]
at groovypp.util.Iterations.each(Iterations.groovy:154) ~[na:na]
at com.chocolatey.pmsencoder.Matcher$match$3.doCall(Matcher.groovy:46) ~[na:na]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.6.0_33]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) ~[na:1.6.0_33]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) ~[na:1.6.0_33]
at java.lang.reflect.Method.invoke(Method.java:597) ~[na:1.6.0_33]
at org.codehaus.groovy.reflection.CachedMethod.invoke(CachedMethod.java:90) ~[na:na]
at groovy.lang.Closure.call(Closure.java:295) ~[na:na]
at org.codehaus.groovy.runtime.DefaultGroovyMethods.each(DefaultGroovyMethods.java:1220) ~[na:na]
at org.codehaus.groovy.runtime.DefaultGroovyMethods.each(DefaultGroovyMethods.java:1196) ~[na:na]
at groovypp.util.Iterations.each(Iterations.groovy:280) ~[na:na]
at com.chocolatey.pmsencoder.Matcher.match(Matcher.groovy:45) ~[na:na]
at com.chocolatey.pmsencoder.Matcher.match(Matcher.groovy) ~[na:na]
at com.chocolatey.pmsencoder.Plugin.match(Plugin.groovy:254) ~[na:na]
at com.chocolatey.pmsencoder.PMSEncoder.launchTranscode(PMSEncoder.groovy:104) ~[na:na]
at net.pms.dlna.DLNAResource.getInputStream(DLNAResource.java:1568) [ums-1.4.0.jar:na]
at com.sharkhunter.channel.ChannelMediaStream.getInputStream(ChannelMediaStream.java:334) [tv_plug_190.jar:na]
at net.pms.network.RequestV2.answer(RequestV2.java:315) [ums-1.4.0.jar:na]
at net.pms.network.RequestHandlerV2.writeResponse(RequestHandlerV2.java:298) [ums-1.4.0.jar:na]
at net.pms.network.RequestHandlerV2.messageReceived(RequestHandlerV2.java:256) [ums-1.4.0.jar:na]
at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:80) [netty-3.2.4.Final.jar:na]
at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:545) [netty-3.2.4.Final.jar:na]
at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:754) [netty-3.2.4.Final.jar:na]
at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleUpstream(ChunkedWriteHandler.java:148) [netty-3.2.4.Final.jar:na]
at org.jboss.netty.handler.codec.http.HttpChunkAggregator.messageReceived(HttpChunkAggregator.java:116) [netty-3.2.4.Final.jar:na]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:302) [netty-3.2.4.Final.jar:na]
at org.jboss.netty.handler.codec.replay.ReplayingDecoder.unfoldAndfireMessageReceived(ReplayingDecoder.java:522) [netty-3.2.4.Final.jar:na]
at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:506) [netty-3.2.4.Final.jar:na]
at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:443) [netty-3.2.4.Final.jar:na]
at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:540) [netty-3.2.4.Final.jar:na]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:274) [netty-3.2.4.Final.jar:na]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:261) [netty-3.2.4.Final.jar:na]
at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:349) [netty-3.2.4.Final.jar:na]
at org.jboss.netty.channel.socket.nio.NioWorker.processSelectedKeys(NioWorker.java:280) [netty-3.2.4.Final.jar:na]
at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:200) [netty-3.2.4.Final.jar:na]
at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108) [netty-3.2.4.Final.jar:na]
at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:44) [netty-3.2.4.Final.jar:na]
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886) [na:1.6.0_33]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908) [na:1.6.0_33]
at java.lang.Thread.run(Thread.java:680) [na:1.6.0_33]
Caused by: java.io.IOException: Cannot run program "TaskKill": error=2, No such file or directory
at java.lang.Runtime.exec(Runtime.java:593) ~[na:1.6.0_33]
at java.lang.Runtime.exec(Runtime.java:431) ~[na:1.6.0_33]
at java.lang.Runtime.exec(Runtime.java:328) ~[na:1.6.0_33]
at org.codehaus.groovy.runtime.DefaultGroovyMethods.execute(DefaultGroovyMethods.java:8702) ~[na:na]
at org.codehaus.groovy.runtime.dgm$166.invoke(Unknown Source) ~[na:na]
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:270) ~[na:na]
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:52) ~[na:na]
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:40) ~[na:na]
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116) ~[na:na]
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:120) ~[na:na]
at putlocker$_run_closure1_closure2_closure4.doCall(putlocker.groovy:16) ~[na:na]
at org.codehaus.groovy.runtime.callsite.PogoMetaClassSite.callCurrent(PogoMetaClassSite.java:66) ~[na:na]
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCallCurrent(CallSiteArray.java:44) ~[na:na]
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:141) ~[na:na]
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:149) ~[na:na]
at putlocker$_run_closure1_closure2_closure4.doCall(putlocker.groovy) ~[na:na]
... 62 common frames omitted
... 91 common frames omitted
ERROR 2012-07-25 18:26:05.848 [null] Fatal error in process starting:
java.io.IOException: Cannot run program "null": error=2, No such file or directory
... 1 common frames omitted[/size]
- SharkHunter
- Developer
Re: Channels Plugin
Hmm, looks like some crash in pmsencoder. Maybe some script needs to be updated.
In the later releases of channels try adding and to your config file. (Make sure only one is in teh file as it cries otherwise).
This should "elimante" the use of pmsencoder....
channels.net_disc=trueCode: Select all
channels.mpeg2_force=trueCode: Select all
channels.mpeg2_force=trueThis should "elimante" the use of pmsencoder....
Re: Channels Plugin
Hello!
A newbe here, just installed UMS and through the program installed the plugin "Channels".
After that i created a file named svt.ch with the code from over here: https://github.com/SharkHunter/Channel/ ... r/channels
Now to my problem. Movies and music plays just fine, but the plugin Channels won't work. It shows up and im able to go into the "Svtplay" section choosing what i want to view. For example "Uppdrag Granskning".
The screen goes black, than an error pops up, translated to english it says something about the file beeing corrupted.
What can i do to fix this?
Thanks in advance!
Thanks in advance!
- SharkHunter
- Developer
Re: Channels Plugin
Send logs. read forums. You might have hit the folder limit if youre using a ps3. I looked ar svtpay today and it worked for me. Same code...Echelon wrote:Hello!
Thanks in advance!
Re: Channels Plugin
Thanks for the quick answer!SharkHunter wrote:Send logs. read forums. You might have hit the folder limit if youre using a ps3. I looked ar svtpay today and it worked for me. Same code...Echelon wrote:Hello!
Thanks in advance!
Here is the bottom of the traces log after just trying to watch SVTPlay, recieving the error: "Det finns skadade data" "There's corrupted data"
INFO 2012-07-28 21:40:04.593 [pool-7-thread-1] Checking IP: 192.168.1.101 for Playstation 3
INFO 2012-07-28 21:40:06.378 [main] The server should now appear on your renderer
INFO 2012-07-28 21:40:09.197 [pool-7-thread-1] Renderer Playstation 3 found on this address: 192.168.1.101
INFO 2012-07-28 21:40:10.321 [New I/O server worker #1-4] Node(com.sharkhunter.channel.Channels) already has an ID=0$6, which is overriden now. The previous parent node was:RootFolder[[MapFile [name=C, id=0$1, format=null, children=[]], MapFile [name=D:\ [Lokal disk], id=0$2, format=null, children=[]], MapFile [name=E:\ [Lagring], id=0$3, format=null, children=[]], MapFile [name=F, id=0$4, format=null, children=[]], VirtualFolder [id=5, name=Web, full path=0$5, ext=null, discovered=false]]]
INFO 2012-07-28 21:41:16.755 [New I/O server worker #1-1] Starting transcode/remux of Antikmagasinet - Del 1 av 12
INFO 2012-07-28 21:41:18.208 [cmd.exe] Process cmd.exe has a return code of 255! Maybe an error occured... check the log file
INFO 2012-07-28 21:41:23.278 [StartPlaying Event] renderer: 192.168.1.101, file: rtmpdump://channel?-r=rtmp%3A%2F%2Ffl11.c91005.cdn.qbrick.com%2F91005%2F_definst_%2Fwp3%2F1190204%2FANTIKMAGASINET-001A-mp4-e-v1-ecd5ef6d762f20c419454beb437c146b280a78ee.mp4&--swfVfy=http%3A%2F%2Fwww.svtplay.se%2Fpublic%2Fswf%2Fvideo%2Fsvtplayer-2012.15.swf
INFO 2012-07-28 21:41:27.280 [StopPlaying Event] renderer: 192.168.1.101, file: rtmpdump://channel?-r=rtmp%3A%2F%2Ffl11.c91005.cdn.qbrick.com%2F91005%2F_definst_%2Fwp3%2F1190204%2FANTIKMAGASINET-001A-mp4-e-v1-ecd5ef6d762f20c419454beb437c146b280a78ee.mp4&--swfVfy=http%3A%2F%2Fwww.svtplay.se%2Fpublic%2Fswf%2Fvideo%2Fsvtplayer-2012.15.swf
INFO 2012-07-28 21:41:42.122 [New I/O server worker #1-8] Starting transcode/remux of Morden i Midsomer - Del 2 av 2
INFO 2012-07-28 21:41:43.435 [cmd.exe] Process cmd.exe has a return code of 255! Maybe an error occured... check the log file
INFO 2012-07-28 21:41:48.564 [StartPlaying Event] renderer: 192.168.1.101, file: rtmpdump://channel?-r=rtmpe%3A%2F%2Ffl11.c90909.cdn.qbrick.com%2F90909%2F_definst_%2Fwp3%2F1283829%2FMIDSOMER_MURDER-002A-mp4-e-v1-d782388a3076138e.mp4&--swfVfy=http%3A%2F%2Fwww.svtplay.se%2Fpublic%2Fswf%2Fvideo%2Fsvtplayer-2012.15.swf
INFO 2012-07-28 21:41:52.564 [StopPlaying Event] renderer: 192.168.1.101, file: rtmpdump://channel?-r=rtmpe%3A%2F%2Ffl11.c90909.cdn.qbrick.com%2F90909%2F_definst_%2Fwp3%2F1283829%2FMIDSOMER_MURDER-002A-mp4-e-v1-d782388a3076138e.mp4&--swfVfy=http%3A%2F%2Fwww.svtplay.se%2Fpublic%2Fswf%2Fvideo%2Fsvtplayer-2012.15.swf
INFO 2012-07-28 21:46:40.897 [pool-7-thread-1] Renderer Playstation 3 found on this address: 192.168.1.101
DEBUG 2012-07-28 21:46:40.899 [pool-7-thread-1] Starting ping -n 3 -l 64000 192.168.1.101
DEBUG 2012-07-28 21:46:42.900 [SpeedStats Failsafe] Stopping process: ping-0
DEBUG 2012-07-28 21:46:49.553 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-07-28 21:47:02.573 [New I/O server worker #1-2] Caught exception
at com.sharkhunter.channel.ChannelMediaStream.updateStreamDetails(ChannelMediaStream.java:244) ~[na:na]
at com.sharkhunter.channel.ChannelMediaStream.scrape_i(ChannelMediaStream.java:303) ~[na:na]
at com.sharkhunter.channel.ChannelMediaStream.getInputStream(ChannelMediaStream.java:331) ~[na:na]
at net.pms.network.RequestV2.answer(RequestV2.java:315) ~[ums.jar:na]
at net.pms.network.RequestHandlerV2.writeResponse(RequestHandlerV2.java:298) ~[ums.jar:na]
at net.pms.network.RequestHandlerV2.messageReceived(RequestHandlerV2.java:256) ~[ums.jar:na]
at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleUpstream(ChunkedWriteHandler.java:148) ~[ums.jar:na]
at org.jboss.netty.handler.codec.http.HttpChunkAggregator.messageReceived(HttpChunkAggregator.java:116) ~[ums.jar:na]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:302) ~[ums.jar:na]
at org.jboss.netty.handler.codec.replay.ReplayingDecoder.unfoldAndfireMessageReceived(ReplayingDecoder.java:522) ~[ums.jar:na]
at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:506) ~[ums.jar:na]
at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:443) ~[ums.jar:na]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:274) ~[ums.jar:na]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:261) ~[ums.jar:na]
at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:349) ~[ums.jar:na]
at org.jboss.netty.channel.socket.nio.NioWorker.processSelectedKeys(NioWorker.java:280) ~[ums.jar:na]
at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:200) ~[ums.jar:na]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [na:1.7.0_05]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [na:1.7.0_05]
at java.lang.Thread.run(Unknown Source) [na:1.7.0_05]
INFO 2012-07-28 21:47:02.586 [New I/O server worker #1-3] Starting transcode/remux of OS i London: SVT24/KK
DEBUG 2012-07-28 21:47:02.588 [New I/O server worker #1-3] Creating pipe \\.\pipe\pmsencoder_transcoder_out_1343504822587_38
DEBUG 2012-07-28 21:47:02.591 [Thread-15] Waiting for pipe connection \\.\pipe\pmsencoder_transcoder_out_1343504822587_38
DEBUG 2012-07-28 21:47:02.864 [cmd.exe] Starting cmd.exe /C C:\rtmpdump.exe -o - -r "rtmp://fl10.c90807.cdn.qbrick.com/90807/webb5_360p live=1 swfVfy=1 swfUrl=http://www.svtplay.se/public/swf/video/svtplayer-2012.15.swf" | win32\ffmpeg.exe -v 0 -y -threads 4 -b 1024k -i - -threads 4 -target ntsc-dvd \\.\pipe\pmsencoder_transcoder_out_1343504822587_38
DEBUG 2012-07-28 21:47:02.865 [cmd.exe] Reading pipe: \\.\pipe\pmsencoder_transcoder_out_1343504822587_38
DEBUG 2012-07-28 21:47:02.957 [cmd.exe] Attaching thread: cmd.exe
INFO 2012-07-28 21:47:03.957 [cmd.exe] Process cmd.exe has a return code of 255! Maybe an error occured... check the log file
INFO 2012-07-28 21:47:09.065 [StartPlaying Event] renderer: 192.168.1.101, file: rtmpdump://channel?-r=rtmp%3A%2F%2Ffl10.c90807.cdn.qbrick.com%2F90807%2Fwebb5_360p&-v&--swfVfy=http%3A%2F%2Fwww.svtplay.se%2Fpublic%2Fswf%2Fvideo%2Fsvtplayer-2012.15.swf
DEBUG 2012-07-28 21:47:11.566 [Buffered IO End Checker] Stopping process: cmd.exe
INFO 2012-07-28 21:47:13.066 [StopPlaying Event] renderer: 192.168.1.101, file: rtmpdump://channel?-r=rtmp%3A%2F%2Ffl10.c90807.cdn.qbrick.com%2F90807%2Fwebb5_360p&-v&--swfVfy=http%3A%2F%2Fwww.svtplay.se%2Fpublic%2Fswf%2Fvideo%2Fsvtplayer-2012.15.swf
DEBUG 2012-07-28 21:47:15.274 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2012-07-28 21:47:37.656 [New I/O server worker #1-1] Retrieving http://www.svt.se/svts/article187824.svt/ALTERNATES/small/default_title
DEBUG 2012-07-28 21:47:39.959 [New I/O server worker #1-6] Caught exception
INFO 2012-07-28 21:47:39.971 [New I/O server worker #1-7] Starting transcode/remux of En idiot på resa - Del 7 av 8
DEBUG 2012-07-28 21:47:39.971 [New I/O server worker #1-7] Creating pipe \\.\pipe\pmsencoder_transcoder_out_1343504859971_41
DEBUG 2012-07-28 21:47:39.972 [Thread-20] Waiting for pipe connection \\.\pipe\pmsencoder_transcoder_out_1343504859971_41
DEBUG 2012-07-28 21:47:40.184 [cmd.exe] Starting cmd.exe /C C:\rtmpdump.exe -o - -r "rtmpe://fl11.c90909.cdn.qbrick.com/90909/_definst_/wp3/1155959/AN_IDIOT_ABROAD-007A-mp4-c-v1-7b904f0f5f5a3d7e.mp4 swfVfy=1 swfUrl=http://www.svtplay.se/public/swf/video/svtplayer-2012.15.swf" | win32\ffmpeg.exe -v 0 -y -threads 4 -b 1024k -i - -threads 4 -target ntsc-dvd \\.\pipe\pmsencoder_transcoder_out_1343504859971_41
DEBUG 2012-07-28 21:47:40.185 [cmd.exe] Reading pipe: \\.\pipe\pmsencoder_transcoder_out_1343504859971_41
DEBUG 2012-07-28 21:47:40.250 [cmd.exe] Attaching thread: cmd.exe
INFO 2012-07-28 21:47:41.250 [cmd.exe] Process cmd.exe has a return code of 255! Maybe an error occured... check the log file
INFO 2012-07-28 21:47:46.384 [StartPlaying Event] renderer: 192.168.1.101, file: rtmpdump://channel?-r=rtmpe%3A%2F%2Ffl11.c90909.cdn.qbrick.com%2F90909%2F_definst_%2Fwp3%2F1155959%2FAN_IDIOT_ABROAD-007A-mp4-c-v1-7b904f0f5f5a3d7e.mp4&--swfVfy=http%3A%2F%2Fwww.svtplay.se%2Fpublic%2Fswf%2Fvideo%2Fsvtplayer-2012.15.swf
DEBUG 2012-07-28 21:47:48.885 [Buffered IO End Checker] Stopping process: cmd.exe
INFO 2012-07-28 21:47:50.386 [StopPlaying Event] renderer: 192.168.1.101, file: rtmpdump://channel?-r=rtmpe%3A%2F%2Ffl11.c90909.cdn.qbrick.com%2F90909%2F_definst_%2Fwp3%2F1155959%2FAN_IDIOT_ABROAD-007A-mp4-c-v1-7b904f0f5f5a3d7e.mp4&--swfVfy=http%3A%2F%2Fwww.svtplay.se%2Fpublic%2Fswf%2Fvideo%2Fsvtplayer-2012.15.swf
INFO 2012-07-28 21:48:40.077 [AWT-EventQueue-0] Configuration saved to: C:\ProgramData\UMS\UMS.conf
DEBUG 2012-07-28 21:50:19.576 [UPNP-AliveMessageSender] Sending ALIVE...
