Videos defualt to mpeg not AVC UMS 6.60 ps3
jp0213x
Re: Videos defualt to mpeg not AVC UMS 6.60 ps3
Post by jp0213x »
And this?
jp0213x
Post by jp0213x »
Ok here are the new logs, the subs worked under AVC. I noticed disabling subs then resuming video under AVC, throws the video out of sync. Is there any way to get 6.60 to detect the correct engine when it plays sub related videos? As I already know AVC isn't good with subs. ffmeg works better when resuming and disabling subs I found on 5.13
Sami32
Post by Sami32 »
Yes. Have a try and post your new log, thanks.
But the GUI don't give the "Defer to MEncoder" same infos, that strange. But never mind, try it and i will see in your new log.
jp0213x
Post by jp0213x »
The new logs are above.
Sami32
Post by Sami32 »
Sorry, our posts "crossed".
I have difficulty to understand you. What you call "AVC", or H.264, have nothing to do with subtitles support but anyway, i'll check your log.
1) "AVC" ==> solved
2) Subtitles display ==> solved
3) Out of sync after resume ==>
jp0213x
Post by jp0213x »
Sami32 wrote:Yes. Have a try and post your new log, thanks.
I will reinstall the application with fresh config.
jp0213x
Post by jp0213x »
Sami32 wrote:Sorry, our posts "crossed".
1) "AVC" ==> solved
My goal here is to get UMS 6.60 to play the same way 5.1.3 does. Would you like me to post logs from 5.13 also?
jp0213x
Post by jp0213x »
Sami32 wrote:OK.
I post a new UMS.conf file to try:
UMS.conf
Here are the logs with the your new config. Video stopped working.
Sami32
Post by Sami32 »
Try that one:
UMS.conf
(38.9 KiB) Downloaded 996 times
Don't forget to select your subtitle font as already explained before.
It's seem that MEncoder is used, also when i totally disabled it. So i guess that trigerring is done for text subtitles, except ASS/SSA, because it's hardcoded. I never checked about that, and though that it was possible to override manually. It seem that i was wrong.
