Can't get the Pogram to Detect any Renderers
Re: Can't get the Pogram to Detect any Renderers
Another long shot.
I'm not sure if it does help or if it is a good thing to do, as I am no Xbox expert.
But usually it is a good idea of having the latest firmware update of your game console installed.
Did you already checked that and tested with the latest version?
well about that all I know is Xbox tells you if an update is out or not because it gives you a message that says you can upade the Xbox & that is the only way Microsoft did it no other way to update the XboxSpeedyQ wrote:Another long shot.
So i was finally able to test this MP3 issue and too have found that they do not play from both the System Video player or from System Music Player.
below are the logs:
https://dl.dropboxusercontent.com/u/266 ... 0.0-a4.zip
below are the logs:
Universal Media Server Wiki!
I have looked at what I think is the important part in the log; UMS analyses the file as mp3 and the characteristics within but does not seem to select the right engine to start playback.DeFlanko wrote:So i was finally able to test this MP3 issue and too have found that they do not play from both the System Video player or from System Music Player.
below are the logs:
So is it a UMS issue after all that has never been tested before with Xbox?
I have highlighted the part in the log (because the log file is huge):
013-08-26 17:54:44.927 [New I/O worker #2] Opened request handler on socket /172.10.1.40:54543
TRACE 2013-08-26 17:54:44.927 [New I/O worker #2] Request: HTTP/1.1 : POST : upnp/control/content_directory
TRACE 2013-08-26 17:54:44.927 [New I/O worker #2] Matched media renderer "Xbox 360" based on address /172.10.1.40
TRACE 2013-08-26 17:54:44.927 [New I/O worker #2] Received on socket: Connection: Keep-alive
TRACE 2013-08-26 17:54:44.927 [New I/O worker #2] Received on socket: Content-Length: 582
TRACE 2013-08-26 17:54:44.927 [New I/O worker #2] Received on socket: CONTENT-TYPE: text/xml; charset="utf-8"
TRACE 2013-08-26 17:54:44.927 [New I/O worker #2] Received on socket: Host: 172.10.1.10:1337
TRACE 2013-08-26 17:54:44.927 [New I/O worker #2] Received on socket: SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
TRACE 2013-08-26 17:54:44.927 [New I/O worker #2] Received on socket: User-Agent: Xbox/2.0.16537.0 UPnP/1.0 Xbox/2.0.16537.0
TRACE 2013-08-26 17:54:44.927 [New I/O worker #2] Recognized media renderer: Xbox 360
TRACE 2013-08-26 17:54:44.927 [New I/O worker #2] HTTP: upnp/control/content_directory / 0-0
TRACE 2013-08-26 17:54:44.927 [New I/O worker #2] discover 0 refresh forced: false
TRACE 2013-08-26 17:54:44.927 [New I/O worker #2] discover 0$1 refresh forced: false
TRACE 2013-08-26 17:54:44.927 [New I/O worker #2] discover 0$1$7 refresh forced: true
TRACE 2013-08-26 17:54:44.927 [New I/O worker #2] Matched format MP3 to "06-sub_focus-rock_it.mp3"
TRACE 2013-08-26 17:54:44.927 [New I/O worker #2] Matched format JPG to "des and jimi wedding.jpg"
DEBUG 2013-08-26 17:54:44.927 [New I/O worker #2] File automatically removed: Inglourious_Bastards.mkv
DEBUG 2013-08-26 17:54:44.927 [New I/O worker #2] File automatically added: 06-sub_focus-rock_it.mp3
DEBUG 2013-08-26 17:54:44.927 [New I/O worker #2] File automatically added: des and jimi wedding.jpg
TRACE 2013-08-26 17:54:44.927 [New I/O worker #2] Matched format MP3 to "E:\Media\Movies\TEST\06-sub_focus-rock_it.mp3"
TRACE 2013-08-26 17:54:44.989 [New I/O worker #2] Parsing results: 06-sub_focus-rock_it.mp3 / container: mp3 / bitrate: 200778 / size: 6908959 / codecV: und / duration: 00:04:35.00 / width: 0 / height: 0 / frameRate: null / thumb size : 0 / muxingMode: null
audio: id=0 / lang: en / flavor: null / codec: mp3 / sf:44100 / na: 2 / bs: 16 / Sub Focus|Sub Focus|Rock It|2009|6
TRACE 2013-08-26 17:54:44.989 [New I/O worker #2] Adding 06-sub_focus-rock_it.mp3 / class: net.pms.dlna.RealFile
TRACE 2013-08-26 17:54:44.989 [New I/O worker #2] Getting player for 06-sub_focus-rock_it.mp3
TRACE 2013-08-26 17:54:44.989 [New I/O worker #2] player: MEncoder, enabled: true, compatible: false
TRACE 2013-08-26 17:54:44.989 [New I/O worker #2] AviSynth/MEncoder cannot determine compatibility based on audio track for E:\Media\Movies\TEST\06-sub_focus-rock_it.mp3
TRACE 2013-08-26 17:54:44.989 [New I/O worker #2] player: AviSynth/MEncoder, enabled: true, compatible: false
TRACE 2013-08-26 17:54:44.989 [New I/O worker #2] tsMuxeR cannot determine compatibility based on audio track for E:\Media\Movies\TEST\06-sub_focus-rock_it.mp3
TRACE 2013-08-26 17:54:44.989 [New I/O worker #2] player: tsMuxeR, enabled: true, compatible: false
TRACE 2013-08-26 17:54:44.989 [New I/O worker #2] player: FFmpeg, enabled: true, compatible: false
TRACE 2013-08-26 17:54:44.989 [New I/O worker #2] player: FFmpeg Audio, enabled: true, compatible: false
TRACE 2013-08-26 17:54:44.989 [New I/O worker #2] player: Audio High Fidelity, enabled: true, compatible: false
TRACE 2013-08-26 17:54:44.989 [New I/O worker #2] player: FFmpeg Web Video, enabled: true, compatible: false
TRACE 2013-08-26 17:54:44.989 [New I/O worker #2] player: VLC Web Video, enabled: true, compatible: false
TRACE 2013-08-26 17:54:44.989 [New I/O worker #2] player: VLC Web Video (Legacy), enabled: true, compatible: false
TRACE 2013-08-26 17:54:44.989 [New I/O worker #2] player: MEncoder Web, enabled: true, compatible: false
TRACE 2013-08-26 17:54:44.989 [New I/O worker #2] player: VLC Web Audio (Legacy), enabled: true, compatible: false
TRACE 2013-08-26 17:54:44.989 [New I/O worker #2] player: FFmpeg DVR-MS Remux, enabled: true, compatible: false
TRACE 2013-08-26 17:54:44.989 [New I/O worker #2] player: dcraw Thumbnailer, enabled: true, compatible: false
TRACE 2013-08-26 17:54:44.989 [New I/O worker #2] player: AviSynth/FFmpeg, enabled: false
TRACE 2013-08-26 17:54:44.989 [New I/O worker #2] player: VLC, enabled: false
TRACE 2013-08-26 17:54:44.989 [New I/O worker #2] no player found for 06-sub_focus-rock_it.mp3
well I just found out Sunday & Monday what you had to have to play music streaming it from the computer to the Xbox you had to have Windows Media Player or Windows Media Center & that is the only way to stream music
No im sure there is a way...there is ALWAYS a way..
Please keep in mind that the first player i tired using was the Video player... so it might have failed because it was looking for a video container in the mp3.
But when i went to the Music player it couldn't find ANYTHING.
I was wondering if this issue was ever fixed? I'm having the EXACT same problem with my XBOX 360.
