TsMuxer Quit Unexpectedly.
MikeRichardson
Post by MikeRichardson »
Zip with TRACE will be attached.
Process: tsMuxeR [68774]
Path: /Applications/Universal Media Server.app/Contents/Resources/osx/tsMuxeR
Identifier: tsMuxeR
Version: ???
Code Type: X86 (Native)
Parent Process: UMS [68755]
Responsible: tsMuxeR [68774]
User ID: 501
Date/Time: 2018-05-11 06:08:15.157 -0500
OS Version: Mac OS X 10.12.6 (16G29)
Report Version: 12
Anonymous UUID: 3F36E961-8A9E-9249-7983-022CCD8AE082
Time Awake Since Boot: 850000 seconds
System Integrity Protection: disabled
Crashed Thread: Unknown
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000241499f5
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [0]
Backtrace not available
Unknown thread crashed with X86 Thread State (32-bit):
eax: 0x248b8b5b ebx: 0xbffffb1c ecx: 0x241499f5 edx: 0x00000001
edi: 0xbffffb64 esi: 0x00000000 ebp: 0xbffffad8 esp: 0xbffffa90
ss: 0x00000023 efl: 0x00010297 eip: 0x000011bb cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
cr2: 0x241499f5
Logical CPU: 2
Error Code: 0x00000004
Trap Number: 14
Binary images description not available
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 11594585
thread_create: 0
thread_set_state: 0
Model: MacPro5,1, BootROM MP51.007F.B03, 4 processors, Quad-Core Intel Xeon, 2.8 GHz, 10 GB, SMC 1.39f11
Graphics: ATI Radeon HD 5770, ATI Radeon HD 5770, PCIe, 1024 MB
Memory Module: DIMM 1, 4 GB, DDR3 ECC, 1066 MHz, 0x014F, 0x54533531324D4C4B37325633482020202020
Memory Module: DIMM 2, 4 GB, DDR3 ECC, 1066 MHz, 0x0198, 0x393936353431332D3030362E4130304C4620
Memory Module: DIMM 3, 1 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54313132553754465238432D48392020
Memory Module: DIMM 4, 1 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54313132553754465238432D48392020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.106.98.100.26)
Bluetooth: Version 5.0.5f1, 3 services, 27 devices, 1 incoming serial ports
Network Service: Ethernet 2, Ethernet, en1
Network Service: Ethernet 3, Ethernet, en1
PCI Card: ATI Radeon HD 5770, Display Controller, Slot-1
PCI Card: PXS4, USB eXtensible Host Controller, Slot-4
Serial ATA Device: HL-DT-ST BD-RE WH16NS40
Serial ATA Device: TSSTcorp DVDWBD SH-B123L
Serial ATA Device: Hitachi HUA723020ALA641, 2 TB
Serial ATA Device: CT240BX200SSD1, 240.06 GB
Serial ATA Device: WDC WD1001FALS-41Y6A0, 1 TB
USB Device: USB 2.0 Bus
USB Device: USB Bus
USB Device: USB Bus
USB Device: USB Bus
USB Device: USB Bus
USB Device: BRCM2046 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB Bus
USB Device: USB Bus
USB Device: Macally iKey
USB Device: USB OPTICAL MOUSE
USB Device: USB 3.0 Bus
USB Device: Expansion Desk
FireWire Device: built-in_hub, Up to 800 Mb/sec
Thunderbolt Bus:
MikeRichardson
Re: TsMuxer Quit Unexpectedly.
Well I could not attach the zip file...
Some of the debug files mentioned, umm, some files for adults only, even though I deleted all those libraries, and my issue is with some, non-adults files.
Why is UMS referencing libraries I deleted?
Anyway this problem is with Roseanne S10E06 and E07, maybe someone knows if those are just bad files.
I can reproduce the crash, just someone tell me how to get UMS to stop referencing these other files. I only have one folder shared called MEDIASHARE and all it has is a few TV episodes. All other shares are deleted, yet, I can see in the debug logs UMS is still trying to reference other videos. I completely removed that hard drive but it still tries to reference the files.
When making the debug files, create a new folder and put a copy of the problematic file(s) there. Then configure UMS to only share this folder and restart UMS.
MikeRichardson
I deleted every single shared folder, and then I restarted UMS.
Here is an example of a line that I get in the debug log even though this folder is not shared and the volume does not even exist anymore on the computer. (names are redacted)
DEBUG 2018-05-11 06:24:28.676 [main] master is internal:net.pms.dlna.RealFile str 40.wmv>/Volumes/NOT_FOR_KIDS/ADULTS_ONLY/40.wmv
Anyway if we can fix that (it seems like another bug) then I will upload the full logs about Roseanne, it is a reproducable bug when resuming.
Yes, the clue is to use new shared folder, because UMS has cached information about your existing folders. You must specify at least one shared folder, or UMS will share your entire harddisk :!:
MikeRichardson
Nadahar wrote: ↑Fri May 11, 2018 11:28 pm Yes, the clue is to use new shared folder, because UMS has cached information about your existing folders. You must specify at least one shared folder, or UMS will share your entire harddisk :!:
Yes, I just saw that!!!
Maybe have a warning for that! Fortunately I only allowed a single IP to access the share.
I deleted all the folders. I added one single folder to share, that only has very few files in it.
Yet STILL in the debug log I see these lines:
DEBUG 2018-05-11 07:16:27.192 [main] master is internal:net.pms.dlna.RealFile str 39.wmv>/Volumes/REMOVED
NOTHING under Volumes is shared. The only folder shared is /Users/mike/Desktop/MEDIASHARE_2/
Why is it touching these files under /Volumes/ that are not shared and do not exist?
How do I fully reset 100%? This seems like a bug.
If I quit and restart UMS, it will still try to touch these files.
I've never seen that behaviour before, but I haven't been a part of the "7.0.0 changes" so I guess this comes from that code then. You should be able to delete everything in the database by clicking "Reset cache/database" on the Navigation/Share tab if my memory servces me correct. After resetting the database, restart UMS. If that doesn't work I'm as clueless as you.
