UMS worked on PS4 last night, today won't work
ultrasuperman
Post by ultrasuperman »
I don't know what changed, yesterday it worked great today the PS4 just can't find UMS. I disabled the firewall in my router and UMS is on the Mcafee allow programs list, I also have a Windows 10 PC.
(170.96 KiB) Downloaded 450 times
Re: UMS worked on PS4 last night, today won't work
Do NOT disable the firewall on the router. Disable the Windows firewall on the computer running UMS.
valib
Post by valib »
@ultrasuperman do you run WIN 10 in the virtual mode using VMware? If not check the adapter the UMS choosen
Using address /192.168.117.1 found on network interface: name:eth2 (VMware Virtual Ethernet Adapter for VMnet8)
