UMS 7.1.0 No Window on macOS High Sierra 10.13.6
ekrogh
Post by ekrogh »
Hi
I just downloaded and started UMS 7.1.0 on my MacBook Pro w. macOS High Sierra 10.13.6.
The windows:
"Select language", "Should UMS start minimized?", "Which of the following best describes your network?", "Should UMS hide its advanced options? They can be enabled later" and "Finally, choose a folder to share. You can choose more later on the Navigation/Share Settings tab.
If you don't choose a folder, we'll choose a default based on your operating system."
pops up OK and I select the default blue choises, BUT when I click OK in the last window the only thing that happens is that "Universal Media Server" shows in the menu. No window shows where I can select folders to share and nowhere can I make a log.
xxx$ java -version
java version "1.8.0_131"
Java(TM) SE Runtime Environment (build 1.8.0_131-b11)
Java HotSpot(TM) 64-Bit Server VM (build 25.131-b11, mixed mode)
(Tried with java 8 also, no difference).
What can I do to solve the problem ?
best regards,
Eigil
FlorenceGee
Re: UMS 7.1.0 No Window on macOS High Sierra 10.13.6
Post by FlorenceGee »
I have the same issue..
BigHanks
Post by BigHanks »
Same problem with 7.2.1. Asked the opening 4 questions. No window, can't do anything.
Hi guys, please test this file and let me know if it works:
http://www.spirton.com/uploads/UMS/UMS- ... lity-2.dmg
SoapJohnson
Post by SoapJohnson »
Hey guys,
I was having the same issues with the questions popping up, but not the rest of the app.
Can confirm that this fixed it for me.
Thanks for confirming, SoapJohnson. We will release this fix soon.
