[Solved] VLC-for-desktop.conf
jps92
Post by jps92 »
I think that is missing the line "Supported = f:mp3 m:audio/mp3" in "# Audio formats supported:"
because it is not possible to read all mp3 files and "Supported = f:ogg m:audio/ogg" instead of "Supported = f:oga m:audio/ogg"
Thank you for the modification.
Re: VLC-for-desktop.conf
The ogg thing is a bit tricky since that container can be video or audio or both. The best idea for compatibility with ogg is to use oga for audio-only ogg files. The mp3 change will be in the next version
