Can't launch UMS
atamariya
Re: Can't launch UMS
Post by atamariya »
Go to the installation directory using command line and try launching the JAR directly.
java -jar ums-6.7.5-SNAPSHOT-jar-with-dependencies.jar
You can paste the output here for further troubleshooting.
atamariya
Post by atamariya »
Trippitaka wrote: ↑Tue Jan 08, 2019 6:26 pm Thanks for the reply, but I really don't know what that means. Are you saying I should open a Command prompt?
Yes.
