UMS does not start anymore on Windows Server 2016
Re: UMS does not start anymore on Windows Server 2016
Windows Media Player has never worked properly with UMS. There is some technical issue, if I recall correctly WMP requires that the server supports "search" but UMS doesn't. You should try using a "real" renderer, or if you must use a software renderer, try VLC or Kodi.
