Massive desktop stutter when UMS is doing nothing but idling
Re: Massive desktop stutter when UMS is doing nothing but idling
It certainly isn't your hardware :D A very nice, and expensive, setup - but why would you run a crippled "home edition" of Windows on such a rig?
Anyway, to the point, this is clearly a bug with UMS. I'm not sure what exactly, but there are many potential issues that could "hold control" over the screen drawing process for too long without it being a lack of "available performance". I haven't tested the later versions of UMS since they are so full of bugs, but I don't think I've ever heard this one before. There's one potential issue I can think of, and that is if you're running "trace" logging and there's a lot going on in your log so that the "Log" tab in UMS gets very busy scrolling through thousands of lines. If this is the case, try to set the "log level" to "info" and see if it makes a difference.
I don't remember all the sabotage Microsoft has done to the "home" editions, but I know it's a lot - and it's not always documented. The thing is that these "editions" are all fake, the reality is that the "pro" version is what was previously known just as Windows. The "home" editions run on the same codebase, but they have made a number of modifications to block access to various parts of the system. This is what I call "sabotage". It's not that it simply doesn't have "all the features" of the "pro" version, it's that things have been intentionally sabotaged.
As an example, take file permissions. It's not like "home" editions doesn't have file permissions, they are a fundamental part of NTFS and thus Windows. But, to sabotage, they have removed all access to change or view file permissions. I guess the idea is that the "home" user doesn't need permissions. The problem is though, that some times other software or Windows itself fucks up the file permissions so that you have to change them to solve a problem. With home edition you then have to restart in safe mode (because there you can actually access them...!), make the changes and then reboot again. Then you can see if it solved the problem... and rinse and repeat until you go crazy or solves the problem, whatever comes first.
There's also the lack of remote desktop capability (which has been there since Windows 2000, but was removed when they invented the "home" editions). In addition I seem to remember that you have to log in with a "Microsoft account" (online account, instead of a local) on Win 10 home. If that is correct, it means that they will track everything you do.
I also think they have severely crippled the network capabilities, but since I don't have any "home" editions I can't really check.
I have been burned by the "home" editions when trying to help others, but I don't remember all the details. My main objection is that it's not a "basic system" that simply lacks "pro" features, it's an edition where they have created limitations on top. That leads to some really bad situations, so I won't get anywhere near it.
It was just a comment though, I just thought the contrast between what you have spent on hardware and the small difference in the software cost was "strange" ;) From what I can see, the difference in the price for the OEM versions is around $50. Don't get me wrong, I think it's a rip off that Windows cost that much in the first place, but in the big picture I wouldn't risk potential frustrations to save $50 on such a rig ;)
Ok, it was just my initial reaction when I saw you specs, no big deal. If permissions are back in the "home" version of Windows that's very good, but it used to be hidden in previous versions at least. I'm sure there are other similar caveats though, but since I'm keeping clear of both Windows 10 and the "home" editions I don't know what they are ;)
That said, I use remote desktop many times a day and don't quite know how people do without it. It is miles better than any other remote-control feature that I've tried, VNC and everything built on it or similar principles simply has way too much latency for me to be useful for anything than short sessions.
