Configure to ignore RAW image files
HimAgain
Post by HimAgain »
Is it possible to configure to ignore RAW image files?
I keep my RAW images which have file type .RW2 together with the JPEGs developed therefrom in the same folders. When I stream to my TV to view the photos as a slideshow, I get repeated images. The JPGs are cropped and edited as I want but the RAW images are un-cropped and crudely rendered by the Samsung TV. The RAW files are much larger 20+mb and take longer to appear on screen.
I would like to optionally exclude these file types. I should like to avoid separating the JPGs from the RAW because my backups are working well as is and all the photo management programs are working well as is (Digikam, Darktable and Geeqie).
