No seek on any renderer or for any file type
magic_ninja
So I've always had issues with seek not working on some files. It is to be expected. I created a format with handbrake that my Samsung UN66FH6200 will be able to play and seek with. When I do run into an issue, I just transcode the file. Now, I can't seek at all. I have no clue what is going on here. I have attached the debug logs per the "How to ask for support" post.
- ums_dbg_2021-07-17-12-05.zip
- (904.72 KiB) Downloaded 178 times
Re: No seek on any renderer or for any file type
Looks like all your videos are transcoded and there is no checking to see if they are compatible with your TV.
There is an error Unable to load library 'mediainfo' and this is used to check for supported formats.
Is Mediainfo installed? I know nothing about Linux so I don't know how you go about installing it but I'm sure there are other posts in the Linus section that mention that.
From my experience with my TV (F series), Samsung TVs are bad with transcoded videos as they use seek-by-byte instead of seek-by-time, so the FF and RWD controls will be disabled.
also I recently found that even for streamed videos these can be disabled, and only work if playing directly from a usb drive. But it is possible to jump to a specific time with supported formats using the well hidden option in menu with the magnifying glass icon, or by using an external controller like BubbleUPnP
ERROR 2021-07-17 12:02:20.116 [main] net.pms.dlna.MediaInfo Error loading MediaInfo library: Unable to load library 'mediainfo':
libmediainfo.so: cannot open shared object file: No such file or directory
Native library (linux-x86-64/libmediainfo.so) not found in resource path ([file:/home/sparkie/Software/UMS/ums-10.7.0/update.jar, file:/home/sparkie/Software/UMS/ums-10.7.0/ums.jar])From my experience with my TV (F series), Samsung TVs are bad with transcoded videos as they use seek-by-byte instead of seek-by-time, so the FF and RWD controls will be disabled.
magic_ninja
Thank you. That did fix the issue. It seems that the TV is old enough that I have a couple options. I can either get a new HLDNA client that can play more types of files, get a new TV, or re-encode everything, because this TV doesn't seem to like to play any mkv files.
Thank you for the update and this solved the issue. I also had to install tsMuxeR and DCRaw.
