Adding a cctv nvr
Adding a cctv nvr
Hi is there a way I can add a cctv nvr to UMS? The recorder is on the same network as UMS all I want to do is view the screen with the images on it, I am completely new to UMS so unfortunately would need step by step if this is possible?
Re: Adding a cctv nvr
Hi jay,
It might work if you were able to get the cctv nvr to expose a web stream, then you could add that web stream to UMS on the Shared Content tab. Or maybe you can find a tool that can take that nvr output and make a web stream.
