Files not showing up
Krozk
Post by Krozk »
I have been using UMS for about a year and I have been loving it, so first of all congrats to some very fine work. :)
Now, I reinstalled my OS (Windows 7) last night and now I'm trying to get UMS working again. It shows up fine on the TV, I can browse every folder but there seems to be no files in the folders even thought that is not the case. The files in question are .avi
I can't seem to figure out why I doesn't work.
Since there is no real bug or error happening, I found it quite hard to attach any useful logs.
Krozk
Re: Files not showing up
Post by Krozk »
.mkv files are showing up just fine, but the .avi files are still nowhere to be found.
SharkHunter
Post by SharkHunter »
Upload the logs anyway. Make sure you follow the guidelines. Even if you don't think there are meaningful info in there there still might be for us.
Krozk
Post by Krozk »
Okay, I apologize for not following the guidelines.
However, after some time I resolved the issue. Navigation -> Virtual folders/ files -> Uncheck hide filetypes
Gareee
Post by Gareee »
I don't see any option for hide filetypes.. do you mean hide file extensions?
