Connect to Philips Wireless Speakers [SOLVED]
I'm trying to use a Philips A3 wireless speaker (AW3000/10) as a renderer but can't seem to get it work.
In the trace-Log, it shows up with the IP-adress, but that's it:
Is there anyone who has experience with those wireless devices? Any hint would be appreciated, thanks a lot.
Nothing else even indicates that the devices communicate.TRACE 2014-07-01 19:26:24.815 [UPNPHelper] Receiving a NOTIFY from [192.168.2.185:37969]
TRACE 2014-07-01 19:26:24.820 [UPNPHelper] Receiving a NOTIFY from [192.168.2.185:54221]
TRACE 2014-07-01 19:26:24.829 [UPNPHelper] Receiving a NOTIFY from [192.168.2.185:54221]
TRACE 2014-07-01 19:26:24.836 [UPNPHelper] Receiving a NOTIFY from [192.168.2.185:54221]
TRACE 2014-07-01 19:26:24.842 [UPNPHelper] Receiving a NOTIFY from [192.168.2.185:53146]
TRACE 2014-07-01 19:26:24.868 [UPNPHelper] Receiving a NOTIFY from [192.168.2.185:50341]
TRACE 2014-07-01 19:26:24.872 [UPNPHelper] Receiving a NOTIFY from [192.168.2.185:59880]
TRACE 2014-07-01 19:26:25.597 [UPNPHelper] Receiving a NOTIFY from [192.168.2.185:44308]
TRACE 2014-07-01 19:26:25.601 [UPNPHelper] Receiving a NOTIFY from [192.168.2.185:44308]
TRACE 2014-07-01 19:26:25.604 [UPNPHelper] Receiving a NOTIFY from [192.168.2.185:44308]
TRACE 2014-07-01 19:26:25.611 [UPNPHelper] Receiving a NOTIFY from [192.168.2.185:42857]
TRACE 2014-07-01 19:26:25.615 [UPNPHelper] Receiving a NOTIFY from [192.168.2.185:38318]
TRACE 2014-07-01 19:26:25.619 [UPNPHelper] Receiving a NOTIFY from [192.168.2.185:39050]
Re: Connect to Philips Wireless Speakers
It was the desktop firewall...
sorry for being such a newb
- Optimus_prime
Re: Connect to Philips Wireless Speakers [SOLVED]
We where all newbs at some stage mate, good work for fixing it. Thanks for using UMS, hope you stick with it
