Access UMS from another PC
Sorry if this was asked before, couldnt find anything via search. Is it possible to access UMS from another PC? How?
Thanks in advance.
Thanks in advance.
Re: Access UMS from another PC
It depends what you want to do with UMS remotely. I use Remote Desktop to update and configure the server remotely, and then forget about it till next test build. If you want to access content,then v5.0 will include a web server for universal client via a web browser.
Didn't the web server go live with version 4.1.0? Try to access port 9001 on the pc.Wolfgan wrote:It depends what you want to do with UMS remotely. I use Remote Desktop to update and configure the server remotely, and then forget about it till next test build. If you want to access content,then v5.0 will include a web server for universal client via a web browser.
Such as from the PC itself: http://127.0.0.1:9001
Depending on your setup/needs, may also require configuring your firewall/router.
- SharkHunter
- Developer
Yes the web if is live as of 4.0. It is always live on port 9001 if you don't tell it otherwise (it is possible to change port or disable it completely).
