No voice (center channel?) audio with default FFmpeg engine
EDIT - clarifying and simplifying the issue as it was a bit unclear before.
While playing a file back via the default engine (FFmpeg) the voices and some other small sounds are missing, I am assuming these are on center channel. When I go into the transcode folder and select [FFmpeg] {Audio: DTS/English ()}* the voice tracks and all sounds play back fine.
I am streaming from UMS 5.0.1 on Win7 x64 to a PS3 which is connected to TV via HDMI and my stereo audio receiver via 2-channel RCA.
It works fine on VLC and Media Player Classic (Windows Media Player won't let me skip ahead to the voices for some reason) - so I'm assuming it isn't a codec issue but I could be wrong.
What I would like to do is default to the FFmpeg transcode which properly plays back all sounds, or figure out what is different between default and FFmpeg transcode settings so I can resolve the issue at the source.
Debug and media info are attached. Let me know if I can provide any other pertinent info.
Divergent.2014.720p.BluRay.x264-SPARKS.mkv.txt- (7.55 KiB) Downloaded 452 times
- jb357_novoice_ums_dbg.zip
- (119.4 KiB) Downloaded 454 times
Re: No voice (center channel?) audio with default FFmpeg engine
Resolved.
Once making the below config change, everything works fine now and I don't have to dig into the transcode folders.
Transcode Settings -> Video Files Engines -> FFMpgeg -> UNCHECK the "Remux videos with tsMuxeR when possible instead of transcoding" option.
Mods feel free to close the thread.
