MKS wont start
omatzamedia
MKS wont start
Hello All
I am very new to ums.
So first I installed the latest UMS.
Then I pressed the shortcut to it.
Nothing happened.
I went to the whole path c:\program files\... and pressed on ums.exe.
Nothing happened (no screen open, no error message)
I un-installed it and re-install it. same results.
I saw that there is bach file ums.bat so I pressed on it.
Nothing happened.
I copied the line from the batch file and run it.
(don't have on here, where I am not, so I didn't paste it here)
No popup no nothing.
I looked at the process manager and I saw that there are two java__ processes that run, but no ums.
The OS is Win XP SP3
Any hints ?
Thanks a lot
Nothing happened.
Nothing happened.
Any hints ?
Thanks a lot
omatzamedia
Re: MKS wont start
No hints ?
No one encountered such a phenomana ?
Developers ?
Developers ?
