Problem with the UMS and subtitles
gLeW
Post by gLeW »
Hi I have a problem with the UMS and subtitles
I have a PS3 and an Xbox, and the problem I have it on both consoles.
The problem happens when I see something with "Avisynth / Menconder" and mkv movie has subtitle. 800288E1 always fails in the PS3, now if I run the same mkv, but no subtitles, it works perfectly.
Now I have the vsfilter in Avisynth plugins folder.
I also tried with PS3mediaserver and this goes to "Avisynth / Menconder" and subtitles.
Probe already do a clean installation, I have also installed the UMS the CoreAVC and AC3 Filter
Thanks sorry for my english
Re: Problem with the UMS and subtitles
Hi gLeW :)
That can happen sometimes when the CPU isn't fast enough or there are other programs using CPU. Sometimes if you try to play it twice the second time will work.
