Samsung BD-F5100 supported?
Hello, can anybody tell Samsung BD-F5100 supported?
Thx
Thx
Re: Samsung BD-F5100 supported?
No profile seems to exist for that particular model, but many other Samsung TVs exists that you may derive your specific profile from (also this http://www.universalmediaserver.com/faq/ may help)
Hey!!
You should upgrade the firmware of your model to make it compatible for every particular use. You may also update drivers for it.
Samsung BD-F5100 Manual can help you in understanding this concept.
