UniverSal media server
davorxxx
Post by davorxxx »
Please help if someone has little will to explain to me what's my problem.
So here's what I have TVPHILIPS 49PUS7909 and computer on it Windows 8.1.
I installed Universal media server and he found TVPHILIPS and also on TV appeared Universal media server.
But the TV says that there is no file in the folder.
Normally I put the file in a shared folder.
No way can not solve it so I can watch series and films.
I do not know something should still install at all.
Thanks for your help.
valib
Re: UniverSal media server
Post by valib »
Shared folder means folder not the file. You must put there only folder which includes the media you want to play.
davorxxx
Post by davorxxx »
I do not understand what should I do if someone can explain a little better.
davorxxx
Post by davorxxx »
squadjot
Post by squadjot »
You can specify folders that contain your movies/files like this.
davorxxx
Post by davorxxx »
I made but again ništa.Ne know what the problem is.
squadjot
Post by squadjot »
Is your files placed on a external harddrive?
What happens if you do not define any folders at all?
Are you running UMS with administrator rights?
davorxxx
Post by davorxxx »
From what I understand, and I have movies on a computer to drive D. This administrator do not get what you need to do, there's no way we UMS work. I do not know how much good it showed right I translate it through Google
