TsMuxer crashing on PS3
Penda
Post by Penda »
*.flv file was downloaded from youtube, ect. Playing it on xbmc works fine; however, the ps3 won't play and will often send an error to the client Windows 7 PC. "TsMuXer.exe has stopped working"
I tried to search for a solution but it seems the only thing I could find was trying previous versions. I tried to download a few previous versions but they all gave the same results. Attached is the debug logs of me starting up the server and trying to play a flv file.
tsmuxer_dbg.zip
(25.82 KiB) Downloaded 778 times
Re: TsMuxer crashing on PS3
Does it still happen with 2.2.2?
Penda
Post by Penda »
2.2.2 fixed it. Before I had to force transcode flv files to fix the issue.
sebciu
Post by sebciu »
i have this issue with 2.2.2
sebciu: can you post your debug.log?
