"UPnP Device Host" Windows Service - AUTOMATIC Startup
If you cannot even find UMS from a Phone/Tablet "UPnP Player APP" or other DLNA/UPnP device, verify and, if necessary, change the "UPnP Device Host" Windows Service to "Automatically" Startup at restart. These APPs will not be able to even find UMS until the Windows Serivce "UPnP Device Host" is running!
I just want to make certain that everyone is aware of this because on my Windows 10 system, the default was set, apparently, to "Manual". And, when I searched all of the UMS forums to see if this had been reported, I found only one obscure reference to it on item #5 in a post by Ranger187 on Feb 20, 2013 in the "General Help and Support" Forum. Good work Ranger187!
It would be nice if someone skilled in the art of documentation could "contribute" a simple HTML5 guide on getting UMS to "run" in various environments which could be placed on the UMS website and included as part of the distribution package. This would really increase the acceptance of UMS. In my opinion, UMS is subjectively the best product of its kind but has a reputation in the reviews of being difficult to "get working".
Re: "UPnP Device Host" Windows Service - AUTOMATIC Startup
Your point about the lack of proper documentation is valid. I doubt that the "UPnP Device Host" is needed. The problem is most likely that you haven't turned off the firewall. My guess is that when you start the "UPnP Device Host", UPnP traffic is automatically allowed through the Windows firewall and this also benefits UMS. There are other ports that's needed as well though, so the best thing is to turn off the firewall as it is normally not needed.
We've been discussing getting a proper documentation about firewall configuration together since so many people seem to have problems with firewalls these days. The problem is that I don't think any of us has a complete overview over what's needed either. I would never run a firewall on my local computer, all kind of stuff stops working (not only UMS) - and I have a router to take care of the firewall duties.
It is nice that we are probably both right! When I stopped the "UPnP Device Host" Windows Service,
"Auto-Discovery" by my Phone/Tablet APPs still works. But, until I initially started this Windows Service
to create the Windows Firewall Definitions, the DLNA/UPnP Player APPs on my WiFi connected Phone/Tablets
could not even see UMS running on my Windows machine. And, how many other "thing" do I have to
"do", "install", "enable" or "run" to create all of the Firewall Definitions?
In my opinion, the greatest risk to user PCs are email attachments, HTML email remote content and
the indiscriminate and uncontrolled running of JavaScript/etc. in browsers. Yes, the protection
offered by PC Firewalls is miniscule but they are not completely worthless. Today, more malware
is being written to attack networking components. And, just this month, one major Silicon Valley
manufacture announced that their networking products had been shipping with malware "preinstalled" for years!
I believe in having as many layers of protection as possible so if one is penetrated, hopefully,
there is another that will stop the attack. And, there is the legal concept of "due diligence":
have you done everything normally expected or even possible? So, I would hate for the UMS answer to be
"just disable your PC's Firewall". I would prefer to see a "Knowledge Base" documenting all of the known
procedures and steps necessary to get UMS running in different environments and modes. And, that would include
which TCP/UDP Ports must be opened, hopefully, only for specific programs and/or services.
I gave up on "[in]security" products that supposedly protect user's PC years ago and moved my user data
into separated data partitions which allows me to restore my 64 GB operating system partition
in less than ten minutes to different previous points in time: completion of a "clean install", completion
of the install of the application programs or a single application program before I changed "something".
I feel strongly enough about this that I am will to do a lot of the grunt testing to verify the correctness
of this information limited only by the restrictions of my environment. There are many ways to
contribute and donate if such help is desired and wanted. I presume you know how to contact me.
Pardon me for running on so long expressing my opinion. I was never noted for my brevity. Thank you,
I've never been noted for my brevity either, so don't worry about that part. I much prefer someone that give an in-depth description to someone that only throws out a few statements and then you have to guess/interpret the rest, or do some rounds of back and forth answers/questions until you actually get the information you need
Regarding protection approach I guess there's many out there. Personally I've had absolutely minimal such problems, and I haven't been infested by a virus since the early 90's. I have had a couple of malware installations, and those have always come from being a payload of something I've downloaded and installed. Attachements in general have never been a problem for me, I simply think they are so easy to reveal, and honestly I don't open an attachment that I didn't "expect" or that fall naturally from that person in that context. But, my basic idea is to control the software that I install on my computers (or other network devices). If I have that under control, then I'm pretty sure there's no "rouge" activity on my local network that's originating from my equipment, and I generally don't allow other equipment in there (I use mostly wired network, and if I have to use WiFi, WPA2 is the only thing I'd use).
Firewalls are there to plug the holes that's left there by other software. They are not the only line of defence, every software or OS should take care of it's own security without a firewall, and it all depends on how you configure said software. I'd never create writable local networks shares that didn't require authentication for example, since malware attacking local network resources are nothing new (the "I love you virus" etc.).
Sadly, firewalls have earned their right to exist a long time ago since there are too many weaknesses in software to trust it's own protection. But, I see it mainly as something you'd want between the network(s) you control and the rest of the world. I really don't like the idea of having such "checkpoints" in between my local devices, it becomes a lot like the West Bank. If quickly renders everything so cumbersome that it's not worth it.
It's always a balancing point, I think any strategy that says "more security is always better" is flawed. It's the same with your house. You could build multiple levels of stone walls, wired electrical fences, several levers of protection zones guared by killer dogs, cameras, high voltage etc. Yes very few of us do this, and the reason is obvious to me: It would get quickly get expensive, and it would make life unpleasant. Who would want to visit you if they risked getting electricuted and killed or severly injured by dogs, and would have to go through multiple layers of physical security to get in or out? Very few I suspect. Yet, if we lived in an environment with high enough risk, we would probably employ most or all of those measures if we could.
For me it's the same with computers. It's all about finding the right balance, and local firewalls on a "safe" network is one of those things I consider to do more harm than good. But, it would obviously depend on what information I kept on said computer. There would be circumstances where I would deem it necessary to run a local firewall, but those would be far from "normal". I do however realize that not everybody share my assessment or strategy. But, I also think though that most people don't really have a strategy or assessment, they simply do what they read or hear from friends. The OS creators think local firewalls are convenient since they can easily adapt them to suit the need of their own software, and they don't really care about everyone else's software. At the same time they don't want to be labeled "weak" on security, so the decision is easy for them. Most users then take this as a sign that using a local firewall is considered a necessary security measure, and the idea spreads. I doesn't mean it's reasonable in most situations imo.
In principle I consider firewalls something the users apply because they don't trust the software's own protection. In many cases they are right, e.g. UMS doesn't really have a protection scheme. At the same time, it's rare that the information provided by UMS would be critical if it were compromised. In any case, because it's something applied by the user, it should also be the user's responsibility to allow or block traffic according to their own needs. Most firewalls have logging capabilities, and an easy way to figure out what needs opening is to simply log everything that's blocked, try some function you want to work and see what gets blocked in the log. Open that, rinse and repeat until said function works.
I don't like the principle of software opening what it needs in the local firewall either. If I saw the need to run a local firewall, I'd very much like to control what got through it. As long as software are allowed to punch whatever holes it like in the firewall, it almost renders it useless. We're already at a point where you're rarely at risk unless you're being tricked into doing something stupid, like installing some malicious software or give away information needed to access computers, online services, bank accounts etc. Local firewalls, as long as software is able to alter their rules, don't offer any protection against that as any malicious software would simply open the access it would need to do it's business. Again, it's a compromise made because most users don't care to aquire enough information to make their own decisions, they just want everything to work as they want it to, while their protection needs is delivered "non intrusively" by "someone" else. But, it's a compromise that makes local firewalls make even less sense.
All this said, I do see a need to better guide users about what access UMS needs to work properly. In addition to the UPnP stuff there are only two cofigurable TCP ports that need incoming access as far as I know. They default to TCP port 5001 (DLNA http server) and TCP port 9001 (web interface http server). In addition UMS needs outgoing access to contact renderers, online services if those are used and to check for plugins and updates if that is desired. Outgoing ports are probably random (when a software asks for an outgoing connection, it's often just given some arbitrarty port by to OS, but I don't know if this is the case here). That's the source port however, the destination port would be predictable depending on the type of traffic. Any IP connection has a source and destination port, but often what's meant by "port" is destination port. The easy, "normal" thing to do to cover this would therefore be to allow incoming 5001 and 9001 TCP traffic, and allow all outgoing traffic.
The part I'm unsure about is the UPnP traffic. The reason why this is somewhat unclear to us is that we use a library called "cling" to do most of this. "Cling" is big and complex, and we only know what we need to use it, not all the details about it's network traffic. What I do know is that it uses multicast, and that in itself could complicate it a little bit.
This is all dictated by the DLNA/UPnP standard, and it's really not up to UMS to decide these rules. The need should be the same for any software that use the DLNA protocol. For anyone that would want to try to map this, I would recommend turning off the local firewall and capturing traffic with Wireshark while using UMS and trying to cover as many use cases as possible. Then the captures would need to be "analyzed", that is filtered and sorted until you can boil all the details down to what access is needed to allow this traffic. I'd start by filtering on the local host and the renderer in question so that only traffic between these two are shown. I'd then work my way down from there to try to get to the bottom. It might not even be very hard to do, but it's always hard to know that one has captured all eventualities.
When that's done, a set of firewall rules would have to be crafted, and the setup would have to be verified. Everything should be tested with the firewall on and off to ensure that the behaviour is identical in either case. When this is tested to a satisfactory lever, I'd say we have what we need to make an exact documentation of what's needed.
I found the UPnP spec so I will see what I can find on "Cling". I almost knew that you were going to suggest running my "favorite" program, Wireshark, for such an endeaver. And, your approach of comparing enabled/disabled Firewall is, I think, the best approach for determing TCP/UDP Ports and their effect upon UMS/DLNA/UPnP. The problem is, who/how are all of the relevant Firewall Definitions created. I second your dislike of programs just "adding" one or more of them during their install. And, of course, they are never deleted. So, if you install some products multiple times, you get the identical rules multiple times. It's enough to give security people heartburn or worst.
The worst I can do is give up OR fail. But, if I do come up with a "strawman", would that even slightly increase the likelihood of a "real" documention for UMS being considered? My personal opinion is that this need is as critical as the code for UMS. Whatever the outcome, I will let you know and not leave you wondering.
When it comes to a "real" documentation for UMS, it's a difficult task. First of all, most people hate to write documentation, both because it is tedious and boring and I guess because people are afraid of not doing it good enough. Coders in general are known to have a somewhat arrogant attitude towards documentation, "it's better that I spend my time coding and someone else does the documentation". I'm not saying that any of the UMS developers have said this, but I'd just like to include it as a possible hurdle.
The biggest problem in the case of UMS is probably that nobody really knows. UMS builds on PS3 Media Server, and when you sum up the history there have been many different people writing the code. A lot of different people know their little bit, many of them are not among the current UMS developers. Gathering this information would be a daunting task. I suspect that quite a few things could never be retrieved that way, and "someone" would have to sit down and read existing code to properly document it.
On top of that, it's the language issue. Ideally the documentation should be in multiple languages, but I guess if we have to pick one language it should be in English. Currently only a very few of the people involved are English native speakers, me excluded. Writing anything in a foreign language is much harder and takes a lot of time, I frequently have to look up words when writing English. So, the challenges are plenty.
I think that the only way it could be realized is that someone really dedicated took it on in a very structured manner, and collaborated with the current and past developers. It's hard to see who would take on such a huge task.
That being said, I think we realize the need for better documentation, and that any contributions would be appreciated and used. If you managed to write some documentation for the firewall section alone, I think we would and should use it for all it's worth.
I have already created an issue about the missing firewall handling, so at least as far as I'm concerned the need for a better handling is as clear as day.
