Black screen instead of movie
smirk
Post by smirk »
Hi, I'm seeing some new behavior with UMS 2.6.0 that 2.4.2 didn't have. Certain movie files won't play; all that appears is a black screen. The PS3 seems like it's starting to play, in that the screen blanks out and the "play" triangle icon appears, but then nothing happens. The PS3 shows it's sitting at zero seconds, and it isn't timing out so it just stays there forever. Playing the same movie with 2.4.2 works fine.
I've attached the log files, please let me know if you need anything else.
Thanks for taking a look, and thanks for UMS!
(39.73 KiB) Downloaded 468 times
