[SOLVED] Improve the Media Library speed
I was reading that http://java-performance.info/base64-enc ... rformance/ while trying to diagnotic an issue.
Since we can see that Java 8 native Base64 implementation is very fast, so will be the embedded CoverArt/AlbumArt (ID3 Tag) process before include them into the database if we use it.
Maybe you did it already, or it is too complicated to maintain a Java 8 version different from Java 7 ?
Just an idea
Just an idea
Re: Make the Media Library faster with Java 8
Are you looking for a J8 version of UMS?
http://www.fosshub.com/Universal-Media- ... -Java8.exe
No.
Just asking if class was used in Java 8 version, and if it will sound reasonnable to implement it for a faster Media Library (when it contain many Cover Art/Album Art ID3 Tags), since for now i saw that Apache Commons-Codec was used :
P.S. Sorry for not being clear in my first post.
Just asking if
java.util.Base64Code: Select all
import org.apache.commons.codec.binary.Base64;So, if we believe this comparison test from 2014, we can make it around 3 times faster.Name | Decode, 200000000 bytes
JavaXmlImpl | 0.885 sec
Java8Impl | 0.887 sec
MiGBase64Impl | 1.928 sec
IHarderImpl | 2.431 sec
ApacheImpl | 2.552 sec
GuavaImpl | 3.744 sec
SunImpl | 4.096 sec
Re: Improve the Media Library speed ?
It's worth looking into, thanks for pointing it out
erick diangilis
hi guys how are you doing? i know its my question has different subject in matter but since you understand more about programming java and things like this i found this java 9 update 125 early acess on the oracle website i would like to try but the even the lastest ums 6.4.1 snapshot that i've got doesn't work with it is there a possibility in a future version to have a compatibility or its too early to use because its not officialy released yet and its not in its full form to make a ums compatible with java 9?
thanks for the atention and have a good day
Sami32 do you mean somethink like this?
import java.util.Base64;
value = MI.Get(general, 0, "Cover_Data");
if (!value.isEmpty()) {
media.setThumb(Base64.getDecoder().decode(value));
...Re: Improve the Media Library speed ?
Valib Yes, exactly what i was thinking about, your skill make it easy
I am better for looking at, trying to understand, that coding it
P.S. Thanks to Valib for this implementation
