[Solved] 2.62 dropping from ps3
phonline
Post by phonline »
A new issue has popped up since going from 2.6.1 to 2.6.2
After some time of non-use (guessing an hour or so) I turn on my ps3 and there's no UMS icon. I go to my PC and it says Connected. I quit UMS and then open it again and the icon instantly appears on my PS3 and I'm good again. This has happened 5 times in the last two days since I switched to 2.6.2. It works well in every other aspect except dropping off my network. I can watch something. Turn off PS3, come back later and it's gone again. I close/re-open on PC and I'm good again.
Zip file of debug files attached. Here's the basic debug log:
04-24 09:09:37  Starting Universal Media Server 2.6.2
04-24 09:09:37  Based on PS3 Media Server by shagrath, copyright 2008-2013
04-24 09:09:37  http://www.universalmediaserver.com
04-24 09:09:37
04-24 09:09:37  Build: 59c8b88ce (2013-04-22)
04-24 09:09:37  Java: 1.7.0_21-Oracle Corporation
04-24 09:09:37  OS: Windows 8 64-bit 6.2
04-24 09:09:37  Encoding: UTF-8
04-24 09:09:37  Memory: 742 MB
04-24 09:09:37
04-24 09:09:37  Working directory: C:\Program Files (x86)\Universal Media Server
04-24 09:09:37  Temp directory: C:\Users\User\AppData\Local\Temp\universalmediaserver
04-24 09:09:37  Logging config file: C:\Program Files (x86)\Universal Media Server\logback.xml
04-24 09:09:37  debug.log: C:\Users\User\AppData\Local\Temp\\debug.log
04-24 09:09:37
04-24 09:09:37  Profile directory: C:\ProgramData\UMS
04-24 09:09:37  Profile path: C:\ProgramData\UMS\UMS.conf
04-24 09:09:37  Profile permissions: rw
04-24 09:09:37  Profile name: Scott
04-24 09:09:37
04-24 09:09:37  Loading MediaInfo library
04-24 09:09:37  Loaded MediaInfoLib - v0.7.62
04-24 09:09:37  Loading renderer configurations from C:\Program Files (x86)\Universal Media Server\renderers
04-24 09:09:37  Loading configuration file: AirPlayer.conf
04-24 09:09:37  Loading configuration file: Android.conf
04-24 09:09:37  Loading configuration file: BlackBerryPlayBook-KalemSoftMP.conf
04-24 09:09:37  Loading configuration file: Bravia4500.conf
04-24 09:09:37  Loading configuration file: Bravia5500.conf
04-24 09:09:37  Loading configuration file: BraviaEX.conf
04-24 09:09:37  Loading configuration file: BraviaEX620.conf
04-24 09:09:37  Loading configuration file: BraviaHX.conf
04-24 09:09:37  Loading configuration file: DirecTVHR.conf
04-24 09:09:37  Loading configuration file: DLinkDSM510.conf
04-24 09:09:37  Loading configuration file: FreeboxHD.conf
04-24 09:09:37  Loading configuration file: FreecomMusicPal.conf
04-24 09:09:37  Loading configuration file: iPad-iPhone.conf
04-24 09:09:37  Loading configuration file: Kuro.conf
04-24 09:09:37  Loading configuration file: LGST600.conf
04-24 09:09:37  Loading configuration file: N900.conf
04-24 09:09:37  Loading configuration file: NetgearNeoTV.conf
04-24 09:09:37  Loading configuration file: OnkyoTX-NR717.conf
04-24 09:09:37  Loading configuration file: OPPOBDP83.conf
04-24 09:09:37  Loading configuration file: OPPOBDP93.conf
04-24 09:09:37  Loading configuration file: Panasonic.conf
04-24 09:09:37  Loading configuration file: Philips.conf
04-24 09:09:37  Loading configuration file: PhilipsPFL.conf
04-24 09:09:37  Loading configuration file: PopcornHour.conf
04-24 09:09:37  Loading configuration file: PS3.conf
04-24 09:09:37  Loading configuration file: Realtek.conf
04-24 09:09:37  Loading configuration file: Samsung-SMT-G7400.conf
04-24 09:09:37  Loading configuration file: SamsungAllShare.conf
04-24 09:09:37  Loading configuration file: SamsungWiseLink.conf
04-24 09:09:37  Loading configuration file: SharpAquos.conf
04-24 09:09:37  Loading configuration file: Showtime3.conf
04-24 09:09:37  Loading configuration file: Showtime4.conf
04-24 09:09:37  Loading configuration file: SMP-N100.conf
04-24 09:09:37  Loading configuration file: SonyBluray.conf
04-24 09:09:37  Loading configuration file: SonyBraviaHX800.conf
04-24 09:09:37  Loading configuration file: SonyHomeTheatreSystem.conf
04-24 09:09:37  Loading configuration file: Streamium.conf
04-24 09:09:37  Loading configuration file: TelstraTbox.conf
04-24 09:09:37  Loading configuration file: VideoWebTV.conf
04-24 09:09:37  Loading configuration file: VizioSmartTV.conf
04-24 09:09:37  Loading configuration file: WDTVLive.conf
04-24 09:09:37  Loading configuration file: WMP.conf
04-24 09:09:37  Loading configuration file: XBMC.conf
04-24 09:09:37  Loading configuration file: XBOX360.conf
04-24 09:09:37  Loading configuration file: YamahaRXA1010.conf
04-24 09:09:37  Loading configuration file: YamahaRXV3900.conf
04-24 09:09:37  Loading configuration file: YamahaRXV671.conf
04-24 09:09:37  Please wait while we check the MPlayer font cache, this can take a minute or so.
04-24 09:09:38  Finished checking the MPlayer font cache.
04-24 09:09:38  VSFilter / DirectVobSub was not found. This can cause problems when trying to play subtitled videos with AviSynth.
04-24 09:09:38  Found VideoLAN version 2.0.5 at: C:\Program Files (x86)\VideoLAN\VLC\vlc.exe
04-24 09:09:38  Searching for plugins in C:\Program Files (x86)\Universal Media Server\plugins
04-24 09:09:38  No plugins found
04-24 09:09:38  Registering transcoding engine: AviSynth/FFmpeg
04-24 09:09:38  Registering transcoding engine: FFmpeg Audio
04-24 09:09:38  Registering transcoding engine: MEncoder
04-24 09:09:38  Registering transcoding engine: AviSynth/MEncoder
04-24 09:09:38  Registering transcoding engine: MPlayer Audio
04-24 09:09:38  Registering transcoding engine: FFmpeg Web Video
04-24 09:09:38  Registering transcoding engine: MEncoder Web
04-24 09:09:38  Registering transcoding engine: MPlayer Video Dump
04-24 09:09:38  Registering transcoding engine: MPlayer Web
04-24 09:09:38  Registering transcoding engine: tsMuxeR
04-24 09:09:38  Registering transcoding engine: Audio High Fidelity
04-24 09:09:38  Registering transcoding engine: VLC Audio Streaming
04-24 09:09:38  Registering transcoding engine: VLC Video Streaming
04-24 09:09:38  Registering transcoding engine: FFmpeg DVR-MS Remux
04-24 09:09:38  Registering transcoding engine: dcraw Thumbnailer
04-24 09:09:38  Using address /192.168.2.2 found on network interface: name:eth4 (Realtek PCIe GBE Family Controller)
04-24 09:09:38  Created socket: /192.168.2.2:5001
04-24 09:09:38  Using the following UUID configured in UMS.conf: 1d82ce6c-fb9c-4861-9e4a-8d153ddf9069
04-24 09:09:39  The server is now available for renderers to find
04-24 09:09:39  No IP filter specified, access granted to /192.168.2.11
04-24 09:09:39  Checking IP: 192.168.2.11 for PlayStation 3
04-24 09:09:44  Renderer PlayStation 3 found on this address: 192.168.2.11
04-24 09:09:46  Address /192.168.2.11 has an estimated network speed of: 42 Mb/s
04-24 09:09:58  Checking shared folder: I:\Video
04-24 09:11:29  No IP filter specified, access granted to /127.0.0.1
04-24 09:19:39  No IP filter specified, access granted to /192.168.2.2
04-24 09:19:39  Another renderer like PlayStation 3 was found!
04-24 09:19:39  Checking IP: 192.168.2.2 for PlayStation 3
04-24 09:19:40  Renderer PlayStation 3 found on this address: 192.168.2.2
04-24 09:19:42  Address /192.168.2.2 has an estimated network speed of: 1024 Mb/s
(18.32 KiB) Downloaded 673 times
Re: 2.62 dropping from ps3
Yeah that has been a bug on the PS3 for a while now, maybe you recently updated the PS3 firmware? I forgot which version started it
phonline
Post by phonline »
No. but i did update Java at the same time as updating UMS. I'll drop that back and see what that does.
phonline
Post by phonline »
As a follow up. reverting Java didn't fix it. Going back to 2.61 fixed it. Something changed going to 2.62 for me that caused the PS3 to stop seeing UMS.
The bug has been fixed now, look for a new release later today hopefully :)
Gareee
Post by Gareee »
I was just going to report the same issue. Glad you already caught it.
I wasn't sure if it was a UMS update, the Java update, or if it was that latest ps3 update.
phonline
Post by phonline »
Thanks. 2.63 has worked perfect!
Optimus_prime
Post by Optimus_prime »
I'm glad to see this is fixed for you phonline
Re: [FIXED]2.62 dropping from ps3
Thanks for confirming, phonline :)
