Screencasting or Mirroring Desktop on TV
Hi guys
I'm new to UMS and tried my best to search forum and internet before I ask my question so forgive me for this.
I found a few old topics suggesting to install Jumpy plugin and capture.py script so I did but can't find any video file captured, as I noted the video file will be saved on PS3 device while I have a MiraScreen dongle and old Sony LCD. (My VGA doesn't support mirroring so I should still use DLNA instead)
Any idea how should I run this screen casting?
Re: Screencasting or Mirroring Desktop on TV
some work have been done by @Sharhunter but was not finished, and he's not active anymore since many months already. Though you can make a build with his PR and have a try.
https://github.com/UniversalMediaServer ... r/pull/218
You can also have a look there, in case it could fullfill your need:
viewtopic.php?f=6&t=6127
Hoping that it helped you. As i'm not familiar at all with that matter, i'm afraid that i'll not be able to help/advice you more than that.
Note: For script handling, @Infidel should be a good adviser
