UMS and PS3 , subtitles issues with mkv
CaptainTom25
Re: UMS and PS3 , subtitles issues with mkv
Here's a new log files : I configured as you requested , Trace and Fatal(FFMPEG) , AVC/HEVC etc.. as you suggested. I used 3 movies
1 Mission Impossible, subtitle .srt files is next to the /mkv : directlink (no transcode folder) , failed, then transcode FFMPEG , also failed. It took less than 1 sec to fail
2 2001, Space Odyssey : many subtitles, no .srt files : 3 english FFMPEG audio/english sub available in transcode forlder : all failed, but it took long time to do so.
3 The book of solution, French / no subtilte FFMPEG : it works , no waiting time
If i disable all subtitles, all movies FFMPEG work, but no subtitle even from Transcode folder : UI shows subtitlse , but not while running the movie.
- ums_dbg_2025-10-01-12-29.zip
- (1.55 MiB) Downloaded 868 times
Mission.Impossible is failing the same way my Squid game is.
(I shortened file names)
I suspect it may be because it has multiple audio tracks, I will have to do a bit of testing of this.
This will be one that will refuse to play immediately.
Do you find that this is the same for other videos with more that one audio track?
I think there is a problem here with the interaction of subtitles and many audio tracks as I have a dual audio anime that plays fine without subs but returns the same error when enabled.
I did mention this on the Forced subs issue I made but it appears to be separate so I'll make another after more testing.
For 2001.A.Space.Odyssey FFmpeg seems to stop analysing the video after coming to stream #9 then soon after it says EOF (end of file)
Does this video play normally on your computer? If not it could be a partial download.
If this plays just fine on your computer could you upload this somewhere so I can test it on my system. You could use Mega.nz then PM me the link.
The last video Le.Livre.des.solutions looks normal but as it has no subs so it proves these are an issue.
ffmpeg.exe -y -loglevel info -hwaccel auto -threads 1 -i G:\Videos\Mission.Impossible.mkv -filter_complex subtitles=G\\:/Videos/Mission.Impossible.srt:force_style=',Fontsize=21.0,PrimaryColour=&H00FFFFFF,Outline=1,Shadow=1,MarginV=10' -map 0:V -map 0:a:1 -threads 16 -bufsize 7000k -maxrate 89000k -g 25 -q:v 1 -qmin 2 -qmax 3 -ac 2 -ab 192k -c:a ac3 -c:v mpeg2video -f vob \\.\pipe\ffmpegvideo_150_1759314304449
[fc#0 @ 000001d11c9761c0] Cannot find an unused video input stream to feed the unlabeled input pad subtitles:default.
Error binding filtergraph inputs/outputs: Invalid argument
EOF
Process C:\Program Files\Universal Media Server\bin\ffmpeg.exe has a return code of -22! Maybe an error occurred... check the log file
[matroska,webm @ 000001ef8594f6c0] Could not find codec parameters for stream 8 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
[matroska,webm @ 000001ef8594f6c0] Could not find codec parameters for stream 9 (Attachment: none): unknown codecCode: Select all
Starting "C:\Program Files\Universal Media Server\bin\ffmpeg.exe" -y -loglevel info -hwaccel auto -threads 1 -i G:\Videos\2001.A.Space.Odyssey.1968.Remastered.1080p.BluRay.AV1.DDP.5.1.Multi3-dAV1nci.mkv -filter_complex subtitles=G\\:/Videos/2001.A.Space.Odyssey.1968.Remastered.1080p.BluRay.AV1.DDP.5.1.Multi3-dAV1nci.mkv:si=0:force_style=',Fontsize=21.0,PrimaryColour=&H00FFFFFF,Outline=1,Shadow=1,MarginV=10' -map 0:V -map 0:a:1 -threads 16 -bufsize 7000k -maxrate 89000k -g 25 -q:v 1 -qmin 2 -qmax 3 -ac 2 -ab 192k -c:a ac3 -c:v mpeg2video -f vob \\.\pipe\ffmpegvideo_148_1759314366712
ffmpeg version 2025-07-21-git-8cdb47e47a-essentials_build-www.gyan.dev Copyright (c) 2000-2025 the FFmpeg developers
built with gcc 15.1.0 (Rev6, Built by MSYS2 project)
configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-zlib --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-sdl2 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-libaom --enable-libopenjpeg --enable-libvpx --enable-mediafoundation --enable-libass --enable-libfreetype --enable-libfribidi --enable-libharfbuzz --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-dxva2 --enable-d3d11va --enable-d3d12va --enable-ffnvcodec --enable-libvpl --enable-nvdec --enable-nvenc --enable-vaapi --enable-openal --enable-libgme --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libtheora --enable-libvo-amrwbenc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-librubberband
libavutil 60. 5.100 / 60. 5.100
libavcodec 62. 8.100 / 62. 8.100
libavformat 62. 1.103 / 62. 1.103
libavdevice 62. 0.100 / 62. 0.100
libavfilter 11. 2.100 / 11. 2.100
libswscale 9. 0.100 / 9. 0.100
libswresample 6. 0.100 / 6. 0.100
[Parsed_subtitles_0 @ 000001d2ca957c40] libass API version: 0x1704000
[Parsed_subtitles_0 @ 000001d2ca957c40] libass source: commit: 0.17.4-13-ge4215b0d175a5a340c0dbd7a990df82f07d71a34
[Parsed_subtitles_0 @ 000001d2ca957c40] Shaper: FriBidi 1.0.16 (SIMPLE) HarfBuzz-ng 11.2.1 (COMPLEX)
[matroska,webm @ 000001d2cabff6c0] Could not find codec parameters for stream 8 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options
[matroska,webm @ 000001d2cabff6c0] Could not find codec parameters for stream 9 (Attachment: none): unknown codec
[Parsed_subtitles_0 @ 000001d2ca957c40] Using font provider directwrite (with GDI)
EOF
I found what is causing the multiple audio tracks to fail. I was able to get it to transcode from the command line with a little edit.
I made a new issue for this here
CaptainTom25
Yes 2001 plays normally on my PC, I uploaded it to mega, the link will be send in PM.
I also tried the version 15.0.0, but still same issues..
Let s hope devs can fix the bugs with future releases...
OK I can confirm that video will play without subtitles but it does appear to suffer the same issue as the other multi audio videos I mentioned before.
However while testing using the FFmpeg command UMS uses for you to play that video I found another issue with the font colour being read as an invalid command and I found this also happens for those other videos.
I think this may be a bug or a change in FFmpeg itself as when I search how it is supposed to look it is correct.
This is what is used and the documentation shows this is correct but will only work if you remove the &
Could you do a test and run the transcode command in the command line on your computer?
To bring it up type cmd in windows search box then select command prompt for the result.
This is the original command that is being used but sent to test.mpg instead of a pipe.
It should give the error "Filter 'subtitles:default' has output 0 (unlabeled) unconnected"
This one should get further but report " 'H00FFFFFF' is not recognized as an internal or external command, operable program or batch file."
(I don't know why but this never appeared in your logs.)
And this one should work and start to transcode.
and the output should look like
You can press ctrl+c to stop it and delete the test.mpg video it made.
I'll update that issue with this new info.
PrimaryColour=&H00FFFFFFTo bring it up type cmd in windows search box then select command prompt for the result.
"C:\Program Files\Universal Media Server\bin\ffmpeg.exe" -y -loglevel info -hwaccel auto -threads 1 -i G:\Videos\2001.A.Space.Odyssey.1968.Remastered.1080p.BluRay.AV1.DDP.5.1.Multi3-dAV1nci.mkv -filter_complex subtitles=G\\:/Videos/2001.A.Space.Odyssey.1968.Remastered.1080p.BluRay.AV1.DDP.5.1.Multi3-dAV1nci.mkv:si=0:force_style=',Fontsize=21.0,PrimaryColour=&H00FFFFFF,Outline=1,Shadow=1,MarginV=10' -map 0:V -map 0:a:0 -threads 16 -bufsize 7000k -maxrate 89000k -g 25 -q:v 1 -qmin 2 -qmax 3 -ac 2 -ab 192k -c:a ac3 -c:v mpeg2video -f vob test.mpg(I don't know why but this never appeared in your logs.)
"C:\Program Files\Universal Media Server\bin\ffmpeg.exe" -y -loglevel info -hwaccel auto -threads 1 -i G:\Videos\2001.A.Space.Odyssey.1968.Remastered.1080p.BluRay.AV1.DDP.5.1.Multi3-dAV1nci.mkv -filter_complex [v]subtitles=G\\:/Videos/2001.A.Space.Odyssey.1968.Remastered.1080p.BluRay.AV1.DDP.5.1.Multi3-dAV1nci.mkv:si=0:force_style=',Fontsize=21.0,PrimaryColour=&H00FFFFFF,Outline=1,Shadow=1,MarginV=10' -map 0:V -map 0:a:0 -threads 16 -bufsize 7000k -maxrate 89000k -g 25 -q:v 1 -qmin 2 -qmax 3 -ac 2 -ab 192k -c:a ac3 -c:v mpeg2video -f vob test.mpgCode: Select all
"C:\Program Files\Universal Media Server\bin\ffmpeg.exe" -y -loglevel info -hwaccel auto -threads 1 -i G:\Videos\2001.A.Space.Odyssey.1968.Remastered.1080p.BluRay.AV1.DDP.5.1.Multi3-dAV1nci.mkv -filter_complex [v]subtitles=G\\:/Videos/2001.A.Space.Odyssey.1968.Remastered.1080p.BluRay.AV1.DDP.5.1.Multi3-dAV1nci.mkv:si=0:force_style=',Fontsize=21.0,PrimaryColour=H00FFFFFF,Outline=1,Shadow=1,MarginV=10' -map 0:V -map 0:a:0 -threads 16 -bufsize 7000k -maxrate 89000k -g 25 -q:v 1 -qmin 2 -qmax 3 -ac 2 -ab 192k -c:a ac3 -c:v mpeg2video -f vob test.mpgCode: Select all
frame= 304 fps= 95 q=1.0 Lq=1.0 size= 37694KiB time=00:00:12.63 bitrate=24434.1kbits/s dup=1 drop=0 speed=3.94x elapsed=0:00:03.21I'll update that issue with this new info.
CaptainTom25
Indeed, I ran the 3 commands and the results are below
1rst command
2nd command
3rd Command
Hope this helps...
1rst command
C:\Users\SteveO>"C:\Program Files\Universal Media Server\bin\ffmpeg.exe" -y -loglevel info -hwaccel auto -threads 1 -i G:\Videos\2001.A.Space.Odyssey.1968.Remastered.1080p.BluRay.AV1.DDP.5.1.Multi3-dAV1nci.mkv -filter_complex subtitles=G\\:/Videos/2001.A.Space.Odyssey.1968.Remastered.1080p.BluRay.AV1.DDP.5.1.Multi3-dAV1nci.mkv:si=0:force_style=',Fontsize=21.0,PrimaryColour=&H00FFFFFF,Outline=1,Shadow=1,MarginV=10' -map 0:V -map 0:a:0 -threads 16 -bufsize 7000k -maxrate 89000k -g 25 -q:v 1 -qmin 2 -qmax 3 -ac 2 -ab 192k -c:a ac3 -c:v mpeg2video -f vob test.mpg
[Parsed_subtitles_0 @ 0000019ccdc05b80] libass API version: 0x1704000
[Parsed_subtitles_0 @ 0000019ccdc05b80] libass source: commit: 0.17.4-13-ge4215b0d175a5a340c0dbd7a990df82f07d71a34
[Parsed_subtitles_0 @ 0000019ccdc05b80] Shaper: FriBidi 1.0.16 (SIMPLE) HarfBuzz-ng 11.2.1 (COMPLEX)
[matroska,webm @ 0000019ccdc07200] Could not find codec parameters for stream 8 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
[matroska,webm @ 0000019ccdc07200] Could not find codec parameters for stream 9 (Attachment: none): unknown codec
[Parsed_subtitles_0 @ 0000019ccdc05b80] Using font provider directwrite (with GDI)
[opus @ 0000019ccdc36140] Error parsing Opus packet header.
[matroska,webm @ 0000019ccf8cad80] Could not find codec parameters for stream 8 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
[matroska,webm @ 0000019ccf8cad80] Could not find codec parameters for stream 9 (Attachment: none): unknown codec
Input #0, matroska,webm, from 'G:\Videos\2001.A.Space.Odyssey.1968.Remastered.1080p.BluRay.AV1.DDP.5.1.Multi3-dAV1nci.mkv':
Metadata:
title : 2001: A Space Odyssey (1968) [dAV1nci]
encoder : libebml v1.4.5 + libmatroska v1.7.1
creation_time : 2024-09-29T12:15:06.000000Z
Duration: 02:28:51.75, start: -0.007000, bitrate: 4007 kb/s
Chapters:
Chapter #0:0: start 0.000000, end 177.093583
Metadata:
title : Chapter 01
Chapter #0:1: start 177.093583, end 279.028750
Metadata:
title : Chapter 02
Chapter #0:2: start 279.028750, end 699.865833
Metadata:
title : Chapter 03
Chapter #0:3: start 699.865833, end 1017.891875
Metadata:
title : Chapter 04
Chapter #0:4: start 1017.891875, end 1192.941750
Metadata:
title : Chapter 05
Chapter #0:5: start 1192.941750, end 1528.944083
Metadata:
title : Chapter 06
Chapter #0:6: start 1528.944083, end 1658.073083
Metadata:
title : Chapter 07
Chapter #0:7: start 1658.073083, end 1769.434333
Metadata:
title : Chapter 08
Chapter #0:8: start 1769.434333, end 2026.774750
Metadata:
title : Chapter 09
Chapter #0:9: start 2026.774750, end 2468.549417
Metadata:
title : Chapter 10
Chapter #0:10: start 2468.549417, end 2737.401333
Metadata:
title : Chapter 11
Chapter #0:11: start 2737.401333, end 3056.470083
Metadata:
title : Chapter 12
Chapter #0:12: start 3056.470083, end 3281.695083
Metadata:
title : Chapter 13
Chapter #0:13: start 3281.695083, end 3513.635125
Metadata:
title : Chapter 14
Chapter #0:14: start 3513.635125, end 3835.957125
Metadata:
title : Chapter 15
Chapter #0:15: start 3835.957125, end 3965.211250
Metadata:
title : Chapter 16
Chapter #0:16: start 3965.211250, end 4330.576250
Metadata:
title : Chapter 17
Chapter #0:17: start 4330.576250, end 4731.768708
Metadata:
title : Chapter 18
Chapter #0:18: start 4731.768708, end 4981.434792
Metadata:
title : Chapter 19
Chapter #0:19: start 4981.434792, end 5222.133583
Metadata:
title : Chapter 20
Chapter #0:20: start 5222.133583, end 5269.180583
Metadata:
title : Chapter 21
Chapter #0:21: start 5269.180583, end 5407.652250
Metadata:
title : Chapter 22
Chapter #0:22: start 5407.652250, end 5570.773542
Metadata:
title : Chapter 23
Chapter #0:23: start 5570.773542, end 5915.492917
Metadata:
title : Chapter 24
Chapter #0:24: start 5915.492917, end 6046.999292
Metadata:
title : Chapter 25
Chapter #0:25: start 6046.999292, end 6335.454125
Metadata:
title : Chapter 26
Chapter #0:26: start 6335.454125, end 6581.449875
Metadata:
title : Chapter 27
Chapter #0:27: start 6581.449875, end 6919.579333
Metadata:
title : Chapter 28
Chapter #0:28: start 6919.579333, end 7026.060708
Metadata:
title : Chapter 29
Chapter #0:29: start 7026.060708, end 7288.114167
Metadata:
title : Chapter 30
Chapter #0:30: start 7288.114167, end 7893.302083
Metadata:
title : Chapter 31
Chapter #0:31: start 7893.302083, end 8277.519250
Metadata:
title : Chapter 32
Chapter #0:32: start 8277.519250, end 8433.341583
Metadata:
title : Chapter 33
Chapter #0:33: start 8433.341583, end 8931.744000
Metadata:
title : Chapter 34
Stream #0:0: Video: av1 (libaom-av1) (Main), yuv420p10le(tv), 1920x872 [SAR 1:1 DAR 240:109], 23.98 fps, 23.98 tbr, 1k tbn (default)
Metadata:
title : dAV1nci
BPS : 2784064
DURATION : 02:28:51.715000000
NUMBER_OF_FRAMES: 214147
NUMBER_OF_BYTES : 3108308515
_STATISTICS_WRITING_APP: mkvmerge v84.0 ('Sleeper') 64-bit
_STATISTICS_WRITING_DATE_UTC: 2024-09-29 12:15:06
_STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Stream #0:1(eng): Audio: eac3, 48000 Hz, 5.1(side), fltp, 320 kb/s (default)
Metadata:
title : English 5.1 (EAC3 320 kbps) - Restored
BPS : 320000
DURATION : 02:28:51.744000000
NUMBER_OF_FRAMES: 279117
NUMBER_OF_BYTES : 357269760
Stream #0:2(eng): Audio: eac3, 48000 Hz, 5.1(side), fltp, 320 kb/s
Metadata:
title : English 5.1 (EAC3 320 kbps) - Original
BPS : 320000
Stream #0:3(fre): Audio: eac3, 48000 Hz, 5.1(side), fltp, 256 kb/s
Metadata:
title : French 5.1 (EAC3 256 kbps)
BPS : 256000
NUMBER_OF_BYTES : 285815808
Stream #0:4(ger): Audio: eac3, 48000 Hz, 5.1(side), fltp, 256 kb/s
Metadata:
title : German 5.1 (EAC3 256 kbps)
BPS : 256000
Stream #0:5(eng): Audio: opus, 48000 Hz, stereo, fltp, start -0.007000
Metadata:
title : English 2.0 (Opus 64 kbps) - Commentary
BPS : 61907
DURATION : 02:28:51.752000000
NUMBER_OF_FRAMES: 446588
NUMBER_OF_BYTES : 69118197
Stream #0:6(eng): Subtitle: subrip (srt), start -0.007000
Metadata:
BPS : 41
DURATION : 01:31:19.081000000
NUMBER_OF_FRAMES: 809
NUMBER_OF_BYTES : 28527
Stream #0:7(eng): Subtitle: subrip (srt), start -0.007000
Metadata:
title : Commentary (AI Transcription)
BPS : 79
DURATION : 02:24:31.170000000
NUMBER_OF_FRAMES: 2336
NUMBER_OF_BYTES : 85912
Stream #0:8(eng): Subtitle: hdmv_pgs_subtitle (pgssub), start -0.007000
Metadata:
title : SDH
BPS : 15133
DURATION : 02:17:49.469000000
NUMBER_OF_FRAMES: 1334
NUMBER_OF_BYTES : 15643381
SOURCE_ID : 001201
_STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID
Stream #0:9: Attachment: none, start -0.007000
Metadata:
filename : av1an-09-28-2024-22-09-50.txt
mimetype : text/plain
[fc#0 @ 0000019ccdc03900] Filter 'subtitles:default' has output 0 (unlabeled) unconnected
←]9001;CmdNotFound;H00FFFFFF←\'H00FFFFFF' is not recognized as an internal or external command,
operable program or batch file.Code: Select all
C:\Users\SteveO>"C:\Program Files\Universal Media Server\bin\ffmpeg.exe" -y -loglevel info -hwaccel auto -threads 1 -i G:\Videos\2001.A.Space.Odyssey.1968.Remastered.1080p.BluRay.AV1.DDP.5.1.Multi3-dAV1nci.mkv -filter_complex [v]subtitles=G\\:/Videos/2001.A.Space.Odyssey.1968.Remastered.1080p.BluRay.AV1.DDP.5.1.Multi3-dAV1nci.mkv:si=0:force_style=',Fontsize=21.0,PrimaryColour=&H00FFFFFF,Outline=1,Shadow=1,MarginV=10' -map 0:V -map 0:a:0 -threads 16 -bufsize 7000k -maxrate 89000k -g 25 -q:v 1 -qmin 2 -qmax 3 -ac 2 -ab 192k -c:a ac3 -c:v mpeg2video -f vob test.mpg
[Parsed_subtitles_0 @ 000002007ce75d80] libass API version: 0x1704000
[Parsed_subtitles_0 @ 000002007ce75d80] libass source: commit: 0.17.4-13-ge4215b0d175a5a340c0dbd7a990df82f07d71a34
[Parsed_subtitles_0 @ 000002007ce75d80] Shaper: FriBidi 1.0.16 (SIMPLE) HarfBuzz-ng 11.2.1 (COMPLEX)
[matroska,webm @ 000002007d11f6c0] Could not find codec parameters for stream 8 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
[matroska,webm @ 000002007d11f6c0] Could not find codec parameters for stream 9 (Attachment: none): unknown codec
[Parsed_subtitles_0 @ 000002007ce75d80] Using font provider directwrite (with GDI)
[opus @ 000002007cea9bc0] Error parsing Opus packet header.
[matroska,webm @ 000002007dc58f00] Could not find codec parameters for stream 8 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
[matroska,webm @ 000002007dc58f00] Could not find codec parameters for stream 9 (Attachment: none): unknown codec
Metadata:
Chapters:
Metadata:
title : Chapter 01
Metadata:
title : Chapter 02
Metadata:
title : Chapter 03
Metadata:
title : Chapter 04
Metadata:
title : Chapter 05
Metadata:
title : Chapter 06
Metadata:
title : Chapter 07
Metadata:
title : Chapter 08
Metadata:
title : Chapter 09
Metadata:
title : Chapter 10
Metadata:
title : Chapter 11
Metadata:
title : Chapter 12
Metadata:
title : Chapter 13
Metadata:
title : Chapter 14
Metadata:
title : Chapter 15
Metadata:
title : Chapter 16
Metadata:
title : Chapter 17
Metadata:
title : Chapter 18
Metadata:
title : Chapter 19
Metadata:
title : Chapter 20
Metadata:
title : Chapter 21
Metadata:
title : Chapter 22
Metadata:
title : Chapter 23
Metadata:
title : Chapter 24
Metadata:
title : Chapter 25
Metadata:
title : Chapter 26
Metadata:
title : Chapter 27
Metadata:
title : Chapter 28
Metadata:
title : Chapter 29
Metadata:
title : Chapter 30
Metadata:
title : Chapter 31
Metadata:
title : Chapter 32
Metadata:
title : Chapter 33
Metadata:
title : Chapter 34
Metadata:
title : dAV1nci
BPS : 2784064
Metadata:
BPS : 320000
Metadata:
BPS : 320000
Metadata:
BPS : 256000
Metadata:
BPS : 256000
Metadata:
BPS : 61907
Metadata:
BPS : 41
Metadata:
BPS : 79
Metadata:
title : SDH
BPS : 15133
SOURCE_ID : 001201
Metadata:
[fc#0 @ 000002007ce73940] Filter 'subtitles:default' has output 0 (unlabeled) unconnected
C:\Users\SteveO>"C:\Program Files\Universal Media Server\bin\ffmpeg.exe" -y -loglevel info -hwaccel auto -threads 1 -i G:\Videos\2001.A.Space.Odyssey.1968.Remastered.1080p.BluRay.AV1.DDP.5.1.Multi3-dAV1nci.mkv -filter_complex [v]subtitles=G\\:/Videos/2001.A.Space.Odyssey.1968.Remastered.1080p.BluRay.AV1.DDP.5.1.Multi3-dAV1nci.mkv:si=0:force_style=',Fontsize=21.0,PrimaryColour=H00FFFFFF,Outline=1,Shadow=1,MarginV=10' -map 0:V -map 0:a:0 -threads 16 -bufsize 7000k -maxrate 89000k -g 25 -q:v 1 -qmin 2 -qmax 3 -ac 2 -ab 192k -c:a ac3 -c:v mpeg2video -f vob test.mpg
[Parsed_subtitles_0 @ 00000263864d7dc0] libass API version: 0x1704000
[Parsed_subtitles_0 @ 00000263864d7dc0] libass source: commit: 0.17.4-13-ge4215b0d175a5a340c0dbd7a990df82f07d71a34
[Parsed_subtitles_0 @ 00000263864d7dc0] Shaper: FriBidi 1.0.16 (SIMPLE) HarfBuzz-ng 11.2.1 (COMPLEX)
[matroska,webm @ 000002638677f6c0] Could not find codec parameters for stream 8 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
[matroska,webm @ 000002638677f6c0] Could not find codec parameters for stream 9 (Attachment: none): unknown codec
[Parsed_subtitles_0 @ 00000263864d7dc0] Using font provider directwrite (with GDI)
[opus @ 00000263880ae140] Error parsing Opus packet header.
[matroska,webm @ 00000263870de800] Could not find codec parameters for stream 8 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
[matroska,webm @ 00000263870de800] Could not find codec parameters for stream 9 (Attachment: none): unknown codec
Metadata:
Chapters:
Metadata:
title : Chapter 01
Metadata:
title : Chapter 02
Metadata:
title : Chapter 03
Metadata:
title : Chapter 04
Metadata:
title : Chapter 05
Metadata:
title : Chapter 06
Metadata:
title : Chapter 07
Metadata:
title : Chapter 08
Metadata:
title : Chapter 09
Metadata:
title : Chapter 10
Metadata:
title : Chapter 11
Metadata:
title : Chapter 12
Metadata:
title : Chapter 13
Metadata:
title : Chapter 14
Metadata:
title : Chapter 15
Metadata:
title : Chapter 16
Metadata:
title : Chapter 17
Metadata:
title : Chapter 18
Metadata:
title : Chapter 19
Metadata:
title : Chapter 20
Metadata:
title : Chapter 21
Metadata:
title : Chapter 22
Metadata:
title : Chapter 23
Metadata:
title : Chapter 24
Metadata:
title : Chapter 25
Metadata:
title : Chapter 26
Metadata:
title : Chapter 27
Metadata:
title : Chapter 28
Metadata:
title : Chapter 29
Metadata:
title : Chapter 30
Metadata:
title : Chapter 31
Metadata:
title : Chapter 32
Metadata:
title : Chapter 33
Metadata:
title : Chapter 34
Metadata:
title : dAV1nci
BPS : 2784064
Metadata:
BPS : 320000
Metadata:
BPS : 320000
Metadata:
BPS : 256000
Metadata:
BPS : 256000
Metadata:
BPS : 61907
Metadata:
BPS : 41
Metadata:
BPS : 79
Metadata:
title : SDH
BPS : 15133
SOURCE_ID : 001201
Metadata:
Stream mapping:
Stream #0:0 (libaom-av1) -> subtitles:default
subtitles:default -> Stream #0:0 (mpeg2video)
Stream #0:0 -> #0:1 (av1 (libaom-av1) -> mpeg2video (native))
Stream #0:1 -> #0:2 (eac3 (native) -> ac3 (native))
Press [q] to stop, [?] for help
[Parsed_subtitles_0 @ 0000026388228480] libass API version: 0x1704000
[Parsed_subtitles_0 @ 0000026388228480] libass source: commit: 0.17.4-13-ge4215b0d175a5a340c0dbd7a990df82f07d71a34
[Parsed_subtitles_0 @ 0000026388228480] Shaper: FriBidi 1.0.16 (SIMPLE) HarfBuzz-ng 11.2.1 (COMPLEX)
[matroska,webm @ 00000263870de2c0] Could not find codec parameters for stream 8 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size
[matroska,webm @ 00000263870de2c0] Could not find codec parameters for stream 9 (Attachment: none): unknown codec
[Parsed_subtitles_0 @ 0000026388228480] Using font provider directwrite (with GDI)
[opus @ 00000263870cd5c0] Error parsing Opus packet header.
Output #0, vob, to 'test.mpg':
Metadata:
encoder : Lavf62.1.103
Chapters:
Chapter #0:0: start 0.007000, end 177.100583
Metadata:
title : Chapter 01
Chapter #0:1: start 177.100583, end 279.035750
Metadata:
title : Chapter 02
Chapter #0:2: start 279.035750, end 699.872833
Metadata:
title : Chapter 03
Chapter #0:3: start 699.872833, end 1017.898875
Metadata:
title : Chapter 04
Chapter #0:4: start 1017.898875, end 1192.948750
Metadata:
title : Chapter 05
Chapter #0:5: start 1192.948750, end 1528.951083
Metadata:
title : Chapter 06
Chapter #0:6: start 1528.951083, end 1658.080083
Metadata:
title : Chapter 07
Chapter #0:7: start 1658.080083, end 1769.441333
Metadata:
title : Chapter 08
Chapter #0:8: start 1769.441333, end 2026.781750
Metadata:
title : Chapter 09
Chapter #0:9: start 2026.781750, end 2468.556417
Metadata:
title : Chapter 10
Chapter #0:10: start 2468.556417, end 2737.408333
Metadata:
title : Chapter 11
Chapter #0:11: start 2737.408333, end 3056.477083
Metadata:
title : Chapter 12
Chapter #0:12: start 3056.477083, end 3281.702083
Metadata:
title : Chapter 13
Chapter #0:13: start 3281.702083, end 3513.642125
Metadata:
title : Chapter 14
Chapter #0:14: start 3513.642125, end 3835.964125
Metadata:
title : Chapter 15
Chapter #0:15: start 3835.964125, end 3965.218250
Metadata:
title : Chapter 16
Chapter #0:16: start 3965.218250, end 4330.583250
Metadata:
title : Chapter 17
Chapter #0:17: start 4330.583250, end 4731.775708
Metadata:
title : Chapter 18
Chapter #0:18: start 4731.775708, end 4981.441792
Metadata:
title : Chapter 19
Chapter #0:19: start 4981.441792, end 5222.140583
Metadata:
title : Chapter 20
Chapter #0:20: start 5222.140583, end 5269.187583
Metadata:
title : Chapter 21
Chapter #0:21: start 5269.187583, end 5407.659250
Metadata:
title : Chapter 22
Chapter #0:22: start 5407.659250, end 5570.780542
Metadata:
title : Chapter 23
Chapter #0:23: start 5570.780542, end 5915.499917
Metadata:
title : Chapter 24
Chapter #0:24: start 5915.499917, end 6047.006292
Metadata:
title : Chapter 25
Chapter #0:25: start 6047.006292, end 6335.461125
Metadata:
title : Chapter 26
Chapter #0:26: start 6335.461125, end 6581.456875
Metadata:
title : Chapter 27
Chapter #0:27: start 6581.456875, end 6919.586333
Metadata:
title : Chapter 28
Chapter #0:28: start 6919.586333, end 7026.067708
Metadata:
title : Chapter 29
Chapter #0:29: start 7026.067708, end 7288.121167
Metadata:
title : Chapter 30
Chapter #0:30: start 7288.121167, end 7893.309083
Metadata:
title : Chapter 31
Chapter #0:31: start 7893.309083, end 8277.526250
Metadata:
title : Chapter 32
Chapter #0:32: start 8277.526250, end 8433.348583
Metadata:
title : Chapter 33
Chapter #0:33: start 8433.348583, end 8931.751000
Metadata:
title : Chapter 34
Stream #0:0: Video: mpeg2video (Main), yuv420p(tv, progressive), 1920x872 [SAR 1:1 DAR 240:109], q=2-31, 200 kb/s, 23.98 fps, 90k tbn
Metadata:
encoder : Lavc62.8.100 mpeg2video
Side data:
cpb: bitrate max/min/avg: 89000000/0/200000 buffer size: 7000000 vbv_delay: N/A
Stream #0:1: Video: mpeg2video (Main), yuv420p(tv, progressive), 1920x872 [SAR 1:1 DAR 240:109], q=2-31, 200 kb/s, 23.98 fps, 90k tbn (default)
Metadata:
title : dAV1nci
BPS : 2784064
Side data:
Stream #0:2(eng): Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s (default)
Metadata:
encoder : Lavc62.8.100 ac3
BPS : 320000
frame= 244 fps= 95 q=1.0 q=1.0 size= 1024KiB time=00:00:10.13 bitrate= 827.7kbits/s speed=3.94x elapsed=0:00:02.57 frame= 545 fps=176 q=1.0 q=1.0 size= 2304KiB time=00:00:22.68 bitrate= 831.9kbits/s speed=7.34x elapsed=0:00:03.09 frame= 846 fps=235 q=1.0 q=1.0 size= 3584KiB time=00:00:35.24 bitrate= 833.1kbits/s speed=9.77x elapsed=0:00:03.60 frame= 1147 fps=278 q=1.0 q=1.0 size= 4864KiB time=00:00:47.79 bitrate= 833.6kbits/s speed=11.6x elapsed=0:00:04.12 frame= 1449 fps=313 q=1.0 q=1.0 size= 6144KiB time=00:01:00.39 bitrate= 833.4kbits/s speed= 13x elapsed=0:00:04.63 [out#0/vob @ 0000026388228c00] video:5728KiB audio:1728KiB subtitle:0KiB other streams:0KiB global headers:0KiB muxing overhead: 1.533944%
frame= 1765 fps=341 q=1.0 Lq=1.0 size= 7570KiB time=00:01:13.57 bitrate= 842.9kbits/s speed=14.2x elapsed=0:00:05.17
Exiting normally, received signal 2.Re: UMS and PS3 , subtitles issues with mkv
Yeah that looks good and confirms what I was seeing.
I think this may have be the cause of some problems some others reported in v14 that I was unable to track down, I never thought about running this in the command line at the time. I'll have to find that thread and go over it again to see how similar the results were.
IIRC I think it was happening on Anime and that sometimes has dual audio and it seemed to just stop too in the logs like it did in yours.
The fix for this is done and should be in the next release 15.2
The cause was an unaccounted change in how the FFmpeg command line works.
For a temporary workaround you could download an old version of FFmpeg here (ffmpeg-2023-07-02-git-50f34172e0-essentials_build.zip)
Extract it and rename it to ffmpeg-old.exe then save in the bin folder of the UMS installation which probably is "C:\Program Files\Universal Media Server\bin\"
Then when UMS is not running edit "C:\ProgramData\UMS\UMS.conf" to change
to
So the old version will be used when you next run UMS.
Once you get 15.2 then you can revert this change.
ffmpeg_path =Code: Select all
ffmpeg_path = C:\\Program Files\\Universal Media Server\\bin\\ffmpeg-old.exeOnce you get 15.2 then you can revert this change.
CaptainTom25
OK thank you, I was expecting a long wait :p I will try the workaround
CaptainTom25
For some reasons, it s not working for most videos.
It worked for old mkv 2001, space Odyssey (not affected by the susbtitle bug, where only one occurrence would be display) , but not for Impossible mission ( It has multiple subtitles, but only English forced is displayed, )
I also played some random videos, and none worked... see dbg file attached.
Any news concerning the subtitle not displaying bug, it was my original report ? Then the ffmpeg issue came to your attention !
- ums_dbg_2025-10-26-18-40.zip
- (1.08 MiB) Downloaded 762 times
