Problem on Linux Mint 22.3
boss
Re: Problem on Linux Mint 22.3
Post by boss »
"I tried UMS-13.0.0 as you suggested and the media scan completed without any problems."
That would suggest that there is nothing wrong with your system.
If you are willing, you could install a newer version so we can determine at which version the issue started.
Can you try: UMS-14.6.0-x86_64.tgz from the same download site.
iamthebull
Post by iamthebull »
I may have been mistaken when I reported that there are no issues with UMS-13.0.0 or I may have gotten lucky on the first attempt. There was an error showing up on the terminal and in the log file as soon as I booted the server. I attempted the media scan anyway and waited a few min. I didn't get any specific message about the scan completing but waited long enough that it should have completed and connected with the client. Everything seemed to be ok. So I attempted 14.6.0 and CRASH. Then 14.0.0, 13.10.0, 13.6.0 and 13.3.0 and they all CRASHED. So I tried 13.0.0 again and it CRASHED.
boss
Post by boss »
Can you try V12
https://www.videohelp.com/software/Univ ... d-versions
File = UMS-12.0.1-x86_64.tgz
Glad your memtest was good. It was a long shot but it rules that out.
Instead of deleting the database each time you can just clear the cache which will start a full scan. Might be easier.
I was looking into that malloc error too and found this on a forum for another music based program from last year.
I don't really understand what they are saying but seems to be a change in Glib that is causing a buffer overflow somewhere, or maybe this function.
gboxed: Use new g_string_copy() as boxed copy for GString
Maybe something similar is happening here.
I don't know if Glib is something that is part of the OS or was used when compiling UMS.
Since the previous versions of UMS is crashing too I am leaning toward a OS problem and something may need downgrading.
The devs will probably need to look into this further as this may be the cause of problems a few other people have had on Mint.
boss
Post by boss »
glibc was the other thing I mentioned.
For Mint information says it is highly discouraged trying to update glibc as it is a major component of the OS.
Information is that if their is a Mint version update available, this is the only way it should be done.
It's a hard one.
boss
Post by boss »
For Mint information says it is highly discouraged trying to update glibc.
glibc is a major component of the OS.
Information is that if there is a Mint version update available, this is the only way it should be done.
It's a hard one.
PS: Looks like Mint 22.3 is the latest.
iamthebull
With version 12.0.1 when I first added the folder the scan completed immediately and in the log file:
DEBUG 2026-06-28 09:45:23.114 [Library Scanner] Starting scan of: root
INFO  2026-06-28 09:45:23.115 [Library Scanner] Library scan completed in 0 seconds
but when I went to browse with a client it seems a scan of the browsed folder was triggered and it CRASHED with same malloc() error.
iamthebull
I have a computer with Linux Mint 21.3 so I tried UMS-15.6.0 on it and I was able to scan the same Music folder (mounted shared network folder in this case) without any issues. Seems the issue is present on Mint 22.3 and not 21.3. Log file attached.
debug.log.zip
(110.2 KiB) Downloaded 689 times
System info for Mint 21.3 install.
System:
  Kernel: 5.15.0-181-generic x86_64 bits: 64 compiler: gcc v: 11.4.0 Desktop: Cinnamon 6.0.4
    tk: GTK 3.24.33 wm: muffin vt: 7 dm: LightDM 1.30.0 Distro: Linux Mint 21.3 Virginia
    base: Ubuntu 22.04 jammy
Machine:
  Type: Laptop System: ASUSTeK product: N56VZ v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: N56VZ v: 1.0 serial: <superuser required> UEFI: American Megatrends
    v: N56VZ.217 date: 05/22/2013
CPU:
  Info: quad core model: Intel Core i7-3630QM bits: 64 type: MT MCP smt: enabled arch: Ivy Bridge
    rev: 9 cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
  Speed (MHz): avg: 1311 high: 1374 min/max: 1200/3400 cores: 1: 1225 2: 1354 3: 1272 4: 1261
    5: 1374 6: 1363 7: 1283 8: 1356 bogomips: 38312
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
  Device-1: Intel 3rd Gen Core processor Graphics vendor: ASUSTeK N56VZ driver: i915 v: kernel
    ports: active: LVDS-1 empty: VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
  Device-2: NVIDIA GK107M [GeForce GT 650M] vendor: ASUSTeK N56VZ driver: nouveau v: kernel
    pcie: speed: 2.5 GT/s lanes: 16 ports: active: none empty: HDMI-A-1 bus-ID: 01:00.0
    chip-ID: 10de:0fd1 class-ID: 0300
  Device-3: Suyin UVC HD Webcam type: USB driver: uvcvideo bus-ID: 1-1.3:4 chip-ID: 064e:d213
    class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: modesetting unloaded: fbdev,vesa
    gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
  Monitor-1: LVDS-1 model: Seiko Epson res: 1920x1080 hz: 60 dpi: 142
    size: 344x194mm (13.5x7.6") diag: 395mm (15.5") modes: 1920x1080
  OpenGL: renderer: Mesa Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 23.2.1-1ubuntu3.1~22.04.4
    direct render: Yes
Audio:
  Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK N56VZ
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20 class-ID: 0403
  Device-2: NVIDIA GK107 HDMI Audio driver: snd_hda_intel v: kernel pcie: speed: 2.5 GT/s
    lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
  Sound Server-1: ALSA v: k5.15.0-181-generic running: yes
  Sound Server-2: PulseAudio v: 15.99.1 running: yes
  Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
  Device-1: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel pcie: speed: 2.5 GT/s
    lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:0887 class-ID: 0280
  IF: wlp3s0 state: up mac: <filter>
  Device-2: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: ASUSTeK N56VZ driver: alx v: kernel
    pcie: speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 04:00.0 chip-ID: 1969:1091 class-ID: 0200
  IF: enp4s0 state: down mac: <filter>
Bluetooth:
  Device-1: Intel Centrino Bluetooth Wireless Transceiver type: USB driver: btusb v: 0.8
    bus-ID: 1-1.1:3 chip-ID: 8087:07da class-ID: e001
  Report: hciconfig ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block:
    hardware: no software: yes address: <filter>
Drives:
  Local Storage: total: 596.18 GiB used: 783.38 GiB (131.4%)
  ID-1: /dev/sda vendor: Phison model: SSB128GPTC0-S81 size: 119.24 GiB speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 06.9 scheme: GPT
  ID-2: /dev/sdb vendor: Samsung model: SSD 850 PRO 512GB size: 476.94 GiB speed: 3.0 Gb/s
    type: SSD serial: <filter> rev: 1B6Q scheme: MBR
Partition:
  ID-1: / size: 29.36 GiB used: 18.96 GiB (64.6%) fs: ext4 dev: /dev/sda3
  ID-2: /boot/efi size: 499 MiB used: 230.9 MiB (46.3%) fs: vfat dev: /dev/sda1
Swap:
  ID-1: swap-1 type: partition size: 1.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda2
USB:
  Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002
    class-ID: 0900
  Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0 speed: 480 Mb/s
    chip-ID: 8087:0024 class-ID: 0900
  Device-1: 1-1.1:3 info: Intel Centrino Bluetooth Wireless Transceiver type: Bluetooth
    driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s chip-ID: 8087:07da class-ID: e001
  Device-2: 1-1.3:4 info: Suyin UVC HD Webcam type: Video driver: uvcvideo interfaces: 2
    rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 064e:d213 class-ID: 0e02 serial: <filter>
  Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002
    class-ID: 0900
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0 speed: 480 Mb/s
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0 speed: 480 Mb/s
    chip-ID: 1d6b:0002 class-ID: 0900
  Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s chip-ID: 1d6b:0003
    class-ID: 0900
Sensors:
  System Temperatures: cpu: 49.0 C mobo: N/A gpu: nouveau temp: 42.0 C
  Fan Speeds (RPM): cpu: 1800
Repos:
  Packages: 2536 apt: 2535 flatpak: 1
  No active apt repos in: /etc/apt/sources.list
  Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
    1: deb https: //linuxmint.mirror.liquidtelecom.com/packages virginia main upstream import backport
    2: deb http: //archive.ubuntu.com/ubuntu jammy main restricted universe multiverse
    3: deb http: //archive.ubuntu.com/ubuntu jammy-updates main restricted universe multiverse
    4: deb http: //archive.ubuntu.com/ubuntu jammy-backports main restricted universe multiverse
    5: deb http: //security.ubuntu.com/ubuntu/ jammy-security main restricted universe multiverse
  Active apt repos in: /etc/apt/sources.list.d/vscode.sources
    1: deb [arch=amd64] https: //packages.microsoft.com/repos/code stable main
Info:
  Processes: 288 Uptime: 10m wakeups: 1 Memory: 15.5 GiB used: 2.46 GiB (15.8%) Init: systemd
  v: 249 runlevel: 5 Compilers: gcc: 11.4.0 alt: 11/12 Client: Cinnamon v: 6.0.4 inxi: 3.3.13
It might be a problem in Mint 22.3 but maybe it could still be a hardware problem.
Could you update the computer with 21.3 to 22.3?
Last time I used Mint I remember it does a system backup before a major upgrade so you can revert it.
If that one works just fine on 22.3 then it has to be a problem on the other computer.
I would still suspect the RAM in that one, maybe the mentest did not stress the memory enough and needs more cycles. I would let it run as long as possible.
You could also try removing ramsticks and only use one at a time for testing.
If the problem is something in Mint 22.3 I don't know how to narrow it down even further to troubleshoot.
Maybe something in UMS will need changing to totally fix this but I have no idea what.
boss
Post by boss »
I also think a good starting point from here is to try 1 x RAM module at a time as mik_s said.
Also, chack in your main logs for mailoc() issues.
grep "mailoc()" /var/log/messages
Also check your computer startup log.
dmesg | grep -i "malloc()"
Can you run the "free" command and check that your free memory is reporting correctly.
Mint 22.3 does use a newer kernel that 21.3 so 22.3 is a major change.
@mik_s
I found this information online:
The malloc(): corrupted top size error is a classic GNU C Library (glibc) memory corruption error. It occurs when your program writes outside the boundaries of allocated memory, overwriting the heap metadata (chunk sizes).
Here are the most effective ways to diagnose and resolve this issue:
2. Check for Specific Software Conflicts If this error occurs while using a third-party application like the Universal Media Server on Linux Mint, it often relates to outdated system libraries or Java environment mismatches.Ensure your Java Runtime Environment (JRE) is up to date.
If iamthebull has jre installed, do you think that it is worth configuring UMS to use that rather than the UMS supplied java?
PS: Some strange behaviour in the 21.3 UMS log:
DEBUG 2026-06-28 10:08:00.036 [main] Loading user profile: /home/david/.config/UMS/UMS.conf
DEBUG 2026-06-28 10:08:00.060 [main] Base path set to file:///home/david/.config/UMS/UMS.conf
DEBUG 2026-06-28 10:08:00.061 [main] Failed to load /home/david/.config/UMS/UMS.conf (Unable to load the configuration from the URL file:/home/david/.config/UMS/UMS.conf) - attempting to load skel profile
WARN 2026-06-28 10:08:00.061 [main] Can't load neither /home/david/.config/UMS/UMS.conf: Unable to load the configuration from the URL file:/home/david/.config/UMS/UMS.conf nor /etc/skel/.config/UMS/UMS.conf: Unable to load the configuration from the URL file:/etc/skel/.config/UMS/UMS.conf
Also
DEBUG 2026-06-28 10:08:48.098 [main] Added file watch at /home/david/Videos: /home/david/Videos/**
DEBUG 2026-06-28 10:08:48.099 [main] Added file watch at /home/david/Music: /home/david/Music/**
DEBUG 2026-06-28 10:08:48.100 [main] Added file watch at /home/david/Pictures: /home/david/Pictures/**
DEBUG 2026-06-28 10:08:48.101 [main] Added file watch at /home/david/Pictures/bed: /home/david/Pictures/**
DEBUG 2026-06-28 10:08:48.102 [main] Added file watch at /home/david/Public: /home/david/Public/**
Also
INFO 2026-06-28 10:19:24.609 [Media Scanner] Loading MediaInfo library
WARN 2026-06-28 10:19:24.621 [Media Scanner] Error loading libzen: Unable to load library 'zen':
libzen.so: cannot open shared object file: No such file or directory
Native library (linux-x86-64/libzen.so) not found in resource path (update.jar:ums.jar)
ERROR 2026-06-28 10:19:24.629 [Media Scanner] Error loading MediaInfo library: Unable to load library 'mediainfo':
libmediainfo.so: cannot open shared object file: No such file or directory
Native library (linux-x86-64/libmediainfo.so) not found in resource path (update.jar:ums.jar)
INFO 2026-06-28 10:19:24.629 [Media Scanner] Make sure you have libmediainfo and libzen installed
