Problem on Linux Mint 22.3
iamthebull
I installed UMS (15.6.0) on Linux Mint 22.3. The first time I ran the shell script I was prompted to use a config wizard and I said yes. The wizard asked a few setup questions then opened http://localhost:9001/ in my browser which showed an authentication page but then UMS crashed. The output on the terminal is below:
I ran the shell script a second time and again it crashed. The output:
What could be the issue here?
My system info:
david@Desktop1:~/Downloads/ums-15.6.0$ ./UMS.sh
14:53:26,657 |-INFO in ch.qos.logback.classic.model.processor.ConfigurationModelHandlerFull - Scan attribute not set or set to unrecognized value.
14:53:26,658 |-INFO in ch.qos.logback.core.model.processor.DefineModelHandler - About to instantiate property definer of type [net.pms.logging.DebugLogPropertyDefiner]
14:53:26,666 |-WARN in Logger[net.pms.configuration.UmsConfiguration] - No appenders present in context [default] for logger [net.pms.configuration.UmsConfiguration].
14:53:26,667 |-INFO in ch.qos.logback.core.model.processor.DefineModelHandler - Setting property logFilePath=/home/david/.config/UMS in scope LOCAL
14:53:26,667 |-INFO in ch.qos.logback.core.model.processor.DefineModelHandler - About to instantiate property definer of type [net.pms.logging.DebugLogPropertyDefiner]
14:53:26,667 |-INFO in ch.qos.logback.core.model.processor.DefineModelHandler - Setting property rootLevel=DEBUG in scope LOCAL
14:53:26,667 |-INFO in ch.qos.logback.core.model.processor.DefineModelHandler - Setting property logFileName=debug.log in scope LOCAL
14:53:26,669 |-INFO in ch.qos.logback.core.model.processor.AppenderModelHandler - Processing appender named [traces]
14:53:26,669 |-INFO in ch.qos.logback.core.model.processor.AppenderModelHandler - About to instantiate appender of type [net.pms.logging.GuiManagerAppender]
14:53:26,692 |-INFO in ch.qos.logback.core.model.processor.AppenderModelHandler - Processing appender named [console]
14:53:26,692 |-INFO in ch.qos.logback.core.model.processor.AppenderModelHandler - About to instantiate appender of type [ch.qos.logback.core.ConsoleAppender]
14:53:26,693 |-INFO in ch.qos.logback.core.ConsoleAppender[console] - NOTE: Writing to the console can be slow. Try to avoid logging to the
14:53:26,693 |-INFO in ch.qos.logback.core.ConsoleAppender[console] - console in production environments, especially in high volume systems.
14:53:26,693 |-INFO in ch.qos.logback.core.ConsoleAppender[console] - See also https://logback.qos.ch/codes.html#slowConsole
14:53:26,694 |-INFO in ch.qos.logback.core.model.processor.AppenderModelHandler - Processing appender named [default.log]
14:53:26,694 |-INFO in ch.qos.logback.core.model.processor.AppenderModelHandler - About to instantiate appender of type [net.pms.logging.UmsFileAppender]
14:53:26,696 |-INFO in ch.qos.logback.core.model.processor.ModelInterpretationContext@3a7442c7 - value "/home/david/.config/UMS/debug.log" substituted for "${logFilePath}${file.separator}${logFileName}"
14:53:26,701 |-WARN in net.pms.logging.UmsFileAppender[default.log] - Append mode is mandatory for RollingFileAppender. Defaulting to append=true.
14:53:26,701 |-INFO in net.pms.logging.UmsFileAppender[default.log] - Active log file name: /home/david/.config/UMS/debug.log
14:53:26,701 |-INFO in net.pms.logging.UmsFileAppender[default.log] - File property is set to [/home/david/.config/UMS/debug.log]
14:53:26,702 |-INFO in ch.qos.logback.classic.model.processor.LoggerModelHandler - Setting level of logger [org.apache] to WARN
14:53:26,702 |-INFO in ch.qos.logback.classic.model.processor.LoggerModelHandler - Setting level of logger [httpclient.wire] to WARN
14:53:26,702 |-INFO in ch.qos.logback.classic.model.processor.LoggerModelHandler - Setting level of logger [fm.last.musicbrainz.coverart] to WARN
14:53:26,702 |-INFO in ch.qos.logback.classic.model.processor.LoggerModelHandler - Setting level of logger [oshi] to WARN
14:53:26,702 |-INFO in ch.qos.logback.classic.model.processor.LoggerModelHandler - Setting level of logger [org.eclipse.jetty] to WARN
14:53:26,702 |-INFO in ch.qos.logback.classic.model.processor.LoggerModelHandler - Setting level of logger [com.zaxxer.hikari] to INFO
14:53:26,702 |-INFO in ch.qos.logback.core.model.processor.ModelInterpretationContext@3a7442c7 - value "DEBUG" substituted for "${rootLevel}"
14:53:26,702 |-INFO in ch.qos.logback.classic.model.processor.RootLoggerModelHandler - Setting level of ROOT logger to DEBUG
14:53:26,702 |-INFO in ch.qos.logback.core.model.processor.AppenderRefModelHandler - Attaching appender named [traces] to Logger[ROOT]
14:53:26,702 |-INFO in ch.qos.logback.core.model.processor.AppenderRefModelHandler - Attaching appender named [console] to Logger[ROOT]
14:53:26,702 |-INFO in ch.qos.logback.core.model.processor.AppenderRefModelHandler - Attaching appender named [default.log] to Logger[ROOT]
14:53:26,702 |-INFO in ch.qos.logback.core.model.processor.DefaultProcessor@4be29ed9 - End of configuration.
14:53:26,703 |-INFO in ch.qos.logback.classic.joran.JoranConfigurator@548d708a - Registering current configuration as safe fallback point
WARN 14:53:26.539 [main] Can't load neither /home/david/.config/UMS/UMS.conf: Unable to load the configuration from the URL file:/home/david/.config/UMS/UMS.conf nor /etc/skel/.config/UMS/UMS.conf: Unable to load the configuration from the URL file:/etc/skel/.config/UMS/UMS.conf
INFO 14:53:26.556 [main] Language not specified, defaulting to OS language.
ERROR 14:53:26.725 [main] Failed to write PID file: /home/david/.config/UMS/data/UMS.pid (No such file or directory)
INFO 14:53:26.867 [System Information Logger] System information:
OS: GNU/Linux Linux Mint 22.3 (Zena) build 6.17.0-35-generic 64-bit
JVM: OpenJDK 64-Bit Server VM 17.0.18 (64-bit) by BellSoft
JVM args: -Xmx1280M -Xss2048k -Dfile.encoding=UTF-8 -Djava.net.preferIPv4Stack=true -Djna.nosys=true
Language: English (United States)
Encoding: UTF-8 | resolved UTF-8 | native UTF-8 | jnu UTF-8 | stdout UTF-8 | stderr UTF-8
CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz with 4 cores (8 virtual cores) (Haswell (Client))
Physical Memory: 15.5 GiB
Free Memory: 11.9 GiB
Maximum JVM Memory: 1.3 GiB
Used network interfaces:
Intel Corporation Ethernet Connection I217-V, speed 1000 Mb/s
INFO 14:54:08.627 [main] Starting Universal Media Server 15.6.0
INFO 14:54:08.627 [main] Based on PS3 Media Server by shagrath, copyright 2008-2014
INFO 14:54:08.627 [main] https://www.universalmediaserver.com
INFO 14:54:08.627 [main] Build: 806496f92 (2026-04-25)
INFO 14:54:08.627 [main] Working directory: /home/david/Downloads/ums-15.6.0
INFO 14:54:08.628 [main] Temporary directory: /tmp/UMS-david
INFO 14:54:08.629 [main] Logging configuration file: /home/david/Downloads/ums-15.6.0/logback.xml
INFO 14:54:08.629 [main] Logfile: /home/david/.config/UMS/debug.log
INFO 14:54:08.629 [main] Profile directory: /home/david/.config/UMS
INFO 14:54:08.629 [main] Profile directory permissions: drwx
INFO 14:54:08.629 [main] Profile configuration file: /home/david/.config/UMS/UMS.conf
INFO 14:54:08.629 [main] Profile configuration file permissions: -rw-
INFO 14:54:08.630 [main] Profile name: Desktop1
INFO 14:54:08.637 [main] Using database engine version 2.4.240
INFO 14:54:08.639 [main] Database may use 80 MB for caching
INFO 14:54:08.640 [main] Using "medias" database located at: "/home/david/.config/UMS/database"
INFO 14:54:08.645 [main] HikariPool-1 - Starting...
INFO 14:54:08.836 [main] HikariPool-1 - Added connection conn0: url=jdbc:h2:/home/david/.config/UMS/database/medias user=SA
INFO 14:54:08.837 [main] HikariPool-1 - Start completed.
INFO 14:54:08.913 [main] Creating database "medias" table: "TABLES_VERSIONS"
INFO 14:54:08.921 [main] Creating database "medias" table: "METADATA"
INFO 14:54:08.937 [main] Creating database "medias" table: "FILES"
INFO 14:54:08.951 [main] Creating database "medias" table: "VIDEO_METADATA"
INFO 14:54:08.963 [main] Creating database "medias" table: "VIDEOTRACKS"
INFO 14:54:08.969 [main] Creating database "medias" table: "SUBTRACKS"
INFO 14:54:08.975 [main] Creating database "medias" table: "CHAPTERS"
INFO 14:54:09.004 [main] Creating database "medias" table: "COVER_ART_ARCHIVE"
INFO 14:54:09.008 [main] Creating database "medias" table: "FILES_STATUS"
INFO 14:54:09.015 [main] Creating database "medias" table: "THUMBNAILS"
INFO 14:54:09.021 [main] Creating database "medias" table: "TV_SERIES"
INFO 14:54:09.030 [main] Creating database "medias" table: "FAILED_LOOKUPS"
INFO 14:54:09.035 [main] Creating database "medias" table: "VIDEO_METADATA_ACTORS"
INFO 14:54:09.041 [main] Creating database "medias" table: "VIDEO_METADATA_AWARDS"
INFO 14:54:09.051 [main] Creating database "medias" table: "VIDEO_METADATA_COUNTRIES"
INFO 14:54:09.056 [main] Creating database "medias" table: "VIDEO_METADATA_DIRECTORS"
INFO 14:54:09.065 [main] Creating database "medias" table: "VIDEO_METADATA_GENRES"
INFO 14:54:09.070 [main] Creating database "medias" table: "VIDEO_METADATA_RATINGS"
INFO 14:54:09.077 [main] Creating database "medias" table: "VIDEO_METADATA_LOCALIZED"
INFO 14:54:09.083 [main] Creating database "medias" table: "TV_SEASON_METADATA_LOCALIZED"
INFO 14:54:09.088 [main] Creating database "medias" table: "AUDIO_METADATA"
INFO 14:54:09.098 [main] Creating database "medias" table: "AUDIOTRACKS"
INFO 14:54:09.108 [main] Creating database "medias" table: "CONTAINER_FILES"
INFO 14:54:09.112 [main] Creating database "medias" table: "STORE_IDS"
INFO 14:54:09.119 [main] Using database engine version 2.4.240
INFO 14:54:09.119 [main] Database may use 80 MB for caching
INFO 14:54:09.119 [main] Using "USERS" database located at: "/home/david/.config/UMS/database"
INFO 14:54:09.120 [main] HikariPool-2 - Starting...
INFO 14:54:09.126 [main] HikariPool-2 - Added connection conn7: url=jdbc:h2:/home/david/.config/UMS/database/USERS user=SA
INFO 14:54:09.127 [main] HikariPool-2 - Start completed.
INFO 14:54:09.130 [main] Creating database "USERS" table: "TABLES_VERSIONS"
INFO 14:54:09.132 [main] Creating database "USERS" table: "GROUPS"
INFO 14:54:09.136 [main] Creating database "USERS" table: "USERS"
INFO 14:54:09.174 [main] Finding user id: -1
INFO 14:54:09.178 [main] Importing old shared content configuration files
INFO 14:55:17.493 [main] Configuration saved to "/home/david/.config/UMS/UMS.conf"
INFO 14:55:18.360 [main] Starting Jetty server 12.1.8
INFO 14:55:18.410 [main] GUI is available at: http://localhost:9001
INFO 14:55:18.413 [main] Starting Jetty server 12.1.8
INFO 14:55:18.423 [main] Finding user id: -1
INFO 14:55:18.424 [main] Loading renderer and device configurations from /home/david/Downloads/ums-15.6.0/renderers
INFO 14:55:18.700 [main] Enabled 217 configurations, listed in order of loading priority:
INFO 14:55:18.700 [main] : Samsung 2021 AU8/AU7/BEA/32Q6
INFO 14:55:18.700 [main] : LG TV 2025+
INFO 14:55:18.700 [main] : Mirascreen
INFO 14:55:18.700 [main] : Samsung 2021 AU9/Q6/43Q7/50Q7
INFO 14:55:18.700 [main] : Samsung 2021+ NEO QLED TV 8K
INFO 14:55:18.700 [main] : Sony Bravia XBR OLED
INFO 14:55:18.700 [main] : Amazon Fire TV Stick Vimu Player
INFO 14:55:18.700 [main] : BubbleUPnP
INFO 14:55:18.700 [main] : Chromecast Ultra
INFO 14:55:18.700 [main] : LG LCD TV (2014)
INFO 14:55:18.700 [main] : LG LED-backlit LCD TV (2022+)
INFO 14:55:18.700 [main] : LG LM660
INFO 14:55:18.700 [main] : LG LS5700
INFO 14:55:18.700 [main] : LG OLED
INFO 14:55:18.700 [main] : LG OLED 2020/2021
INFO 14:55:18.700 [main] : LG OLED 2022
INFO 14:55:18.700 [main] : LG TV 2023+
INFO 14:55:18.700 [main] : Naim Mu-So
INFO 14:55:18.700 [main] : Panasonic AS600
INFO 14:55:18.700 [main] : Panasonic AS650
INFO 14:55:18.700 [main] : Panasonic BDT220
INFO 14:55:18.700 [main] : Panasonic BDT360
INFO 14:55:18.700 [main] : Panasonic CX680
INFO 14:55:18.701 [main] : Panasonic CX700
INFO 14:55:18.701 [main] : Panasonic DX
INFO 14:55:18.701 [main] : Panasonic E6
INFO 14:55:18.701 [main] : Panasonic ET60
INFO 14:55:18.701 [main] : Panasonic GT50
INFO 14:55:18.701 [main] : Panasonic GX800B
INFO 14:55:18.701 [main] : Panasonic Home Theater (SC-BTT)
INFO 14:55:18.701 [main] : Panasonic HZ1500
INFO 14:55:18.701 [main] : Panasonic S60
INFO 14:55:18.701 [main] : Panasonic ST60
INFO 14:55:18.701 [main] : Panasonic VT60
INFO 14:55:18.701 [main] : Philips 6500 Series TV
INFO 14:55:18.701 [main] : Philips Android TV
INFO 14:55:18.701 [main] : Samsung 2021 Q5
INFO 14:55:18.701 [main] : Samsung 2021+ QLED TV
INFO 14:55:18.701 [main] : Samsung EH5300
INFO 14:55:18.701 [main] : Samsung Note Tab
INFO 14:55:18.701 [main] : Samsung Q7 Series
INFO 14:55:18.701 [main] : Samsung Soundbar MS750
INFO 14:55:18.701 [main] : Skybox VR Player
INFO 14:55:18.701 [main] : Sony Blu-ray (2013)
INFO 14:55:18.701 [main] : Sony Bluray BDP-S3700
INFO 14:55:18.701 [main] : Sony Bluray UBP-X800M2
INFO 14:55:18.701 [main] : Sony Bravia EX
INFO 14:55:18.701 [main] : Sony Bravia HX
INFO 14:55:18.701 [main] : Sony Bravia W
INFO 14:55:18.701 [main] : Sony Bravia X
INFO 14:55:18.701 [main] : Sony Bravia XBR
INFO 14:55:18.701 [main] : Sony Bravia XD/XE/XF
INFO 14:55:18.701 [main] : Sony Bravia XH
INFO 14:55:18.701 [main] : Sony Bravia XR
INFO 14:55:18.701 [main] : Sony X Series TV
INFO 14:55:18.701 [main] : VLC for Apple TV 4K
INFO 14:55:18.701 [main] : VLC for iOS or macOS
INFO 14:55:18.701 [main] : Xperia Z3
INFO 14:55:18.702 [main] : Bigscreen
INFO 14:55:18.702 [main] : Chromecast
INFO 14:55:18.702 [main] : Denon AVR-4311CI
INFO 14:55:18.702 [main] : Denon AVR-X4200W
INFO 14:55:18.702 [main] : Hisense K680
INFO 14:55:18.702 [main] : LG Blu-ray Player (BP550)
INFO 14:55:18.702 [main] : LG EG910V
INFO 14:55:18.702 [main] : LG LED-backlit LCD TV
INFO 14:55:18.702 [main] : LG UB820V
INFO 14:55:18.702 [main] : LG UH770
INFO 14:55:18.702 [main] : LG WebOS TV
INFO 14:55:18.702 [main] : Lumin U1 Mini
INFO 14:55:18.702 [main] : Onkyo TX-NR8xx
INFO 14:55:18.702 [main] : Panasonic DMR
INFO 14:55:18.702 [main] : Panasonic TV
INFO 14:55:18.702 [main] : Samsung 2018 QLED TV
INFO 14:55:18.702 [main] : Samsung 5300 Series
INFO 14:55:18.702 [main] : Samsung 8 Series
INFO 14:55:18.702 [main] : Samsung 8K TV 2019+
INFO 14:55:18.702 [main] : Samsung 9 Series
INFO 14:55:18.702 [main] : Samsung BD-C6800
INFO 14:55:18.702 [main] : Samsung D6400
INFO 14:55:18.702 [main] : Samsung D7000
INFO 14:55:18.702 [main] : Samsung EH6070
INFO 14:55:18.702 [main] : Samsung ES6100
INFO 14:55:18.702 [main] : Samsung ES6575
INFO 14:55:18.702 [main] : Samsung ES8000
INFO 14:55:18.702 [main] : Samsung ES8005
INFO 14:55:18.702 [main] : Samsung F5100
INFO 14:55:18.702 [main] : Samsung F5505
INFO 14:55:18.702 [main] : Samsung F5900
INFO 14:55:18.702 [main] : Samsung H4500
INFO 14:55:18.702 [main] : Samsung H6203
INFO 14:55:18.702 [main] : Samsung H6400
INFO 14:55:18.703 [main] : Samsung H6500
INFO 14:55:18.703 [main] : Samsung HT-E3 Series
INFO 14:55:18.703 [main] : Samsung HT-F4
INFO 14:55:18.703 [main] : Samsung J55xx Series
INFO 14:55:18.703 [main] : Samsung J6200
INFO 14:55:18.703 [main] : Samsung LED UHD
INFO 14:55:18.703 [main] : Samsung PL51E490
INFO 14:55:18.703 [main] : Samsung Q9 Series
INFO 14:55:18.703 [main] : Samsung Soundbar
INFO 14:55:18.703 [main] : Samsung The Frame
INFO 14:55:18.703 [main] : Samsung UHD TV 2019+
INFO 14:55:18.703 [main] : Sony Blu-ray
INFO 14:55:18.703 [main] : Sony Bravia EX725
INFO 14:55:18.703 [main] : Sony SA-NS310
INFO 14:55:18.703 [main] : Vizio Smart TV
INFO 14:55:18.703 [main] : VLC for Apple TV
INFO 14:55:18.703 [main] : VLC for iOS (iPhone 5 or older)
INFO 14:55:18.703 [main] : Xbox One
INFO 14:55:18.703 [main] : Yamaha R-N303
INFO 14:55:18.703 [main] : Yamaha R-N500
INFO 14:55:18.703 [main] : Yamaha RX-A1010
INFO 14:55:18.703 [main] : Yamaha RX-A2050
INFO 14:55:18.703 [main] : Yamaha RX-V3900
INFO 14:55:18.703 [main] : Yamaha RX-V500D
INFO 14:55:18.703 [main] : Yamaha RX-V671
INFO 14:55:18.703 [main] : AirPlayer
INFO 14:55:18.703 [main] : Android
INFO 14:55:18.704 [main] : AnyCast
INFO 14:55:18.704 [main] : Apple iPad / iPhone
INFO 14:55:18.704 [main] : Azur BD
INFO 14:55:18.704 [main] : BRAVIA KDL-xxNX800
INFO 14:55:18.704 [main] : Bush Freeview Set Top Box
INFO 14:55:18.704 [main] : Caliber HPG336DAB/DIR
INFO 14:55:18.704 [main] : D-Link DSM-510
INFO 14:55:18.704 [main] : DirecTV
INFO 14:55:18.704 [main] : Fetch TV
INFO 14:55:18.704 [main] : foobar2000 mobile
INFO 14:55:18.704 [main] : Freebox
INFO 14:55:18.704 [main] : Freecom MusicPal
INFO 14:55:18.704 [main] : Hama IR320
INFO 14:55:18.704 [main] : KalemSoft Media Player
INFO 14:55:18.704 [main] : Kodi
INFO 14:55:18.704 [main] : LG Blu-ray Player (BDP)
INFO 14:55:18.704 [main] : LG Blu-ray Player (BP)
INFO 14:55:18.704 [main] : LG LA6200
INFO 14:55:18.704 [main] : LG LA644V
INFO 14:55:18.704 [main] : LG LM620
INFO 14:55:18.704 [main] : LG NANO TV
INFO 14:55:18.704 [main] : LG Smart TV Upgrader
INFO 14:55:18.704 [main] : Linn App (control point)
INFO 14:55:18.704 [main] : Logitech Squeezebox
INFO 14:55:18.704 [main] : Lumin
INFO 14:55:18.704 [main] : MediaPlayer
INFO 14:55:18.704 [main] : Miracast M806
INFO 14:55:18.705 [main] : Movian
INFO 14:55:18.705 [main] : Naim Mu-So Qb
INFO 14:55:18.705 [main] : Netgear NeoTV
INFO 14:55:18.705 [main] : Netgem N7700
INFO 14:55:18.705 [main] : NextCP2
INFO 14:55:18.705 [main] : Nokia N900
INFO 14:55:18.705 [main] : Onkyo TX-NR7xx
INFO 14:55:18.705 [main] : OPPO BDP
INFO 14:55:18.705 [main] : OPPO BDP-83
INFO 14:55:18.705 [main] : Panasonic BDT
INFO 14:55:18.705 [main] : Panasonic TX-L32V10E
INFO 14:55:18.705 [main] : Panasonic U30Z
INFO 14:55:18.705 [main] : Philips Aurea
INFO 14:55:18.705 [main] : Philips PUS TV
INFO 14:55:18.705 [main] : Philips TV
INFO 14:55:18.705 [main] : Pigasus
INFO 14:55:18.705 [main] : Pioneer BDP
INFO 14:55:18.705 [main] : Pioneer Kuro
INFO 14:55:18.705 [main] : PlayStation 3
INFO 14:55:18.705 [main] : PlayStation 4
INFO 14:55:18.705 [main] : PlayStation Vita
INFO 14:55:18.705 [main] : Popcorn Hour
INFO 14:55:18.705 [main] : Realtek
INFO 14:55:18.705 [main] : Roku (DVP 10)
INFO 14:55:18.705 [main] : Roku 3 (NSP 3)
INFO 14:55:18.705 [main] : Roku 3 (NSP 5)
INFO 14:55:18.705 [main] : Roku 3 (NSP 6-7)
INFO 14:55:18.705 [main] : Roku 4 (NSP 6-7)
INFO 14:55:18.705 [main] : Roku TV
INFO 14:55:18.706 [main] : Roku TV (NSP 8)
INFO 14:55:18.706 [main] : Roku TV 4K
INFO 14:55:18.706 [main] : Roku Ultra
INFO 14:55:18.706 [main] : Samsung C/D Series
INFO 14:55:18.706 [main] : Samsung C6600
INFO 14:55:18.706 [main] : Samsung E+ Series
INFO 14:55:18.706 [main] : Samsung Galaxy S5
INFO 14:55:18.706 [main] : Samsung Galaxy S7
INFO 14:55:18.706 [main] : Samsung Mobile
INFO 14:55:18.706 [main] : Samsung OLED
INFO 14:55:18.706 [main] : Samsung SMT-G7400
INFO 14:55:18.706 [main] : Samsung WiseLink
INFO 14:55:18.706 [main] : Sharp Aquos
INFO 14:55:18.706 [main] : Showtime 3
INFO 14:55:18.706 [main] : Showtime 4
INFO 14:55:18.706 [main] : Sony Bravia
INFO 14:55:18.706 [main] : Sony Bravia 4500
INFO 14:55:18.706 [main] : Sony Bravia 5500
INFO 14:55:18.706 [main] : Sony Bravia AG
INFO 14:55:18.706 [main] : Sony Bravia BX305
INFO 14:55:18.706 [main] : Sony Bravia EX620
INFO 14:55:18.706 [main] : Sony Bravia HX75
INFO 14:55:18.706 [main] : Sony Bravia NX70x
INFO 14:55:18.706 [main] : Sony Home Theatre System
INFO 14:55:18.706 [main] : Sony SMP-N100
INFO 14:55:18.706 [main] : Sony STR-DA5800ES
INFO 14:55:18.706 [main] : Sony STR-DN1080
INFO 14:55:18.706 [main] : Sony Xperia Z/ZL/ZQ/Z1/Z2
INFO 14:55:18.706 [main] : Streamium
INFO 14:55:18.706 [main] : Technisat S1+
INFO 14:55:18.707 [main] : Telefunken TV
INFO 14:55:18.707 [main] : Telstra T-Box
INFO 14:55:18.707 [main] : Thomson U3 Series
INFO 14:55:18.707 [main] : UnknownRenderer
INFO 14:55:18.707 [main] : VideoWeb TV
INFO 14:55:18.707 [main] : VLC for desktop
INFO 14:55:18.707 [main] : WD TV Live
INFO 14:55:18.707 [main] : WiiM
INFO 14:55:18.707 [main] : Windows Media Player
INFO 14:55:18.707 [main] : XBMC
INFO 14:55:18.707 [main] : Xbox 360
INFO 14:55:18.707 [main] : Yamaha AV Receiver
INFO 14:55:18.707 [main] Checking the fontconfig cache in the background, this can take two minutes or so.
INFO 14:55:18.747 [main] Configuration saved to "/home/david/.config/UMS/UMS.conf"
INFO 14:55:18.788 [main] Transcoding engine "FFmpeg Audio" is available
INFO 14:55:18.886 [main] Transcoding engine "MEncoder Video" is available
INFO 14:55:18.886 [main] Transcoding engine "FFmpeg Video" is available
INFO 14:55:18.891 [main] Transcoding engine "VLC Video" is available
INFO 14:55:18.892 [main] Transcoding engine "FFmpeg HLS Video" is available
INFO 14:55:18.893 [main] Transcoding engine "FFmpeg Web Video" is available
INFO 14:55:18.893 [main] Transcoding engine "MEncoder Web Video" is available
INFO 14:55:18.893 [main] Transcoding engine "VLC Web Video" is available
INFO 14:55:18.896 [main] Transcoding engine "tsMuxeR Video" is available
INFO 14:55:18.896 [main] Transcoding engine "tsMuxeR Audio" is available
INFO 14:55:18.897 [main] Transcoding engine "VLC Web Audio (Legacy)" is available
INFO 14:55:18.897 [main] Transcoding engine "VLC Web Video (Legacy)" is available
INFO 14:55:18.901 [main] Transcoding engine "DCRaw" is available
INFO 14:55:18.901 [main] Transcoding engine "youtube-dl" is available
INFO 14:55:19.126 [main] Generated new random UUID: f9c33979-ed94-41df-9b98-012aa48394cd
INFO 14:55:19.127 [main] Configuration saved to "/home/david/.config/UMS/UMS.conf"
INFO 14:55:19.127 [main] Using the following UUID configured in UMS.conf: f9c33979-ed94-41df-9b98-012aa48394cd
INFO 14:55:19.212 [main] Starting UPnP service...
INFO 14:55:19.241 [main] Registering UPnP servlet under context path:
INFO 14:55:19.249 [jupnp-stream-server 5-1] Starting Jetty server 12.1.8
INFO 14:55:19.260 [main] Starting Jetty HTTP client v12.1.8 connection manager/pool
INFO 14:55:19.288 [jupnp-multicast-receiver 3-1] IP Filter: Access allowed to 10.0.1.2
INFO 14:55:19.749 [main] Web player is available at: http://10.0.1.2:9002
INFO 14:55:20.556 [Web GUI browser] Launching the graphical interface on a browser
INFO 14:55:20.556 [main] Universal Media Server is now available for renderers to find
INFO 14:55:20.556 [Media Scanner] Media scan started
INFO 14:55:20.628 [Media Scanner] Loading MediaInfo library
INFO 14:55:20.646 [Media Scanner] Loaded MediaInfoLib - v24.01
INFO 14:55:21.378 [webgui-server-69] Checking user table have admin
INFO 14:55:21.380 [webgui-server-167] Checking user table have admin
WARN 14:55:21.521 [webgui-server-65] Error verifying JWT: The token was expected to have 3 parts, but got 0.
WARN 14:55:21.522 [webgui-server-65] Error verifying JWT: The token was expected to have 3 parts, but got 0.
malloc(): invalid size (unsorted)
Aborted (core dumped)Code: Select all
15:02:11,318 |-INFO in ch.qos.logback.classic.model.processor.ConfigurationModelHandlerFull - Scan attribute not set or set to unrecognized value.
15:02:11,319 |-INFO in ch.qos.logback.core.model.processor.DefineModelHandler - About to instantiate property definer of type [net.pms.logging.DebugLogPropertyDefiner]
15:02:11,327 |-WARN in Logger[net.pms.configuration.UmsConfiguration] - No appenders present in context [default] for logger [net.pms.configuration.UmsConfiguration].
15:02:11,327 |-INFO in ch.qos.logback.core.model.processor.DefineModelHandler - Setting property logFilePath=/home/david/.config/UMS in scope LOCAL
15:02:11,327 |-INFO in ch.qos.logback.core.model.processor.DefineModelHandler - About to instantiate property definer of type [net.pms.logging.DebugLogPropertyDefiner]
15:02:11,327 |-INFO in ch.qos.logback.core.model.processor.DefineModelHandler - Setting property rootLevel=DEBUG in scope LOCAL
15:02:11,327 |-INFO in ch.qos.logback.core.model.processor.DefineModelHandler - Setting property logFileName=debug.log in scope LOCAL
15:02:11,329 |-INFO in ch.qos.logback.core.model.processor.AppenderModelHandler - Processing appender named [traces]
15:02:11,329 |-INFO in ch.qos.logback.core.model.processor.AppenderModelHandler - About to instantiate appender of type [net.pms.logging.GuiManagerAppender]
15:02:11,352 |-INFO in ch.qos.logback.core.model.processor.AppenderModelHandler - Processing appender named [console]
15:02:11,352 |-INFO in ch.qos.logback.core.model.processor.AppenderModelHandler - About to instantiate appender of type [ch.qos.logback.core.ConsoleAppender]
15:02:11,353 |-INFO in ch.qos.logback.core.ConsoleAppender[console] - NOTE: Writing to the console can be slow. Try to avoid logging to the
15:02:11,353 |-INFO in ch.qos.logback.core.ConsoleAppender[console] - console in production environments, especially in high volume systems.
15:02:11,353 |-INFO in ch.qos.logback.core.ConsoleAppender[console] - See also https://logback.qos.ch/codes.html#slowConsole
15:02:11,353 |-INFO in ch.qos.logback.core.model.processor.AppenderModelHandler - Processing appender named [default.log]
15:02:11,353 |-INFO in ch.qos.logback.core.model.processor.AppenderModelHandler - About to instantiate appender of type [net.pms.logging.UmsFileAppender]
15:02:11,354 |-INFO in ch.qos.logback.core.model.processor.ModelInterpretationContext@66982506 - value "/home/david/.config/UMS/debug.log" substituted for "${logFilePath}${file.separator}${logFileName}"
15:02:11,358 |-INFO in net.pms.logging.UmsFileAppender[default.log] - The previous log will be compressed to [/home/david/.config/UMS/debug.log.prev.zip].
15:02:11,359 |-INFO in net.pms.logging.UmsCompressor - The target compressed file named [/home/david/.config/UMS/debug.log.zip] will be appended.
15:02:11,378 |-INFO in net.pms.logging.UmsCompressor - ZIP compressing [/home/david/.config/UMS/debug.log] as [debug.0000.log]
15:02:11,394 |-WARN in net.pms.logging.UmsFileAppender[default.log] - Append mode is mandatory for RollingFileAppender. Defaulting to append=true.
15:02:11,394 |-INFO in net.pms.logging.UmsFileAppender[default.log] - Active log file name: /home/david/.config/UMS/debug.log
15:02:11,394 |-INFO in net.pms.logging.UmsFileAppender[default.log] - File property is set to [/home/david/.config/UMS/debug.log]
15:02:11,394 |-INFO in ch.qos.logback.classic.model.processor.LoggerModelHandler - Setting level of logger [org.apache] to WARN
15:02:11,394 |-INFO in ch.qos.logback.classic.model.processor.LoggerModelHandler - Setting level of logger [httpclient.wire] to WARN
15:02:11,394 |-INFO in ch.qos.logback.classic.model.processor.LoggerModelHandler - Setting level of logger [fm.last.musicbrainz.coverart] to WARN
15:02:11,394 |-INFO in ch.qos.logback.classic.model.processor.LoggerModelHandler - Setting level of logger [oshi] to WARN
15:02:11,394 |-INFO in ch.qos.logback.classic.model.processor.LoggerModelHandler - Setting level of logger [org.eclipse.jetty] to WARN
15:02:11,394 |-INFO in ch.qos.logback.classic.model.processor.LoggerModelHandler - Setting level of logger [com.zaxxer.hikari] to INFO
15:02:11,394 |-INFO in ch.qos.logback.core.model.processor.ModelInterpretationContext@66982506 - value "DEBUG" substituted for "${rootLevel}"
15:02:11,395 |-INFO in ch.qos.logback.classic.model.processor.RootLoggerModelHandler - Setting level of ROOT logger to DEBUG
15:02:11,395 |-INFO in ch.qos.logback.core.model.processor.AppenderRefModelHandler - Attaching appender named [traces] to Logger[ROOT]
15:02:11,395 |-INFO in ch.qos.logback.core.model.processor.AppenderRefModelHandler - Attaching appender named [console] to Logger[ROOT]
15:02:11,395 |-INFO in ch.qos.logback.core.model.processor.AppenderRefModelHandler - Attaching appender named [default.log] to Logger[ROOT]
15:02:11,395 |-INFO in ch.qos.logback.core.model.processor.DefaultProcessor@70cf32e3 - End of configuration.
15:02:11,395 |-INFO in ch.qos.logback.classic.joran.JoranConfigurator@5a59ca5e - Registering current configuration as safe fallback point
INFO 15:02:11.541 [System Information Logger] System information:
Language: English (United Kingdom)
Free Memory: 11.7 GiB
INFO 15:02:11.882 [main] Starting Universal Media Server 15.6.0
INFO 15:02:11.882 [main] Based on PS3 Media Server by shagrath, copyright 2008-2014
INFO 15:02:11.882 [main] https://www.universalmediaserver.com
INFO 15:02:11.882 [main] Build: 806496f92 (2026-04-25)
INFO 15:02:11.882 [main] Working directory: /home/david/Downloads/ums-15.6.0
INFO 15:02:11.883 [main] Temporary directory: /tmp/UMS-david
INFO 15:02:11.883 [main] Logging configuration file: /home/david/Downloads/ums-15.6.0/logback.xml
INFO 15:02:11.883 [main] Logfile: /home/david/.config/UMS/debug.log
INFO 15:02:11.883 [main] Profile directory: /home/david/.config/UMS
INFO 15:02:11.883 [main] Profile directory permissions: drwx
INFO 15:02:11.883 [main] Profile configuration file: /home/david/.config/UMS/UMS.conf
INFO 15:02:11.884 [main] Profile configuration file permissions: -rw-
INFO 15:02:11.884 [main] Profile name: Desktop1
INFO 15:02:11.890 [main] Using database engine version 2.4.240
INFO 15:02:11.892 [main] Database may use 80 MB for caching
INFO 15:02:11.892 [main] Using "medias" database located at: "/home/david/.config/UMS/database"
INFO 15:02:11.896 [main] HikariPool-1 - Starting...
INFO 15:02:12.177 [main] HikariPool-1 - Added connection conn0: url=jdbc:h2:/home/david/.config/UMS/database/medias user=SA
INFO 15:02:12.179 [main] HikariPool-1 - Start completed.
INFO 15:02:12.288 [main] Using database engine version 2.4.240
INFO 15:02:12.288 [main] Database may use 80 MB for caching
INFO 15:02:12.289 [main] Using "USERS" database located at: "/home/david/.config/UMS/database"
INFO 15:02:12.289 [main] HikariPool-2 - Starting...
INFO 15:02:12.298 [main] HikariPool-2 - Added connection conn2: url=jdbc:h2:/home/david/.config/UMS/database/USERS user=SA
INFO 15:02:12.298 [main] HikariPool-2 - Start completed.
INFO 15:02:12.327 [main] Finding user id: -1
INFO 15:02:12.331 [main] Getting shared content from configuration file : /home/david/.config/UMS/SHARED.conf
INFO 15:02:13.776 [main] Starting Jetty server 12.1.8
INFO 15:02:13.827 [main] GUI is available at: http://localhost:9001
INFO 15:02:13.830 [main] Starting Jetty server 12.1.8
INFO 15:02:13.839 [main] Finding user id: -1
INFO 15:02:13.840 [main] Loading renderer and device configurations from /home/david/Downloads/ums-15.6.0/renderers
INFO 15:02:14.073 [main] Enabled 217 configurations, listed in order of loading priority:
INFO 15:02:14.073 [main] : Samsung 2021 AU8/AU7/BEA/32Q6
INFO 15:02:14.073 [main] : LG TV 2025+
INFO 15:02:14.073 [main] : Mirascreen
INFO 15:02:14.073 [main] : Samsung 2021 AU9/Q6/43Q7/50Q7
INFO 15:02:14.073 [main] : Samsung 2021+ NEO QLED TV 8K
INFO 15:02:14.073 [main] : Sony Bravia XBR OLED
INFO 15:02:14.073 [main] : Amazon Fire TV Stick Vimu Player
INFO 15:02:14.073 [main] : BubbleUPnP
INFO 15:02:14.073 [main] : Chromecast Ultra
INFO 15:02:14.073 [main] : LG LCD TV (2014)
INFO 15:02:14.074 [main] : LG LED-backlit LCD TV (2022+)
INFO 15:02:14.074 [main] : LG LM660
INFO 15:02:14.074 [main] : LG LS5700
INFO 15:02:14.074 [main] : LG OLED
INFO 15:02:14.074 [main] : LG OLED 2020/2021
INFO 15:02:14.074 [main] : LG OLED 2022
INFO 15:02:14.074 [main] : LG TV 2023+
INFO 15:02:14.074 [main] : Naim Mu-So
INFO 15:02:14.074 [main] : Panasonic AS600
INFO 15:02:14.074 [main] : Panasonic AS650
INFO 15:02:14.074 [main] : Panasonic BDT220
INFO 15:02:14.074 [main] : Panasonic BDT360
INFO 15:02:14.074 [main] : Panasonic CX680
INFO 15:02:14.074 [main] : Panasonic CX700
INFO 15:02:14.074 [main] : Panasonic DX
INFO 15:02:14.074 [main] : Panasonic E6
INFO 15:02:14.074 [main] : Panasonic ET60
INFO 15:02:14.074 [main] : Panasonic GT50
INFO 15:02:14.074 [main] : Panasonic GX800B
INFO 15:02:14.074 [main] : Panasonic Home Theater (SC-BTT)
INFO 15:02:14.074 [main] : Panasonic HZ1500
INFO 15:02:14.074 [main] : Panasonic S60
INFO 15:02:14.074 [main] : Panasonic ST60
INFO 15:02:14.074 [main] : Panasonic VT60
INFO 15:02:14.074 [main] : Philips 6500 Series TV
INFO 15:02:14.074 [main] : Philips Android TV
INFO 15:02:14.074 [main] : Samsung 2021 Q5
INFO 15:02:14.074 [main] : Samsung 2021+ QLED TV
INFO 15:02:14.074 [main] : Samsung EH5300
INFO 15:02:14.075 [main] : Samsung Note Tab
INFO 15:02:14.075 [main] : Samsung Q7 Series
INFO 15:02:14.075 [main] : Samsung Soundbar MS750
INFO 15:02:14.075 [main] : Skybox VR Player
INFO 15:02:14.075 [main] : Sony Blu-ray (2013)
INFO 15:02:14.075 [main] : Sony Bluray BDP-S3700
INFO 15:02:14.075 [main] : Sony Bluray UBP-X800M2
INFO 15:02:14.075 [main] : Sony Bravia EX
INFO 15:02:14.075 [main] : Sony Bravia HX
INFO 15:02:14.075 [main] : Sony Bravia W
INFO 15:02:14.075 [main] : Sony Bravia X
INFO 15:02:14.075 [main] : Sony Bravia XBR
INFO 15:02:14.075 [main] : Sony Bravia XD/XE/XF
INFO 15:02:14.075 [main] : Sony Bravia XH
INFO 15:02:14.075 [main] : Sony Bravia XR
INFO 15:02:14.075 [main] : Sony X Series TV
INFO 15:02:14.075 [main] : VLC for Apple TV 4K
INFO 15:02:14.075 [main] : VLC for iOS or macOS
INFO 15:02:14.075 [main] : Xperia Z3
INFO 15:02:14.075 [main] : Bigscreen
INFO 15:02:14.075 [main] : Chromecast
INFO 15:02:14.075 [main] : Denon AVR-4311CI
INFO 15:02:14.075 [main] : Denon AVR-X4200W
INFO 15:02:14.076 [main] : Hisense K680
INFO 15:02:14.076 [main] : LG Blu-ray Player (BP550)
INFO 15:02:14.076 [main] : LG EG910V
INFO 15:02:14.076 [main] : LG LED-backlit LCD TV
INFO 15:02:14.076 [main] : LG UB820V
INFO 15:02:14.076 [main] : LG UH770
INFO 15:02:14.076 [main] : LG WebOS TV
INFO 15:02:14.076 [main] : Lumin U1 Mini
INFO 15:02:14.076 [main] : Onkyo TX-NR8xx
INFO 15:02:14.076 [main] : Panasonic DMR
INFO 15:02:14.076 [main] : Panasonic TV
INFO 15:02:14.076 [main] : Samsung 2018 QLED TV
INFO 15:02:14.076 [main] : Samsung 5300 Series
INFO 15:02:14.076 [main] : Samsung 8 Series
INFO 15:02:14.076 [main] : Samsung 8K TV 2019+
INFO 15:02:14.076 [main] : Samsung 9 Series
INFO 15:02:14.076 [main] : Samsung BD-C6800
INFO 15:02:14.076 [main] : Samsung D6400
INFO 15:02:14.076 [main] : Samsung D7000
INFO 15:02:14.076 [main] : Samsung EH6070
INFO 15:02:14.076 [main] : Samsung ES6100
INFO 15:02:14.076 [main] : Samsung ES6575
INFO 15:02:14.076 [main] : Samsung ES8000
INFO 15:02:14.076 [main] : Samsung ES8005
INFO 15:02:14.076 [main] : Samsung F5100
INFO 15:02:14.076 [main] : Samsung F5505
INFO 15:02:14.076 [main] : Samsung F5900
INFO 15:02:14.076 [main] : Samsung H4500
INFO 15:02:14.076 [main] : Samsung H6203
INFO 15:02:14.076 [main] : Samsung H6400
INFO 15:02:14.077 [main] : Samsung H6500
INFO 15:02:14.077 [main] : Samsung HT-E3 Series
INFO 15:02:14.077 [main] : Samsung HT-F4
INFO 15:02:14.077 [main] : Samsung J55xx Series
INFO 15:02:14.077 [main] : Samsung J6200
INFO 15:02:14.077 [main] : Samsung LED UHD
INFO 15:02:14.077 [main] : Samsung PL51E490
INFO 15:02:14.077 [main] : Samsung Q9 Series
INFO 15:02:14.077 [main] : Samsung Soundbar
INFO 15:02:14.077 [main] : Samsung The Frame
INFO 15:02:14.077 [main] : Samsung UHD TV 2019+
INFO 15:02:14.077 [main] : Sony Blu-ray
INFO 15:02:14.077 [main] : Sony Bravia EX725
INFO 15:02:14.077 [main] : Sony SA-NS310
INFO 15:02:14.077 [main] : Vizio Smart TV
INFO 15:02:14.077 [main] : VLC for Apple TV
INFO 15:02:14.077 [main] : VLC for iOS (iPhone 5 or older)
INFO 15:02:14.077 [main] : Xbox One
INFO 15:02:14.077 [main] : Yamaha R-N303
INFO 15:02:14.077 [main] : Yamaha R-N500
INFO 15:02:14.077 [main] : Yamaha RX-A1010
INFO 15:02:14.077 [main] : Yamaha RX-A2050
INFO 15:02:14.077 [main] : Yamaha RX-V3900
INFO 15:02:14.077 [main] : Yamaha RX-V500D
INFO 15:02:14.077 [main] : Yamaha RX-V671
INFO 15:02:14.077 [main] : AirPlayer
INFO 15:02:14.077 [main] : Android
INFO 15:02:14.077 [main] : AnyCast
INFO 15:02:14.078 [main] : Apple iPad / iPhone
INFO 15:02:14.078 [main] : Azur BD
INFO 15:02:14.078 [main] : BRAVIA KDL-xxNX800
INFO 15:02:14.078 [main] : Bush Freeview Set Top Box
INFO 15:02:14.078 [main] : Caliber HPG336DAB/DIR
INFO 15:02:14.078 [main] : D-Link DSM-510
INFO 15:02:14.078 [main] : DirecTV
INFO 15:02:14.078 [main] : Fetch TV
INFO 15:02:14.078 [main] : foobar2000 mobile
INFO 15:02:14.078 [main] : Freebox
INFO 15:02:14.078 [main] : Freecom MusicPal
INFO 15:02:14.078 [main] : Hama IR320
INFO 15:02:14.078 [main] : KalemSoft Media Player
INFO 15:02:14.078 [main] : Kodi
INFO 15:02:14.078 [main] : LG Blu-ray Player (BDP)
INFO 15:02:14.078 [main] : LG Blu-ray Player (BP)
INFO 15:02:14.078 [main] : LG LA6200
INFO 15:02:14.078 [main] : LG LA644V
INFO 15:02:14.078 [main] : LG LM620
INFO 15:02:14.078 [main] : LG NANO TV
INFO 15:02:14.078 [main] : LG Smart TV Upgrader
INFO 15:02:14.078 [main] : Linn App (control point)
INFO 15:02:14.078 [main] : Logitech Squeezebox
INFO 15:02:14.078 [main] : Lumin
INFO 15:02:14.078 [main] : MediaPlayer
INFO 15:02:14.078 [main] : Miracast M806
INFO 15:02:14.078 [main] : Movian
INFO 15:02:14.078 [main] : Naim Mu-So Qb
INFO 15:02:14.078 [main] : Netgear NeoTV
INFO 15:02:14.079 [main] : Netgem N7700
INFO 15:02:14.079 [main] : NextCP2
INFO 15:02:14.079 [main] : Nokia N900
INFO 15:02:14.079 [main] : Onkyo TX-NR7xx
INFO 15:02:14.079 [main] : OPPO BDP
INFO 15:02:14.079 [main] : OPPO BDP-83
INFO 15:02:14.079 [main] : Panasonic BDT
INFO 15:02:14.079 [main] : Panasonic TX-L32V10E
INFO 15:02:14.079 [main] : Panasonic U30Z
INFO 15:02:14.079 [main] : Philips Aurea
INFO 15:02:14.079 [main] : Philips PUS TV
INFO 15:02:14.079 [main] : Philips TV
INFO 15:02:14.079 [main] : Pigasus
INFO 15:02:14.079 [main] : Pioneer BDP
INFO 15:02:14.079 [main] : Pioneer Kuro
INFO 15:02:14.079 [main] : PlayStation 3
INFO 15:02:14.079 [main] : PlayStation 4
INFO 15:02:14.079 [main] : PlayStation Vita
INFO 15:02:14.079 [main] : Popcorn Hour
INFO 15:02:14.079 [main] : Realtek
INFO 15:02:14.079 [main] : Roku (DVP 10)
INFO 15:02:14.079 [main] : Roku 3 (NSP 3)
INFO 15:02:14.079 [main] : Roku 3 (NSP 5)
INFO 15:02:14.079 [main] : Roku 3 (NSP 6-7)
INFO 15:02:14.079 [main] : Roku 4 (NSP 6-7)
INFO 15:02:14.079 [main] : Roku TV
INFO 15:02:14.079 [main] : Roku TV (NSP 8)
INFO 15:02:14.079 [main] : Roku TV 4K
INFO 15:02:14.080 [main] : Roku Ultra
INFO 15:02:14.080 [main] : Samsung C/D Series
INFO 15:02:14.080 [main] : Samsung C6600
INFO 15:02:14.080 [main] : Samsung E+ Series
INFO 15:02:14.080 [main] : Samsung Galaxy S5
INFO 15:02:14.080 [main] : Samsung Galaxy S7
INFO 15:02:14.080 [main] : Samsung Mobile
INFO 15:02:14.080 [main] : Samsung OLED
INFO 15:02:14.080 [main] : Samsung SMT-G7400
INFO 15:02:14.080 [main] : Samsung WiseLink
INFO 15:02:14.080 [main] : Sharp Aquos
INFO 15:02:14.080 [main] : Showtime 3
INFO 15:02:14.080 [main] : Showtime 4
INFO 15:02:14.080 [main] : Sony Bravia
INFO 15:02:14.080 [main] : Sony Bravia 4500
INFO 15:02:14.080 [main] : Sony Bravia 5500
INFO 15:02:14.080 [main] : Sony Bravia AG
INFO 15:02:14.080 [main] : Sony Bravia BX305
INFO 15:02:14.080 [main] : Sony Bravia EX620
INFO 15:02:14.080 [main] : Sony Bravia HX75
INFO 15:02:14.080 [main] : Sony Bravia NX70x
INFO 15:02:14.080 [main] : Sony Home Theatre System
INFO 15:02:14.080 [main] : Sony SMP-N100
INFO 15:02:14.080 [main] : Sony STR-DA5800ES
INFO 15:02:14.080 [main] : Sony STR-DN1080
INFO 15:02:14.080 [main] : Sony Xperia Z/ZL/ZQ/Z1/Z2
INFO 15:02:14.080 [main] : Streamium
INFO 15:02:14.080 [main] : Technisat S1+
INFO 15:02:14.080 [main] : Telefunken TV
INFO 15:02:14.080 [main] : Telstra T-Box
INFO 15:02:14.080 [main] : Thomson U3 Series
INFO 15:02:14.081 [main] : UnknownRenderer
INFO 15:02:14.081 [main] : VideoWeb TV
INFO 15:02:14.081 [main] : VLC for desktop
INFO 15:02:14.081 [main] : WD TV Live
INFO 15:02:14.081 [main] : WiiM
INFO 15:02:14.081 [main] : Windows Media Player
INFO 15:02:14.081 [main] : XBMC
INFO 15:02:14.081 [main] : Xbox 360
INFO 15:02:14.081 [main] : Yamaha AV Receiver
INFO 15:02:14.081 [main] Checking the fontconfig cache in the background, this can take two minutes or so.
INFO 15:02:14.114 [main] Configuration saved to "/home/david/.config/UMS/UMS.conf"
INFO 15:02:14.163 [main] Transcoding engine "FFmpeg Audio" is available
INFO 15:02:14.255 [main] Transcoding engine "MEncoder Video" is available
INFO 15:02:14.255 [main] Transcoding engine "FFmpeg Video" is available
INFO 15:02:14.259 [main] Transcoding engine "VLC Video" is available
INFO 15:02:14.260 [main] Transcoding engine "FFmpeg HLS Video" is available
INFO 15:02:14.261 [main] Transcoding engine "FFmpeg Web Video" is available
INFO 15:02:14.261 [main] Transcoding engine "MEncoder Web Video" is available
INFO 15:02:14.261 [main] Transcoding engine "VLC Web Video" is available
INFO 15:02:14.264 [main] Transcoding engine "tsMuxeR Video" is available
INFO 15:02:14.264 [main] Transcoding engine "tsMuxeR Audio" is available
INFO 15:02:14.265 [main] Transcoding engine "VLC Web Audio (Legacy)" is available
INFO 15:02:14.265 [main] Transcoding engine "VLC Web Video (Legacy)" is available
INFO 15:02:14.269 [main] Transcoding engine "DCRaw" is available
INFO 15:02:14.270 [main] Transcoding engine "youtube-dl" is available
INFO 15:02:14.531 [main] Using the following UUID configured in UMS.conf: f9c33979-ed94-41df-9b98-012aa48394cd
INFO 15:02:14.595 [main] Starting UPnP service...
INFO 15:02:14.623 [main] Registering UPnP servlet under context path:
INFO 15:02:14.634 [jupnp-stream-server 5-1] Starting Jetty server 12.1.8
INFO 15:02:14.652 [main] Starting Jetty HTTP client v12.1.8 connection manager/pool
INFO 15:02:14.684 [jupnp-multicast-receiver 3-1] IP Filter: Access allowed to 10.0.1.2
INFO 15:02:15.143 [main] Web player is available at: http://10.0.1.2:9002
INFO 15:02:16.040 [Web GUI browser] Launching the graphical interface on a browser
INFO 15:02:16.040 [Media Scanner] Media scan started
INFO 15:02:16.041 [main] Universal Media Server is now available for renderers to find
INFO 15:02:16.078 [Media Scanner] Loading MediaInfo library
INFO 15:02:16.105 [Media Scanner] Loaded MediaInfoLib - v24.01
Aborted (core dumped)My system info:
System:
Kernel: 6.17.0-35-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0 clocksource: tsc
Desktop: Cinnamon v: 6.6.7 tk: GTK v: 3.24.41 wm: Muffin v: 6.6.3 vt: 7 dm: LightDM v: 1.30.0
Distro: Linux Mint 22.3 Zena base: Ubuntu 24.04 noble
Machine:
Type: Desktop System: Gigabyte product: Z87X-OC v: N/A serial: <superuser required> Chassis:
type: 3 serial: <superuser required>
Mobo: Gigabyte model: Z87X-OC-CF v: x.x serial: <superuser required> uuid: <superuser required>
UEFI: American Megatrends v: F8 date: 03/18/2014
CPU:
Info: quad core model: Intel Core i7-4770K bits: 64 type: MT MCP smt: enabled arch: Haswell
rev: 3 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 3752 high: 3827 min/max: 800/3900 cores: 1: 3777 2: 3689 3: 3764 4: 3693
5: 3827 6: 3692 7: 3787 8: 3794 bogomips: 55868
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics vendor: Gigabyte
driver: i915 v: kernel arch: Gen-7.5 ports: active: HDMI-A-1,HDMI-A-2 empty: DP-1,HDMI-A-3,VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0412 class-ID: 0300
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X: loaded: modesetting
unloaded: fbdev,vesa dri: crocus gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,left model: LG (GoldStar) 23EA73 res: 1920x1080
hz: 60 dpi: 96 size: 510x290mm (20.08x11.42") diag: 587mm (23.1") modes: max: 1920x1080
min: 640x480
Monitor-2: HDMI-A-2 mapped: HDMI-2 pos: right model: LG (GoldStar) 23EA73 res: 1920x1080 hz: 60
dpi: 96 size: 510x290mm (20.08x11.42") diag: 587mm (23.1") modes: max: 1920x1080 min: 640x480
API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus device: 1 drv: swrast
gbm: drv: crocus surfaceless: drv: crocus x11: drv: crocus inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.8-0ubuntu0.24.04.2 glx-v: 1.4
direct-render: yes renderer: Mesa Intel HD Graphics 4600 (HSW GT2) device-ID: 8086:0412
API: Vulkan v: 1.3.275 layers: 3 surfaces: xcb,xlib device: 0 type: integrated-gpu driver: N/A
device-ID: 8086:0412 device: 1 type: cpu driver: N/A device-ID: 10005:0000
Audio:
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio driver: snd_hda_intel v: kernel
bus-ID: 00:03.0 chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Gigabyte 8
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
API: ALSA v: k6.17.0-35-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse status: active
2: wireplumber status: active 3: pipewire-alsa type: plugin
Network:
Device-1: Intel Ethernet I217-V vendor: Gigabyte driver: e1000e v: kernel port: f080
bus-ID: 00:19.0 chip-ID: 8086:153b class-ID: 0200
IF: eno1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:
Local Storage: total: 3.4 TiB used: 1.84 TiB (54.1%)
ID-1: /dev/sda vendor: Intel model: SSDSC2BW240A4 size: 223.57 GiB speed: 6.0 Gb/s tech: SSD
serial: <filter> fw-rev: DC02 scheme: GPT
ID-2: /dev/sdb vendor: Western Digital model: WD20EFRX-68EUZN0 size: 1.82 TiB speed: 6.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0A80 scheme: GPT
ID-3: /dev/sdc vendor: Western Digital model: WD10EACS-00D6B1 size: 931.51 GiB speed: 3.0 Gb/s
tech: N/A serial: <filter> fw-rev: 1A01 scheme: GPT
ID-4: /dev/sdd vendor: Toshiba model: APPLE HDD MK5065GSXF size: 465.76 GiB speed: 3.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1B
Partition:
ID-1: / size: 17.9 GiB used: 14.63 GiB (81.7%) fs: ext4 dev: /dev/sda3
ID-2: /boot/efi size: 499 MiB used: 7.1 MiB (1.4%) fs: vfat dev: /dev/sda1
Swap:
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
USB:
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 14 rev: 2.0 speed: 480 Mb/s lanes: 1
chip-ID: 1d6b:0002 class-ID: 0900
Hub-2: 1-7:2 info: Dell Keyboard Hub ports: 3 rev: 1.1 speed: 12 Mb/s lanes: 1 power: 100mA
chip-ID: 413c:1003 class-ID: 0900
Device-1: 1-7.1:4 info: Dell Keyboard type: keyboard,HID driver: hid-generic,usbhid
interfaces: 2 rev: 1.1 speed: 12 Mb/s lanes: 1 power: 50mA chip-ID: 413c:2010 class-ID: 0300
Hub-3: 1-9:3 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s lanes: 1 chip-ID: 045b:0209
class-ID: 0900
Device-1: 1-9.2:6 info: Microsoft Basic Optical Mouse type: mouse driver: hid-generic,usbhid
interfaces: 1 rev: 1.1 speed: 1.5 Mb/s lanes: 1 power: 100mA chip-ID: 045e:0084 class-ID: 0301
Hub-4: 1-10:5 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s lanes: 1 chip-ID: 045b:0209
class-ID: 0900
Hub-5: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s lanes: 1
Hub-6: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0 speed: 480 Mb/s
lanes: 1 chip-ID: 8087:8000 class-ID: 0900
Hub-7: 3-0:1 info: super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s lanes: 1 chip-ID: 1d6b:0003
class-ID: 0900
Hub-8: 3-5:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s lanes: 1 chip-ID: 045b:0210
class-ID: 0900
Hub-9: 3-6:3 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s lanes: 1 chip-ID: 045b:0210
class-ID: 0900
Hub-10: 4-0:1 info: full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s lanes: 1
Hub-11: 4-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0 speed: 480 Mb/s
lanes: 1 chip-ID: 8087:8008 class-ID: 0900
Sensors:
System Temperatures: cpu: 39.0 C mobo: N/A
Fan Speeds (rpm): N/A
Repos:
Packages: pm: dpkg pkgs: 1993
No active apt repos in: /etc/apt/sources.list
Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
1: deb https: //mirror.cpsc.ucalgary.ca/mirror/linuxmint.com/packages zena main upstream import backport
2: deb http: //archive.ubuntu.mirror.rafal.ca/ubuntu noble main restricted universe multiverse
3: deb http: //archive.ubuntu.mirror.rafal.ca/ubuntu noble-updates main restricted universe multiverse
4: deb http: //archive.ubuntu.mirror.rafal.ca/ubuntu noble-backports main restricted universe multiverse
5: deb http: //security.ubuntu.com/ubuntu/ noble-security main restricted universe multiverse
Active apt repos in: /etc/apt/sources.list.d/vscode.sources
1: deb [arch=amd64] https: //packages.microsoft.com/repos/code stable main
Info:
Memory: total: 16 GiB available: 15.51 GiB used: 4.16 GiB (26.8%)
Processes: 298 Power: uptime: 5h 7m states: freeze,mem,disk suspend: deep wakeups: 0
hibernate: platform Init: systemd v: 255 target: graphical (5) default: graphical
Compilers: gcc: 13.3.0 Client: Unknown python3.12 client inxi: 3.3.34
Re: Problem on Linux Mint 22.3
I don't know much about Linux so @boss should be of more help.
It might be helpful if you could get trace mode logs, see the section in red above.
If it is crashing before being able to open the GUI then you can manually edit /home/david/.config/UMS/UMS.conf to add
before running UMS then post /home/david/.config/UMS/debug.log and UMS.conf
This may be a permissions problem in linux so is preventing UMS from accessing its config files.
I see you are running from your downloads folder. Try installing it on your system folder, I think this is opt but not 100% sure
Someone else was having problems with this here but I don't think it went anywhere. you could try the same steps and see if that helps.
log_level = traceThis may be a permissions problem in linux so is preventing UMS from accessing its config files.
iamthebull
I moved the files to /opt/ums-15.6.0. Same thing.
UMS.conf
david@Desktop1:/opt/ums-15.6.0$ ./UMS.sh
20:11:59,062 |-INFO in ch.qos.logback.classic.model.processor.ConfigurationModelHandlerFull - Scan attribute not set or set to unrecognized value.
20:11:59,063 |-INFO in ch.qos.logback.core.model.processor.DefineModelHandler - About to instantiate property definer of type [net.pms.logging.DebugLogPropertyDefiner]
20:11:59,070 |-WARN in Logger[net.pms.configuration.UmsConfiguration] - No appenders present in context [default] for logger [net.pms.configuration.UmsConfiguration].
20:11:59,071 |-INFO in ch.qos.logback.core.model.processor.DefineModelHandler - Setting property logFilePath=/home/david/.config/UMS in scope LOCAL
20:11:59,071 |-INFO in ch.qos.logback.core.model.processor.DefineModelHandler - About to instantiate property definer of type [net.pms.logging.DebugLogPropertyDefiner]
20:11:59,071 |-INFO in ch.qos.logback.core.model.processor.DefineModelHandler - Setting property rootLevel=TRACE in scope LOCAL
20:11:59,071 |-INFO in ch.qos.logback.core.model.processor.DefineModelHandler - Setting property logFileName=debug.log in scope LOCAL
20:11:59,073 |-INFO in ch.qos.logback.core.model.processor.AppenderModelHandler - Processing appender named [traces]
20:11:59,073 |-INFO in ch.qos.logback.core.model.processor.AppenderModelHandler - About to instantiate appender of type [net.pms.logging.GuiManagerAppender]
20:11:59,094 |-INFO in ch.qos.logback.core.model.processor.AppenderModelHandler - Processing appender named [console]
20:11:59,094 |-INFO in ch.qos.logback.core.model.processor.AppenderModelHandler - About to instantiate appender of type [ch.qos.logback.core.ConsoleAppender]
20:11:59,095 |-INFO in ch.qos.logback.core.ConsoleAppender[console] - NOTE: Writing to the console can be slow. Try to avoid logging to the
20:11:59,095 |-INFO in ch.qos.logback.core.ConsoleAppender[console] - console in production environments, especially in high volume systems.
20:11:59,095 |-INFO in ch.qos.logback.core.ConsoleAppender[console] - See also https://logback.qos.ch/codes.html#slowConsole
20:11:59,095 |-INFO in ch.qos.logback.core.model.processor.AppenderModelHandler - Processing appender named [default.log]
20:11:59,095 |-INFO in ch.qos.logback.core.model.processor.AppenderModelHandler - About to instantiate appender of type [net.pms.logging.UmsFileAppender]
20:11:59,097 |-INFO in ch.qos.logback.core.model.processor.ModelInterpretationContext@66982506 - value "/home/david/.config/UMS/debug.log" substituted for "${logFilePath}${file.separator}${logFileName}"
20:11:59,100 |-INFO in net.pms.logging.UmsFileAppender[default.log] - The previous log will be compressed to [/home/david/.config/UMS/debug.log.prev.zip].
20:11:59,101 |-INFO in net.pms.logging.UmsCompressor - The target compressed file named [/home/david/.config/UMS/debug.log.zip] will be appended.
20:11:59,119 |-INFO in net.pms.logging.UmsCompressor - ZIP compressing [/home/david/.config/UMS/debug.log] as [debug.0000.log]
20:11:59,134 |-WARN in net.pms.logging.UmsFileAppender[default.log] - Append mode is mandatory for RollingFileAppender. Defaulting to append=true.
20:11:59,134 |-INFO in net.pms.logging.UmsFileAppender[default.log] - Active log file name: /home/david/.config/UMS/debug.log
20:11:59,134 |-INFO in net.pms.logging.UmsFileAppender[default.log] - File property is set to [/home/david/.config/UMS/debug.log]
20:11:59,135 |-INFO in ch.qos.logback.classic.model.processor.LoggerModelHandler - Setting level of logger [org.apache] to WARN
20:11:59,135 |-INFO in ch.qos.logback.classic.model.processor.LoggerModelHandler - Setting level of logger [httpclient.wire] to WARN
20:11:59,135 |-INFO in ch.qos.logback.classic.model.processor.LoggerModelHandler - Setting level of logger [fm.last.musicbrainz.coverart] to WARN
20:11:59,135 |-INFO in ch.qos.logback.classic.model.processor.LoggerModelHandler - Setting level of logger [oshi] to WARN
20:11:59,135 |-INFO in ch.qos.logback.classic.model.processor.LoggerModelHandler - Setting level of logger [org.eclipse.jetty] to WARN
20:11:59,135 |-INFO in ch.qos.logback.classic.model.processor.LoggerModelHandler - Setting level of logger [com.zaxxer.hikari] to INFO
20:11:59,135 |-INFO in ch.qos.logback.core.model.processor.ModelInterpretationContext@66982506 - value "TRACE" substituted for "${rootLevel}"
20:11:59,135 |-INFO in ch.qos.logback.classic.model.processor.RootLoggerModelHandler - Setting level of ROOT logger to TRACE
20:11:59,135 |-INFO in ch.qos.logback.core.model.processor.AppenderRefModelHandler - Attaching appender named [traces] to Logger[ROOT]
20:11:59,135 |-INFO in ch.qos.logback.core.model.processor.AppenderRefModelHandler - Attaching appender named [console] to Logger[ROOT]
20:11:59,135 |-INFO in ch.qos.logback.core.model.processor.AppenderRefModelHandler - Attaching appender named [default.log] to Logger[ROOT]
20:11:59,135 |-INFO in ch.qos.logback.core.model.processor.DefaultProcessor@70cf32e3 - End of configuration.
20:11:59,136 |-INFO in ch.qos.logback.classic.joran.JoranConfigurator@5a59ca5e - Registering current configuration as safe fallback point
INFO 20:11:59.283 [System Information Logger] System information:
Free Memory: 12.4 GiB
INFO 20:11:59.589 [main] Starting Universal Media Server 15.6.0
INFO 20:11:59.589 [main] Based on PS3 Media Server by shagrath, copyright 2008-2014
INFO 20:11:59.589 [main] https://www.universalmediaserver.com
INFO 20:11:59.589 [main] Build: 806496f92 (2026-04-25)
INFO 20:11:59.589 [main] Working directory: /opt/ums-15.6.0
INFO 20:11:59.589 [main] Temporary directory: /tmp/UMS-david
INFO 20:11:59.592 [main] Logging configuration file: /opt/ums-15.6.0/logback.xml
INFO 20:11:59.592 [main] Logfile: /home/david/.config/UMS/debug.log
INFO 20:11:59.592 [main] Profile directory: /home/david/.config/UMS
INFO 20:11:59.592 [main] Profile directory permissions: drwx
INFO 20:11:59.592 [main] Profile configuration file: /home/david/.config/UMS/UMS.conf
INFO 20:11:59.593 [main] Profile configuration file permissions: -rw-
INFO 20:11:59.593 [main] Profile name: Desktop1
INFO 20:11:59.602 [main] Using database engine version 2.4.240
INFO 20:11:59.603 [main] Database may use 80 MB for caching
INFO 20:11:59.604 [main] Using "medias" database located at: "/home/david/.config/UMS/database"
INFO 20:11:59.609 [main] HikariPool-1 - Starting...
INFO 20:11:59.904 [main] HikariPool-1 - Added connection conn0: url=jdbc:h2:/home/david/.config/UMS/database/medias user=SA
INFO 20:11:59.906 [main] HikariPool-1 - Start completed.
INFO 20:12:00.000 [main] Using database engine version 2.4.240
INFO 20:12:00.000 [main] Database may use 80 MB for caching
INFO 20:12:00.000 [main] Using "USERS" database located at: "/home/david/.config/UMS/database"
INFO 20:12:00.000 [main] HikariPool-2 - Starting...
INFO 20:12:00.010 [main] HikariPool-2 - Added connection conn1: url=jdbc:h2:/home/david/.config/UMS/database/USERS user=SA
INFO 20:12:00.010 [main] HikariPool-2 - Start completed.
INFO 20:12:00.034 [main] Finding user id: -1
INFO 20:12:00.039 [main] Getting shared content from configuration file : /home/david/.config/UMS/SHARED.conf
INFO 20:12:01.440 [main] Starting Jetty server 12.1.8
INFO 20:12:01.489 [main] GUI is available at: http://localhost:9001
INFO 20:12:01.491 [main] Starting Jetty server 12.1.8
INFO 20:12:01.502 [main] Finding user id: -1
INFO 20:12:01.503 [main] Loading renderer and device configurations from /opt/ums-15.6.0/renderers
INFO 20:12:01.744 [main] Enabled 217 configurations, listed in order of loading priority:
INFO 20:12:01.744 [main] : Samsung 2021 AU8/AU7/BEA/32Q6
INFO 20:12:01.744 [main] : LG TV 2025+
INFO 20:12:01.744 [main] : Mirascreen
INFO 20:12:01.744 [main] : Samsung 2021 AU9/Q6/43Q7/50Q7
INFO 20:12:01.744 [main] : Samsung 2021+ NEO QLED TV 8K
INFO 20:12:01.744 [main] : Sony Bravia XBR OLED
INFO 20:12:01.744 [main] : Amazon Fire TV Stick Vimu Player
INFO 20:12:01.744 [main] : BubbleUPnP
INFO 20:12:01.744 [main] : Chromecast Ultra
INFO 20:12:01.744 [main] : LG LCD TV (2014)
INFO 20:12:01.744 [main] : LG LED-backlit LCD TV (2022+)
INFO 20:12:01.744 [main] : LG LM660
INFO 20:12:01.744 [main] : LG LS5700
INFO 20:12:01.744 [main] : LG OLED
INFO 20:12:01.744 [main] : LG OLED 2020/2021
INFO 20:12:01.745 [main] : LG OLED 2022
INFO 20:12:01.745 [main] : LG TV 2023+
INFO 20:12:01.745 [main] : Naim Mu-So
INFO 20:12:01.745 [main] : Panasonic AS600
INFO 20:12:01.745 [main] : Panasonic AS650
INFO 20:12:01.745 [main] : Panasonic BDT220
INFO 20:12:01.745 [main] : Panasonic BDT360
INFO 20:12:01.745 [main] : Panasonic CX680
INFO 20:12:01.745 [main] : Panasonic CX700
INFO 20:12:01.745 [main] : Panasonic DX
INFO 20:12:01.745 [main] : Panasonic E6
INFO 20:12:01.745 [main] : Panasonic ET60
INFO 20:12:01.745 [main] : Panasonic GT50
INFO 20:12:01.745 [main] : Panasonic GX800B
INFO 20:12:01.745 [main] : Panasonic Home Theater (SC-BTT)
INFO 20:12:01.745 [main] : Panasonic HZ1500
INFO 20:12:01.745 [main] : Panasonic S60
INFO 20:12:01.745 [main] : Panasonic ST60
INFO 20:12:01.745 [main] : Panasonic VT60
INFO 20:12:01.745 [main] : Philips 6500 Series TV
INFO 20:12:01.746 [main] : Philips Android TV
INFO 20:12:01.746 [main] : Samsung 2021 Q5
INFO 20:12:01.746 [main] : Samsung 2021+ QLED TV
INFO 20:12:01.746 [main] : Samsung EH5300
INFO 20:12:01.746 [main] : Samsung Note Tab
INFO 20:12:01.746 [main] : Samsung Q7 Series
INFO 20:12:01.747 [main] : Samsung Soundbar MS750
INFO 20:12:01.747 [main] : Skybox VR Player
INFO 20:12:01.747 [main] : Sony Blu-ray (2013)
INFO 20:12:01.747 [main] : Sony Bluray BDP-S3700
INFO 20:12:01.747 [main] : Sony Bluray UBP-X800M2
INFO 20:12:01.747 [main] : Sony Bravia EX
INFO 20:12:01.747 [main] : Sony Bravia HX
INFO 20:12:01.747 [main] : Sony Bravia W
INFO 20:12:01.747 [main] : Sony Bravia X
INFO 20:12:01.747 [main] : Sony Bravia XBR
INFO 20:12:01.747 [main] : Sony Bravia XD/XE/XF
INFO 20:12:01.747 [main] : Sony Bravia XH
INFO 20:12:01.747 [main] : Sony Bravia XR
INFO 20:12:01.747 [main] : Sony X Series TV
INFO 20:12:01.747 [main] : VLC for Apple TV 4K
INFO 20:12:01.747 [main] : VLC for iOS or macOS
INFO 20:12:01.747 [main] : Xperia Z3
INFO 20:12:01.747 [main] : Bigscreen
INFO 20:12:01.747 [main] : Chromecast
INFO 20:12:01.748 [main] : Denon AVR-4311CI
INFO 20:12:01.748 [main] : Denon AVR-X4200W
INFO 20:12:01.748 [main] : Hisense K680
INFO 20:12:01.748 [main] : LG Blu-ray Player (BP550)
INFO 20:12:01.748 [main] : LG EG910V
INFO 20:12:01.748 [main] : LG LED-backlit LCD TV
INFO 20:12:01.748 [main] : LG UB820V
INFO 20:12:01.748 [main] : LG UH770
INFO 20:12:01.748 [main] : LG WebOS TV
INFO 20:12:01.748 [main] : Lumin U1 Mini
INFO 20:12:01.748 [main] : Onkyo TX-NR8xx
INFO 20:12:01.748 [main] : Panasonic DMR
INFO 20:12:01.748 [main] : Panasonic TV
INFO 20:12:01.748 [main] : Samsung 2018 QLED TV
INFO 20:12:01.748 [main] : Samsung 5300 Series
INFO 20:12:01.748 [main] : Samsung 8 Series
INFO 20:12:01.748 [main] : Samsung 8K TV 2019+
INFO 20:12:01.748 [main] : Samsung 9 Series
INFO 20:12:01.748 [main] : Samsung BD-C6800
INFO 20:12:01.748 [main] : Samsung D6400
INFO 20:12:01.748 [main] : Samsung D7000
INFO 20:12:01.748 [main] : Samsung EH6070
INFO 20:12:01.749 [main] : Samsung ES6100
INFO 20:12:01.749 [main] : Samsung ES6575
INFO 20:12:01.749 [main] : Samsung ES8000
INFO 20:12:01.749 [main] : Samsung ES8005
INFO 20:12:01.749 [main] : Samsung F5100
INFO 20:12:01.749 [main] : Samsung F5505
INFO 20:12:01.749 [main] : Samsung F5900
INFO 20:12:01.749 [main] : Samsung H4500
INFO 20:12:01.749 [main] : Samsung H6203
INFO 20:12:01.749 [main] : Samsung H6400
INFO 20:12:01.749 [main] : Samsung H6500
INFO 20:12:01.749 [main] : Samsung HT-E3 Series
INFO 20:12:01.749 [main] : Samsung HT-F4
INFO 20:12:01.749 [main] : Samsung J55xx Series
INFO 20:12:01.749 [main] : Samsung J6200
INFO 20:12:01.749 [main] : Samsung LED UHD
INFO 20:12:01.749 [main] : Samsung PL51E490
INFO 20:12:01.749 [main] : Samsung Q9 Series
INFO 20:12:01.749 [main] : Samsung Soundbar
INFO 20:12:01.749 [main] : Samsung The Frame
INFO 20:12:01.749 [main] : Samsung UHD TV 2019+
INFO 20:12:01.749 [main] : Sony Blu-ray
INFO 20:12:01.750 [main] : Sony Bravia EX725
INFO 20:12:01.750 [main] : Sony SA-NS310
INFO 20:12:01.750 [main] : Vizio Smart TV
INFO 20:12:01.750 [main] : VLC for Apple TV
INFO 20:12:01.750 [main] : VLC for iOS (iPhone 5 or older)
INFO 20:12:01.750 [main] : Xbox One
INFO 20:12:01.750 [main] : Yamaha R-N303
INFO 20:12:01.750 [main] : Yamaha R-N500
INFO 20:12:01.750 [main] : Yamaha RX-A1010
INFO 20:12:01.750 [main] : Yamaha RX-A2050
INFO 20:12:01.750 [main] : Yamaha RX-V3900
INFO 20:12:01.750 [main] : Yamaha RX-V500D
INFO 20:12:01.750 [main] : Yamaha RX-V671
INFO 20:12:01.750 [main] : AirPlayer
INFO 20:12:01.750 [main] : Android
INFO 20:12:01.750 [main] : AnyCast
INFO 20:12:01.750 [main] : Apple iPad / iPhone
INFO 20:12:01.750 [main] : Azur BD
INFO 20:12:01.750 [main] : BRAVIA KDL-xxNX800
INFO 20:12:01.750 [main] : Bush Freeview Set Top Box
INFO 20:12:01.750 [main] : Caliber HPG336DAB/DIR
INFO 20:12:01.751 [main] : D-Link DSM-510
INFO 20:12:01.751 [main] : DirecTV
INFO 20:12:01.751 [main] : Fetch TV
INFO 20:12:01.751 [main] : foobar2000 mobile
INFO 20:12:01.751 [main] : Freebox
INFO 20:12:01.751 [main] : Freecom MusicPal
INFO 20:12:01.751 [main] : Hama IR320
INFO 20:12:01.751 [main] : KalemSoft Media Player
INFO 20:12:01.751 [main] : Kodi
INFO 20:12:01.751 [main] : LG Blu-ray Player (BDP)
INFO 20:12:01.751 [main] : LG Blu-ray Player (BP)
INFO 20:12:01.751 [main] : LG LA6200
INFO 20:12:01.751 [main] : LG LA644V
INFO 20:12:01.751 [main] : LG LM620
INFO 20:12:01.751 [main] : LG NANO TV
INFO 20:12:01.751 [main] : LG Smart TV Upgrader
INFO 20:12:01.751 [main] : Linn App (control point)
INFO 20:12:01.751 [main] : Logitech Squeezebox
INFO 20:12:01.751 [main] : Lumin
INFO 20:12:01.751 [main] : MediaPlayer
INFO 20:12:01.751 [main] : Miracast M806
INFO 20:12:01.751 [main] : Movian
INFO 20:12:01.751 [main] : Naim Mu-So Qb
INFO 20:12:01.751 [main] : Netgear NeoTV
INFO 20:12:01.752 [main] : Netgem N7700
INFO 20:12:01.752 [main] : NextCP2
INFO 20:12:01.752 [main] : Nokia N900
INFO 20:12:01.752 [main] : Onkyo TX-NR7xx
INFO 20:12:01.752 [main] : OPPO BDP
INFO 20:12:01.752 [main] : OPPO BDP-83
INFO 20:12:01.752 [main] : Panasonic BDT
INFO 20:12:01.752 [main] : Panasonic TX-L32V10E
INFO 20:12:01.752 [main] : Panasonic U30Z
INFO 20:12:01.752 [main] : Philips Aurea
INFO 20:12:01.752 [main] : Philips PUS TV
INFO 20:12:01.752 [main] : Philips TV
INFO 20:12:01.752 [main] : Pigasus
INFO 20:12:01.752 [main] : Pioneer BDP
INFO 20:12:01.752 [main] : Pioneer Kuro
INFO 20:12:01.752 [main] : PlayStation 3
INFO 20:12:01.752 [main] : PlayStation 4
INFO 20:12:01.752 [main] : PlayStation Vita
INFO 20:12:01.752 [main] : Popcorn Hour
INFO 20:12:01.752 [main] : Realtek
INFO 20:12:01.752 [main] : Roku (DVP 10)
INFO 20:12:01.753 [main] : Roku 3 (NSP 3)
INFO 20:12:01.753 [main] : Roku 3 (NSP 5)
INFO 20:12:01.753 [main] : Roku 3 (NSP 6-7)
INFO 20:12:01.753 [main] : Roku 4 (NSP 6-7)
INFO 20:12:01.753 [main] : Roku TV
INFO 20:12:01.753 [main] : Roku TV (NSP 8)
INFO 20:12:01.753 [main] : Roku TV 4K
INFO 20:12:01.753 [main] : Roku Ultra
INFO 20:12:01.753 [main] : Samsung C/D Series
INFO 20:12:01.753 [main] : Samsung C6600
INFO 20:12:01.753 [main] : Samsung E+ Series
INFO 20:12:01.753 [main] : Samsung Galaxy S5
INFO 20:12:01.753 [main] : Samsung Galaxy S7
INFO 20:12:01.753 [main] : Samsung Mobile
INFO 20:12:01.753 [main] : Samsung OLED
INFO 20:12:01.753 [main] : Samsung SMT-G7400
INFO 20:12:01.753 [main] : Samsung WiseLink
INFO 20:12:01.753 [main] : Sharp Aquos
INFO 20:12:01.753 [main] : Showtime 3
INFO 20:12:01.753 [main] : Showtime 4
INFO 20:12:01.754 [main] : Sony Bravia
INFO 20:12:01.754 [main] : Sony Bravia 4500
INFO 20:12:01.754 [main] : Sony Bravia 5500
INFO 20:12:01.754 [main] : Sony Bravia AG
INFO 20:12:01.754 [main] : Sony Bravia BX305
INFO 20:12:01.754 [main] : Sony Bravia EX620
INFO 20:12:01.754 [main] : Sony Bravia HX75
INFO 20:12:01.754 [main] : Sony Bravia NX70x
INFO 20:12:01.754 [main] : Sony Home Theatre System
INFO 20:12:01.754 [main] : Sony SMP-N100
INFO 20:12:01.754 [main] : Sony STR-DA5800ES
INFO 20:12:01.754 [main] : Sony STR-DN1080
INFO 20:12:01.755 [main] : Sony Xperia Z/ZL/ZQ/Z1/Z2
INFO 20:12:01.755 [main] : Streamium
INFO 20:12:01.755 [main] : Technisat S1+
INFO 20:12:01.755 [main] : Telefunken TV
INFO 20:12:01.755 [main] : Telstra T-Box
INFO 20:12:01.755 [main] : Thomson U3 Series
INFO 20:12:01.755 [main] : UnknownRenderer
INFO 20:12:01.755 [main] : VideoWeb TV
INFO 20:12:01.755 [main] : VLC for desktop
INFO 20:12:01.755 [main] : WD TV Live
INFO 20:12:01.755 [main] : WiiM
INFO 20:12:01.755 [main] : Windows Media Player
INFO 20:12:01.755 [main] : XBMC
INFO 20:12:01.755 [main] : Xbox 360
INFO 20:12:01.755 [main] : Yamaha AV Receiver
INFO 20:12:01.756 [main] Checking the fontconfig cache in the background, this can take two minutes or so.
INFO 20:12:01.790 [main] Configuration saved to "/home/david/.config/UMS/UMS.conf"
INFO 20:12:01.853 [main] Transcoding engine "FFmpeg Audio" is available
INFO 20:12:01.950 [main] Transcoding engine "MEncoder Video" is available
INFO 20:12:01.950 [main] Transcoding engine "FFmpeg Video" is available
INFO 20:12:01.955 [main] Transcoding engine "VLC Video" is available
INFO 20:12:01.956 [main] Transcoding engine "FFmpeg HLS Video" is available
INFO 20:12:01.957 [main] Transcoding engine "FFmpeg Web Video" is available
INFO 20:12:01.957 [main] Transcoding engine "MEncoder Web Video" is available
INFO 20:12:01.958 [main] Transcoding engine "VLC Web Video" is available
INFO 20:12:01.961 [main] Transcoding engine "tsMuxeR Video" is available
INFO 20:12:01.961 [main] Transcoding engine "tsMuxeR Audio" is available
INFO 20:12:01.961 [main] Transcoding engine "VLC Web Audio (Legacy)" is available
INFO 20:12:01.962 [main] Transcoding engine "VLC Web Video (Legacy)" is available
INFO 20:12:01.965 [main] Transcoding engine "DCRaw" is available
INFO 20:12:01.965 [main] Transcoding engine "youtube-dl" is available
INFO 20:12:02.146 [main] Using the following UUID configured in UMS.conf: f9c33979-ed94-41df-9b98-012aa48394cd
INFO 20:12:02.198 [main] Starting UPnP service...
INFO 20:12:02.221 [main] Registering UPnP servlet under context path:
INFO 20:12:02.232 [jupnp-stream-server 5-1] Starting Jetty server 12.1.8
INFO 20:12:02.243 [main] Starting Jetty HTTP client v12.1.8 connection manager/pool
INFO 20:12:02.273 [jupnp-multicast-receiver 3-1] IP Filter: Access allowed to 10.0.1.2
INFO 20:12:02.732 [main] Web player is available at: http://10.0.1.2:9002
INFO 20:12:03.601 [Web GUI browser] Launching the graphical interface on a browser
INFO 20:12:03.601 [main] Universal Media Server is now available for renderers to find
INFO 20:12:03.601 [Media Scanner] Media scan started
INFO 20:12:03.632 [Media Scanner] Loading MediaInfo library
INFO 20:12:03.651 [Media Scanner] Loaded MediaInfoLib - v24.01
INFO 20:12:04.397 [webgui-server-51] Checking user table have admin
INFO 20:12:04.412 [webgui-server-51] Checking user table have admin
WARN 20:12:04.535 [webgui-server-52] Error verifying JWT: The token was expected to have 3 parts, but got 0.
WARN 20:12:04.539 [webgui-server-52] Error verifying JWT: The token was expected to have 3 parts, but got 0.
Aborted (core dumped)UMS.conf
jwt_secret = f7089946
cred.path = /home/david/.config/UMS/UMS.cred
language = en-GB
engines = FFmpegVideo,MEncoderVideo,tsMuxeRVideo,VLCVideo,FFmpegAudio,tsMuxeRAudio,FFmpegHlsVideo,FFmpegWebVideo,VLCWebVideo,VLCVideoStreaming,MEncoderWebVideo,VLCAudioStreaming,DCRaw,youtubeDl
engines_priority = FFmpegVideo,FFmpegHlsVideo,MEncoderVideo,tsMuxeRVideo,VLCVideo,FFmpegAudio,tsMuxeRAudio,FFmpegWebVideo,youtubeDl,VLCWebVideo,VLCVideoStreaming,MEncoderWebVideo,VLCAudioStreaming,DCRaw
was_youtube_dl_enabled_once = true
hide_advanced_options = false
scan_shared_folders_on_startup = true
run_wizard = false
show_info = false
ffmpeg_available_gpu_acceleration_methods = none,auto,cuda,vaapi,qsv,drm,opencl,vulkan,amf
uuid = f9c33979-ed94-41df-9b98-012aa48394cd
log_level = trace
iamthebull
I think the crash has something to do with the process that scans the shared folders. I set scan_shared_folders_on_startup = false in UMS.conf and was able to start the server without it crashing. I explored the web interface a bit then I manually triggered a scan of the shared folders in the web interface and after a few min it crashed again with the same output.
That log file is included here: Then I started the server again and triggered the scan of the shared folders but this time the server did not crash. Maybe because each time the scan partially finished and this time it fully completed??? Anyway that log file is here:
It does look to be related to the file scan as that is when it stops but there are no errors logged.
But in the last one the files would have been mostly scanned so is able to complete before it crashes.
In the first logs you posted there is a "malloc(): invalid size (unsorted)" at the end, I think malloc is memory allocation but I don't know enough to say if it is a OS thing or a problem in UMS.
Maybe it would work if you assign more memory to UMS in the startup script?
I think there is some OS logging that could help but I don't know anything about that. @boss do you have any ideas?
The correct location for UMS is in the /opt directory so keep using it from there.
mik_s is correct in that the "malloc(): invalid size (unsorted)" error is moreso related to the Linux system rather than UMS.
It could possibly be a corruption in the UMS database triggering it,
Try this.
Stop UMS
rm /home/david/.config/UMS/database -r
Restart UMS. A fresh database directory and database files will be created on startup.
See how that works.
If there is still a problem, can you post the following files inside a zipped file.
/opt/ums-15.6.0/UMS.sh
debug.log (in trace mode)
Try this.
Stop UMS
See how that works.
iamthebull
I removed the database and restarted UMS but I still had scan_shared_folders_on_startup = false in UMS.conf so I shut down the server and changed to true and restarted the server. No problems on the first startup since there was no scanning. The second startup crashed with the same malloc() error.
iamthebull
It was the same malloc() error but this time it says corrupted top size instead of invalid size (unsorted). I'm not sure if the difference is all that significant.iamthebull wrote: ↑Fri Jun 26, 2026 2:28 am The second startup crashed with the same malloc() error.
malloc(): corrupted top size
Aborted (core dumped)Re: Problem on Linux Mint 22.3
Your UMS.conf file (/home/david/.config/UMS/UMS.conf) seems incomplete. Normally there is a lot more in that file.
Compare my UMS.conf file with yours.
Perhaps that is because none of the entries with defaults have not been included in your UMS.conf file.
Just to make sure that is not causing any issues, can you:
mv /home/david/.config/UMS/UMS.conf /home/david/.config/UMS/UMS.conf.bak
and copy my UMS.conf to /home/david/.config/UMS/
*** In my UMS.conf you may wish to change the "server name"
Now it is: server_name = UMS (Satan)
It won't affect anything it will just display that name on your renderers.
You can change to: server_name =
Or what name you choose to be displayed. Change the "UMS (Satan)" part to your desired name.
EG: server_name = UMS Media Server
It looks like you are only using 1 shared folder which is all music. Is that the case?
What is your estimate of the number of music files in your shared folder?
Can you check that the following packages are installed on mint and they are the latest versions.
mediainfo
dcraw
vlc-nox
mplayer
mencoder
ffmpeg
It is probably worth getting the output of ffmpeg (to check the enabled options) as well if you could post that.
From the command line, just type in: ffmpeg
And copy all the output.
mediainfo
dcraw
vlc-nox
mplayer
mencoder
ffmpeg
- UMS.zip
- (17.18 KiB) Downloaded 590 times
iamthebull
The UMS.conf file you attached is exactly the same as the UMS.conf located in my /opt/ums-15.6.0/ folder and doesn't have the server_name set to anything. Did you send the right one?
The config wizard prompted me to share one folder and I randomly picked the Music folder. I have other folders with videos I was intending to share once I sorted the crashing issue out. There are around 3000 files and 230 directories in Music.
The INSTALL.txt in /opt/ums-15.6.0/ instructs to install the dependencies:
which doesn't include ffmpeg so I installed it and I still have the malloc() error. Also vlc-bin is listed instead of vlc-nox. Which one should it be? Maybe INSTALL.txt needs to be updated?
Here's what I have installed (they are the latest versions in the mint repositories):
ffmpeg
sudo apt-get install mediainfo dcraw vlc-bin mplayer mencoderHere's what I have installed (they are the latest versions in the mint repositories):
david@Desktop1:/media/shared/Music$ apt list --installed | grep -e mediainfo -e dcraw -e vlc-nox -e vlc-bin -e mplayer -e mencoder -e ffmpeg
dcraw/noble,now 9.28-5ubuntu1 amd64 [installed]
ffmpeg/noble,now 7:6.1.1-3ubuntu5 amd64 [installed]
ffmpegthumbnailer/noble,now 2.2.2+git20240104+dfsg-1build1 amd64 [installed]
libffmpegthumbnailer4v5/noble,now 2.2.2+git20240104+dfsg-1build1 amd64 [installed]
libmediainfo0v5/noble,now 24.01+dfsg-1build2 amd64 [installed,automatic]
libvlc-bin/noble,now 3.0.20-3build6 amd64 [installed,automatic]
mediainfo/noble,now 24.01.1-1build2 amd64 [installed]
mencoder/noble,now 2:1.5+svn38446-1build5 amd64 [installed]
mplayer/noble,now 2:1.5+svn38446-1build5 amd64 [installed]
vlc-bin/noble,now 3.0.20-3build6 amd64 [installed]
david@Desktop1:/opt/ums-15.6.0$ ffmpeg
ffmpeg version 6.1.1-3ubuntu5 Copyright (c) 2000-2023 the FFmpeg developers
built with gcc 13 (Ubuntu 13.2.0-23ubuntu3)
configuration: --prefix=/usr --extra-version=3ubuntu5 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --disable-omx --enable-gnutls --enable-libaom --enable-libass --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libglslang --enable-libgme --enable-libgsm --enable-libharfbuzz --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-openal --enable-opencl --enable-opengl --disable-sndio --enable-libvpl --disable-libmfx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-ladspa --enable-libbluray --enable-libjack --enable-libpulse --enable-librabbitmq --enable-librist --enable-libsrt --enable-libssh --enable-libsvtav1 --enable-libx264 --enable-libzmq --enable-libzvbi --enable-lv2 --enable-sdl2 --enable-libplacebo --enable-librav1e --enable-pocketsphinx --enable-librsvg --enable-libjxl --enable-shared
WARNING: library configuration mismatch
avcodec configuration: --prefix=/usr --extra-version=3ubuntu5 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --disable-omx --enable-gnutls --enable-libaom --enable-libass --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libglslang --enable-libgme --enable-libgsm --enable-libharfbuzz --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-openal --enable-opencl --enable-opengl --disable-sndio --enable-libvpl --disable-libmfx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-ladspa --enable-libbluray --enable-libjack --enable-libpulse --enable-librabbitmq --enable-librist --enable-libsrt --enable-libssh --enable-libsvtav1 --enable-libx264 --enable-libzmq --enable-libzvbi --enable-lv2 --enable-sdl2 --enable-libplacebo --enable-librav1e --enable-pocketsphinx --enable-librsvg --enable-libjxl --enable-shared --enable-version3 --disable-doc --disable-programs --disable-static --enable-libaribb24 --enable-libopencore_amrnb --enable-libopencore_amrwb --enable-libtesseract --enable-libvo_amrwbenc --enable-libsmbclient
libavutil 58. 29.100 / 58. 29.100
libavcodec 60. 31.102 / 60. 31.102
libavformat 60. 16.100 / 60. 16.100
libavdevice 60. 3.100 / 60. 3.100
libavfilter 9. 12.100 / 9. 12.100
libswscale 7. 5.100 / 7. 5.100
libswresample 4. 12.100 / 4. 12.100
libpostproc 57. 3.100 / 57. 3.100
Hyper fast Audio and Video encoder
usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...
Use -h to get full help or, even better, run 'man ffmpeg'
